I Have an LG front loader washing machine the WD 1018C and the dorr wont open i have tried everything
  • airwitch1 Apr 12, 2009
    I also have an LG WD1018C, and the door is jammed. The wash cycle has gone through, and no lights are showing on the panel. What do I do?
  • Carl Schulzetenberg
    Carl Schulzetenberg May 11, 2010
    After extensive search in LG USA data base, found no model WD 1018C.
  • 1,543 Answers
Have not heard back from you, so I'm guessing you have solved your problem. If not, send another comment. Please don't bother rating.
Posted on Oct 05, 2008
I have a LG WD-1018C washer that wont spin out .. it just keep starting and stopping in about 30 second intervals ... an error code has just come up ... 1E ...can you help please ? Steve
The IE or 1E error or fault code indicates that the washer is not filling with water. Check to be sure the water supply valves are open. Also, check to be sure the water supply hoses aren't kinked or clogged. Next, remove the hoses from the washing machine and run water into a bucket to test the pressure and flow of the water. If all of these check out and you have good water pressure and flow to the machine, you should replace the water inlet valve.
Feb 20, 2015 | LG Washing Machines
Lg washing machine is making a squeaking sound and not spinning dry. Do I need to replace the belt? 7.5kg washer model WD-1018C
check the belt tension before replacing. there should be about 1/2" deflection (play) on the longest open side of the belt.
Mar 21, 2014 | LG WM1812C Front Load Washer
My lg intello front loader washing machine door is stuck the machine will not wok as the de keep flashing any ideas how i can open door to get clothes out
put outlet hose on ground drain water out ,then between the handle and the manchine theres a hook put something there to pull it towards u and it will open but its not easy , but is for me
Jan 17, 2013 | LG WD-1080FD Front Load Washer
The door is jammed on my LG Intellowasher WD-1023C-Washing Machine - Front loader. It has finished it's wash cycle, but the door won't open
Slide a paint scraper or similar between the machine and the latch side and push it quite hard and it should open. Mine does and I found the fix on this site!
Jul 13, 2011 | LG WD-1041WFH Front Load Washer
Looking for a instruction manuel for an LG intellowasher WD1018C
  • Your instruction manual is here
http://safemanuals.com/user-guide-instructions-owner-manual/LG/WD-1018C-_E
  • Now when you go to there link you will click on the "download the complete user guide" PDF link in the upper right hand corner of the screen. Then it will ask you to rate 4 questions about the washing machine and leave a comment about it. Once you do that click "download user guide" and it will drop the PDF into your PC. I just did it and scanned it and open it so everything is safe and it will get you your manual quick and free.
Regards, Tony
May 01, 2011 | LG Washing Machines
Need the operating manual for a lg intellowasher 7.5 wd-1018c
go to www.lg.com/au then click on product support left hand side of screen then type in wd-1018c in search box under box high lighted in red wd-1018c washing machine comes up. click on it. half way down page down load pdf for manual
Oct 10, 2010 | Washing Machines
Top loader door wont open
Something has caused the washer to not release the door. Is there an error code that is flashing (FE?). A locked door can be due to too much water in the basket, suds causing false water detection (should be using HE), or perhaps the drain is clogged.
If you are sure that the water is not going to spill out on floor, then you might be able to get door open by unplugging the unit and waiting a few minutes (mine took an hour) for the electric lock to release.
Sep 15, 2009 | LG WD-16115FD Front Load Washer
The door on my LG WD-1018C frontloader won't open.
Unplug electrical cord, wait one minute then plug back in. Sorry this is all I can tell u as I cannot find a parts diagram anywhere on Internet, not only is LG not helping u they don't want anyone else to help either by keeping their drawings secret. You might try sears partsdirect.com and talk to tech.
Nov 20, 2017 | GE WBVH6240F Front Load Washer
LG Front Loader WD-8074FHB
sometimes you just have to force the door but first try hitting the machine near the door lock sometimes this helps the door interlock may be stuck in the closed position
Mar 02, 2008 | LG WM1812C Front Load Washer
Door Wont Open
Your washing machine is fucked, and your clothes probably have more chance of fitting your cat than they do you. is your washing machine french...?
Jan 01, 2008 | Washing Machines
Washing Machines Logo
282 people viewed this question
Top Washing Machines Experts
