Question about Polaroid Cameras
Camera is not turning on at all, when press button to turn on makes a beep sound and the light turn on green, then light goes off
Try charging the battery and see if that helps
Posted on Sep 19, 2008
P3015 beep
Here are some possible reasons why your printer is beeping:
1. Your printer is connected to a UPS (Uninterruptible Power Supply). When the printer goes through the printing cycle it uses a massive amount of electricity. During those few seconds of power usage, the UPS will beep indicating that it will not be able to sustain that power output for any period of time.
How to fix: Move your printer to another outlet and don't connect it to a UPS
2. You have an MFP (multi-function printer) that is attempting to fax again and again. When sending a fax, it's typical that the printer makes noises (dialing, connecting, etc). One of these noises is a fax response beep.
How to fix: Check your printers menu and turn off/down the fax volume
3. Some printers with an LCD menu and keypad make noise when keys are pressed or the printer encounters an alarm of some type. This can become annoying when typing keys for a phone number or by changing a menu setting.
How to fix: Check the menu settings for the printer and turn off/down the sound that's occuring. As an example, the HP LaserJet MFP series printers have the following sounds.
  • The alarm sound that the printer makes when it requires attention, such as when the all-in-one
    door is open.
  • The beeps that are emitted when you press the all-in-one control-panel buttons.
  • The phone line sounds for outgoing faxes.
  • The ring volume for incoming faxes.
As an example, change alarm volume by following these steps (using a 305X series printer)
1. Press Menu
2. Use the < or the > button to select System setup, and then press the green checkmark button
3. Use the < or the > button to select Volume settings, and then press green checkmark button
4. Press the green checkmark button to select Alarm volume
5. Use the < or the > button to select Off, Soft, Medium, or Loud
6. Press the green checkmark button to save your selection
Mar 20, 2014 | Office Equipment & Supplies
My Samsung TL205 digital camera will not turn on. The lens is out but when I press the power button, the green on button will light up then the camera will make one beep sound as the green light turns off....
I just fixed my camera. I pushed the lens inside completely. took the battery out and put it back in. turned it on and off a couple of times and ready to go!! good luck!
Feb 17, 2011 | Samsung DualView TL205 Digital Camera
My new camera (samsung TL205) will not turn on, when i press the power button I hear a chiming sound but the camera will not power on.
mine is doing the same thing. but my lense wont even close. and when i press the button to power on the green light comes on then beeps, then goes off. so if you get a word on how to fix it let me know.
Dec 24, 2010 | Samsung DualView TL220 Digital Camera
Three beeps when i try to turn it on
i had the same problem a while back. I fooled around with my camera lens a bit and it turned out that one side of the lens was sticking out a bit. I pressed down on this and pushed the power button and it worked. The next time I turned it on the same thing happened but if you keep doing the same thing it should work.
Hope this helps!
Aug 21, 2009 | Samsung L100 Digital Camera
Camera won't turn on - makes strange sound
This is a very common issue with digital camera on either the lens gears have to be replaced or the lens barrel need replacing. I rebuild these lenses all the time for 75.00 plus shipping and the turn around is normally less then a week. if you still need help fell free to contact me at
Feb 26, 2009 | Casio Exilim EX-S600 Digital Camera
Focusing Still Photos with SD870 IS
If you check page 45 in the manual, you'll see that the orange light during the half press indicates that the flash is turned on. A single beep means that the camera is having difficulty getting a "focus lock" (usually when shooting in low light conditions). See page 100 of the manual for suggestions on how to improve the chances for getting a well-focused picture.
May 01, 2008 | Canon PowerShot SD870 IS Digital Camera
Pentax Optio M20: won't work.
ok have same problem press the power button and and the play> button at the same time. your screen will come on but not lens. then hold the play button down untill lens come out. this will work for you , you may have to do it a couple of times but it will work
Jan 20, 2008 | Pentax Optio M20 Digital Camera
Digimax l60
I don't know, it's not powering up......
Jan 03, 2008 | Samsung Digimax L60 Digital Camera
Video Problems
Auto Mode In this mode, all you have to do is press the shutter button and let the camera do everything else. 1. Turn the camera on.
2. Turn the shooting mode dial to normal_mode.gif.
mode_dial.gif 3. Aim the camera at the subject.
4. Use the zoom lever to achieve the desired composition (relative subject size in the viewfinder).
  • The angle of view can be adjusted within the 45 to 100 mm range, in 35mm film equivalent.
  • When the LCD monitor is on, the combined use of the digital zoom and optical zoom enables magnified shooting up to approx. 7x.
5. Press the shutter button halfway.
  • Two beeps will sound when the camera has finished metering, and the indicator will light green or orange. If the LCD monitor is on, the AF frame will appear green.
  • The yellow indicator will blink and the beep will sound one time if the subject is difficult to focus on.
af_frame_indicator_a70.gif 6. Press the shutter button all the way.
  • You will hear the sound of the shutter when the shutter activates.
  • The picture appears for two seconds on the LCD monitor, if it is on.
  • The indicator next to the viewfinder blinks green while data is recorded onto the SD card.
Jun 10, 2007 | Canon PowerShot A400 Digital Camera
Camera wont turn beep sounds and green light glows when pressing power button
Does the lens extend in either of these cases? If there has been some malfunction in the lens and it fails to extend the situation can cause the camera to power-off in order to protect itself. Some cameras show error messages before powering off, others do not. Hold the camera up to your ear and turn the power on. Is there a series of mechanical sounds before the beeps? Hearing sounds but not seeing the lens extend indicates some sort of failure in the lens assembly. If you hear nothing then the problem most likely lies elsewhere, possibly a failed electronic component or something as simple as a loose connection. Check with your manufacturer for any recalls or technical bulletins, and see if they will service your camera under warranty. If not there are a number of repair facilitys available on the internet who generally have better rates than out-of-warranty service at the factory. David Millier Advance Camera Repair
Jan 08, 2007 | Samsung Digimax S500 Digital Camera
Cameras Logo
61 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
