Question about Sony Handycam DCR-PC105E Mini DV Digital Camcorder
Memory stick recording
We have just purchased a Sony handycam and also a memory stick. When I insert the memory stick for recording and push record, it indicates no disc. What procedure do we do for memory stick recording. The book really says nothing about this.
  • simmers15 Sep 19, 2008
    There is not this option, and also The salesperson at Best Buy told us you could record on the memory stick, however, Sony says you cannot record a video on a memory stick. The memory stick is only for still pictures. Thank you for your input
    Master:
  • 763 Answers
That means your camcorder is set to record on the disc not on the memory card. try to look on the settings on your camcorder there's an option fo you to choose like disc or memory card to be use as recording. hope that helps!
CHARCOIS
Posted on Sep 19, 2008
Why do I see MEMORY STICK ERROR on my Sony camcorder?
Check the memory stick for a little slide lock on the side. Make sure that is not in the locked position. This feature is there to prevent people from recording over special memories, like weddings. But sometimes during handling (or just not knowing) people accidentally switch it to "lock"
Good luck
Oct 03, 2012 | Sony Handycam DCR-TRV350 Digital Camcorder
Sony Handycam HDR-XR150 - Cannot access data in hard drive. Visible in windows as removable drive E but error message Please insert a disk into drive E: E:31.00 message blinking continuously. Please help....
hi i format my handycam hdr-xr150e(sony) hdd then i see e:31:00 then i insert memory stick and do wht you help(1- Place the memory stick 2- Go to "Home" -> "Manage Media" (or something like that) -> And select the option to change to the memory stick, instead of HD.) now i can record but in top of screen the e:31:00 not removed
Jan 19, 2011 | Sony Handycam HDR-XR520 High Definition...
I have a Sony Memory Stick Duo Adapter with 1 GB Memory Stick Pro Duo insert. When I put in my DCR-TRV18 camera and switch it to Memory, I get Memory Stick Error on the screen
On many cameras , the picture format that you can save on memory stick is not the same that you can have by recording on tapes. It should be the same on your handycam.
You can increase memory stick to at least 2GB, that is what sony reccomends, you can test a 4 gb to 16 gb at the shop, if it works , then buy it.
However, the quality of movies grabbed on memory stick, should be far less than the one of movies recorded on tape.
Dec 27, 2010 | Sony Handycam DCR-TRV18 Mini DV Digital...
How do I get Handycam DCR-DVD305 to recod videos onto a memory stick duo pro?
It is not possible to record the videos onto a Memory Stick Duo or Pro Duo, as this Camcorder DCRDVD305 does not support video recording onto the Memory Stick.
To record the videos you may use 8cm DVD-R/DVD-RW/DVD+RW.
Aug 23, 2010 | Sony Handycam DCR-DVD305 DVD Camcorder
What memory stick works in the DCR-TRV340 Sony Handycam?
Mine says msa-4a. the duo sticks won't work. You will the larger older memory sticks
Apr 26, 2010 | Sony Handycam DCR-TRV340 Digital Camcorder
Sony CX-12 Camcorder gives message when memory stick inserted
Hi!
This is a feature and not a defect of the CX-12 that reminds the user that the memory stick inserted might not be able to record the data from the camera effectively. HD video requires a memory stick with a relatively fast data read/write speed, and the CX-12 recommends not using any other stick that is not Mark 2.
Fortunately, though, as you have found out, it does not affect the camera's ability to record in non-Mark 2 sticks.
Hope this helps!
Nov 13, 2008 | Sony Handycam HDR-CX12 Flash Media...
Sony handycam not recognizing memory stick
i think the 108 will only put pics on card- may not show card unless in camera mode-put in camera mode w/no disc and see if it shows how many avail pics-i don't think 108 records video on card
May 21, 2008 | Sony Handycam DCR-DVD108 DVD Camcorder
Open Questions:
Sony Handycam DCR-PC105E Mini DV Digital Camcorder Logo
412 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
