Audiovox JHT140/Jensen JHT140 remote control code
Need Audiovox JHT140/Jensen JHT140 remote control code.
5 Suggested Answers
SOURCE: JENSEN JER 323 REMOTE
i need the tv codes for the jensen jer 323 remote for a diamond tv
Posted on Feb 06, 2008
SOURCE: jensen JR800C remote control
I have the manual , key learn feature is easier for newer units.046ab2b.gif1b6682c.gif0aa0186.gifbba9f50.gif
Posted on Mar 30, 2008
whytfang
  • 170 Answers
SOURCE: I NEED THE CODES
Here is the user manual...this should help...
Here you go...it took a while but I found it cause I ROCK....that'sright say it with me....He...Rocks...hehe...but anyway here is the linkaddress if the link doesn't work...
http://safemanuals.com/user-guide-instructions-owner-manual/JENSEN/JER-321-_E
I hope this helps...good luck and thanks for rating my effort....the Fang
Download the completeuser guide (3257 Ko)
Posted on May 20, 2009
whytfang
  • 170 Answers
SOURCE: I need programming instructions for Jensen Remote
Here you go...it took a while but I found the user manual cause I ROCK....that's right say it with me....He...Rocks...hehe...but anyway here is the link address if the link doesn't work...
ginko
  • 19396 Answers
SOURCE: nvx430bt jensen gps initialization error no language files
Hi.
This happens when the language files stored in your Jensen's memory get damaged. The Sat Nav system will look for new language files on your USB memory, and return the error.
Often the problem happens because you formatted the disk.
I suggest to start trying to set language to English.
In theory you are supposed to restore the flash image from original CD or computer backup.
A first attempt to fix the problem can be done resetting the Sat Nav. Just take out the battery for ten seconds.
If you have the original CD, files to be restored are in the IGO folder, and must be copied into the flash disk.
Files to be copied are
  • igolaunch.exe
  • IGOPATH.TXT
  • SettingsBackup.ini
  • TAHOMA.TTF
  • TAHOMABD.TTF
If that does not work, contact Jensen/Audiovox clicking here, they will enable a download of the language files to replace the damaged ones.
Posted on Dec 29, 2009
Need universal remote codes for audiovox tv
Try 053 or 0053 Source: http://www.universalremotecodes.org/ge
Aug 05, 2012 | Jensen JR400 Remote Control
Problem with jensen universal remote control
the problem is still unclear.
can you mention what is the problem exactly?
for which model of TV you need the codes?
Jul 30, 2008 | Jensen JER-321 Remote Control
HOW DO I FIND REPLACEMENT FACE PLATE & REMOTE FOR JENSON MODEL #DV2007
Here is where to get a replacement waterproof remote - http://www.jensenmarinedirect.com/jensen-waterproof-wired-remote-control.html With these marine radios the faceplate is usually the first thing to fail from water damage. Not that your is water damaged but because of this finding a used one is impossible on the net. You will have to contact Jensen for to see if they have the faceplate available separately. http://audiovox.com/jensen/ Good luck.
Regards, Tony
Apr 14, 2011 | Jensen Car Audio & Video
What is the all codes
Depends on the model of Jensen Remote.
Jensen was a division of Recoton, and Audiovox bough them out some years ago. The current Audiovox website does not keep infornation on older remote models.
http://replay.web.archive.org/20010401224505/http://jensenremotes.com/ is a snapshot of the website from 2001. Is your model listed there? You can access some of the old codes there, or leave a comment with your exact model number.
Some more modern TVs will use codes that older remotes cannot produce.
Feb 23, 2011 | Jensen 143307 Remote Control
I NEED A REPLACEMENT REMOTE FOR A JENSEN TS2050J WHICH ONE DO I GET AND WHERE DO I GET IT FROM?...............THANKS
You can get a replacement remote here: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=TS2050J&uuid=12929864096390 .
Alternatively, you can get a universal remote and try the Audiovox codes if Jensen isn't listed. You may need one of the higher end remotes to match features like changing the source of the TV. (An input/source button will be useful.) Just make sure to check if the remote code does more than turn the TV on and off and changes the channel before deciding that you have the correct code programmed.
I hope this helps.
Dec 22, 2010 | Jensen TS2050J 20" TV
Need codes please for Jensen JER 422 for Magnabox TV
magnavox tv jer 422 codes are: 1000 1004 1006 1008 1019 1062 1068 1069 1075 1076 1133 1219
Jan 12, 2008 | Jensen JER-422 Universal Remote Control
Need codes for a jr400
Your codes can be found here:
http://www.remotecodelist.com/remotes/jensen/JR300C.pdf
Nov 27, 2007 | Jensen JR400 Remote Control
Programming code for remote control jensen jr321
I am not 100% positive that the JR-321 is supported in the 300 series but.
Jensen JR300 manual - If you cant get it to work using one of these codes it does not support your unit.
http://157.254.235.130/public/IBJ34500SE.pdf
or
http://157.254.235.130/public/J3_4_500_MANUAL_S_E.pdf
Hope that helps!
Oct 03, 2007 | Jensen JR500 Remote Control
159 people viewed this question
 Grubhead
Grubhead
