Question about Whirlpool GR399LXHS Electric Kitchen Range
How do I change the element on a Whirlpool Gold range?
I have a Whirlpool Gold range with a ceramic (smooth) top. The double element does not work and I have purchased a new one. It seems easy to install as I have the top up and have replaced the burner...but it still doesn't work. Please help.
  • Anonymous Mar 31, 2014
    how to replace burner on whirlpool model gw385lepbo5
  • 5,911 Answers
If you have replaced the dual element with a new one, and have verified that you have the wiring installed correctly, it may be the infinite switch that controls the element that is bad. That would be the switch behind the control knob for the element in question.
Posted on Sep 19, 2008
Hi, I have a Rangemaster 110 (electric double oven), which has a double grill. Unfortunately one half of the grill has blown - not working. Is it easy to repair? Thanks a lot - Krisztina
Usually fairly straight forward. Remove the blown element being careful not to loose the wires into the void behind the grill. Insert new element making sure the orientation and wires are conected as the original was.
Dec 28, 2010 | Rangemaster Range Cookers Kitchener 110...
Whirlpool Gold Accubake System smooth top stove keeps kicking out the 10 amp breaker, sometimes with oven on, sometimes just a burner on, just started doing this a week ago, why????
I have had teh same issue. Not sure if its a design issue or that is just how it works. I have replaced the element, the thermostat and the control board and it still does the repeated cycling.
Aug 30, 2010 | Whirlpool Kitchen Ranges
Discoloration on ceramic top
Hi- High temps make for tricky maintenance of glass or ceramic tops. The heat element must pass its heat energy through the glass or ceramic and into the pan. Water droplets will steam away, while a spatter of oil or even a few grains of sugar will melt and burn to a tough film of carbon on the surface. The obvious preventitive measures of checking pan bottoms thoroughly before contact with clean (yes- very clean) cooktop surface mean most spots may be small, they can be annoying to look at and tough to remove. My best cleaning results for these spots came from using a VERY small amount of OVEN cleaner (use gloves) on a paper towel placed on spot for a few minutes. A clean, new razor blade may be used to scrape off film. Hope this helps. - Thanks- ED
Feb 25, 2010 | Kitchen Ranges
Ceramic top temperature control
This would be a faulty switch. Hope this helps!
Mar 08, 2009 | Whirlpool GR465LXLS Electric Kitchen Range
Whirlpool Gold Range Mod GLP84900
Hi I have a whirlpool gold range mdl GJSP 84902 and had replaced the bottom hidden element after finding out it wasn't getting any heat. So replacement took a little figuring out. it ws easy after a removal of screws and pulling out the whole oven casing out fron the front. Anyhow I still don't get enough heat generate from the bottom element, what other cause are there. checked fuses wiring all is connected HELP ME PLEASE !!!!! thank you Paul
Nov 02, 2008 | Whirlpool GR465LXLS Electric Kitchen Range
Whirlpool RF367LXS Ceramic Glass Range not working
either the element is burned out of the switch that controls the element is bad
Nov 25, 2007 | Kitchen Ranges
Whirlpool GR399LXHS Electric Kitchen Range Logo
855 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
