Question about LG DLE2514 Electric Dryer
LG 2514W Rear Seal
The rear seal on my LG 2514W Electric Dryer needs to be replaced. It looks like rubber in the back, with a soft, fibrous, felt-like material attached to it that acts like a cushion between the drum and the back plate. The felt-like part has broken and part of it is now hanging in the drum. I can tuck it back into the crack between the drum and the back plate, but it just comes right back out again. The dryer function works fine. I'm afraid to keep using it, but cannot find ANY repair person to come out and fix this problem! I live in Western MA and I've called everyone in the yellow pages. Either they don't service LG, or they don't do any service in my area. I found a service manual online that gives me exploded views of the whole unit, but cannot discern whether I'm going to have to take the top off, then the front and remove the drum by pulling it out the front, or take the top off and deal with the seal from the rear. I hope you can help me with this. I will never buy another LG product again! I will only buy mainstream names that anyone can repair if needed. Thank you.
  • 706 Answers
Here is a link to the service manual ( think you already have this but if not.. here it is..
http://136.166.4.200/contents/Laundry/DLE2514/DLE2514_Service_Manual.pdf
and here is the disassembly link
http://136.166.4.200/contents/Laundry/DLE2514/DLE2514_Disassembly.pdf
As for gasket replacement, consider this.. If you are attempting this yourself.. order the correct gasket and gasket cement from an appliance dealer..I believe item #A460 and the part number for your model is 4986EL2004D so that is what you will need to order. Typically, you would just remove the drum from the chassis and glue the gasket in place after removing the original one. Just follow the disassembly intructions tyat I've attached as a link and then the drum comes out fairly simply.. If you have access to a digital camera, take a few before pictures of the drum, belt and pulley system so you can use them as backup in case you get confused.. It really isn't all that difficult. As alway.. make sure you UNPLUG it first... Good Luck..
Posted on Sep 19, 2008
    Novelist:
    Champion:
  • 261 Answers
Hi kc,
You are on the right track, the dryer has many screws and sections to pull off including the top and front. I use a plastic scraper from Ace Hardware to remove old felt to prevent scraping enamel on drum. Note how the belt loops on the tensioner to the motor pulley.
Brown marks left on clothing -- occasionally My dryer is not gas but electric but that wasn't a choice on here.
If your clothes get marked or torn in your dryer, check these: Rollers Rear seal Front glides Front seal Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Aug 01, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
My dryer leaves burn marks on the clothes. What
Hi. Thanks for using fixya. I can help you. When clothes get marked or torn in your dryer, check these: Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it. small_8_13.jpg
Nov 09, 2009 | GE DBL333EA Electric Dryer
Hi, when dryer is running it is noisy. It is level, all 4 legs are tight and have rubber feet attached. Noise continues after load is leveled and when only 1 or 2 small items are being dried. Appears to be...
You need to replace the 2 rear drum roller wheels and probably the rear drum felt seal. While you have it torn down inspect the front drum glides for wear.
This dryer is worth repairing.
Aug 28, 2009 | Maytag Neptune MDE5500AY Electric Dryer
My clothes have brown marks on them that look like burn marks. has this been a problem with maytag neptune dryers? if so, what is going on?
Rollers
Rear seal
Front glides
Front seal
Jun 29, 2009 | Maytag Neptune MDE4000 Electric Dryer
Grease type substance inside
Hello. I know exactly what is wrong with your dryer.
Rollers
Rear seal
Front glides
Front seal
Jun 07, 2009 | Dryers
Clothes get stuck between dryer and barrel
If your clothes get stuck, marked or torn in your dryer, check these:
Rollers
Rear seal
Front glides
Front seal
May 31, 2009 | Electrolux Kenmore 5.8 cu. ft. Super...
Narrow streak of what looks like grease on clothes from dryer
hi anne-
May 09, 2009 | Dryers
Black carbon/soot on the door and lint filter of my dryer
I have the same problem with a Maytag Performa gas dryer. My husband took our dryer apart and found that the burner tube which leads from the burner to the back of the dryer was full of soot (which was getting blown back into the dryer drum with the hot air.) We are cleaning it out now but would like to know how to prevent this from recurring in the future.
Dec 16, 2008 | Kenmore 62602 Electric Dryer
LG 2514W Rear Seal
I've used a company called MCMINONE online to order most components for LG products. Try them first.. If that fails to reap benefits.. I would call appliance repair shops in your area or search online for parts for LG products.. ( there are numerous hits if you do that) and get your parts that way.
You will need to remove the top and front to pull the drum out and that is done typically by removing three screws on the back of the cover.. to allow it to slide toward the back of the unit then you should be able to lift it off. You'll need to unscrew the filter housing and with the top cover removed you should be able to remove a few sheet metal screws to detach the front panel.. You'll also have to disconnect the door switch... and the drum belt.. ( here is where you may want a digital picture to use as reference when reinstalling it.. )
As for gasket cement, you can get some in a small container at an automotive parts store of the parts house you find to get your gasket should be able to provide that too..
I am in my day job now ( lunch break) and can assist you better from home later on if you need any additional information.. feel free to ask.. ( If I recall correctly, did you say you lived in western mass?) If thats true, I may know arepair man that would be willing to assist you.. but I would have to ask first.. Please advise on that one.. TTYL
Sep 19, 2008 | LG DLE2514 Electric Dryer
Torn clothes
Rollers
Rear seal
Front glides
Front seal
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Mar 30, 2008 | Frigidaire GLEQ2152ES Electric Dryer
LG DLE2514 Electric Dryer Logo
136 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
