Question about Arctic Products Grilling
Side-Kick gas bbq
I have a side-kick gas bbq that attaches to the side of my RV. it fell off and the gas regulator broke, its the regulator that attaches to my propane tank with a quick connect. Please help me find the replacement part. ?
Bill
meBNme
  • 334 Answers
SOURCE: BBQ Galore Capt'n Cook 4 burner gas grill won't get hot.
You can buy a gas pressure guage from any HVAC supply house, and possibly at a gas utility office or the retailer that sold the grill.
It taps into the manifold, or gas valve.
For most LP systems you are looking for 11 to 14 PSI but double check with your system. You may can find it on the owners manual or on the data sticker.
Be shure to shut off the gas before you remove the plug and hook up the guage. Most plugs are either allen wrench or square head plugs.
Posted on Dec 06, 2008
SOURCE: no gas getting to bbq
I switched to the new style 20# tank with the new turn-on knob.  I couldn't get enough gas pressure to the BBQ burners for all three burners to light or to keep a strong flame on even one burner.  The new style tanks have a safety valve on the inside of the tank that shuts the gas off if you turn the knob on too fast because the safety valve thinks there is leak.  Shut everything off and then try turning the knob on real slow, especially at first, before turning it all the way on.  If that doesn't work (it didn't for me), then replace the large plastic connection valve knob (female end) that attaches the regulator to the tank.  Mine was for the old style tank and was black (low pressure).  I went to a propane company and had them replace it with a green knob (higher pressure).  Took it home and WALA!  Everything works fine now.  But it was very frustrating trying to figure why I couldn't get any gas to the burners after buying a brand new tank.  I hope this helps solve your problems.
Posted on Dec 22, 2008
TheMobilian
  • 8220 Answers
SOURCE: cannot conect regulator to small 16.4 oz propane tank
It must have some sort of packing spacer you need to remove from the hose to attach the tank. LOL
Posted on Apr 12, 2009
  • 46 Answers
SOURCE: bbq regulator
should be able to get some help at your local hardware or home & garden store!
Posted on May 31, 2009
Most modern gas regulators have a safety feature to prevent gas left on. If you shut off the tank first and then turn off the burners, it will trigger and keep the gas flow at a very reduce flow to prevent you from turning on the tank again with the burners left on and not realizing it. Turn everything off and then turn on tank first, followed by the burners and this will solve most problems of a low flame or a bbq that won't get hot.
Posted on Jun 13, 2009
Why did the driver side window fall in the door?
Hi, Its likely not the window regulator. Something could have come apart or broke where it attaches, but you will have to take it apart to find out.
Aug 30, 2014 | 2002 Ford Escort
I have a ducane bbq and am having problems reattaching the gas line to the house
If it is push pull, on the house side pull back the gas pipe ring about 1/4 inch insert gas hose and release ring. If it is threaded, turn gas hose, bbq side, ring counter clock wise and it will attach.
Apr 24, 2014 | Ducane 30400042 (LP)
We leave our RV on a river lot on occasion and return home. I forgot to shut off the furnace, although I turned off the gas. Will the unit run without the gas being on?
if the thremostat calls it will kick on the fan it will run. And keep running until it is shut off. Think about it if the temp gets low it will kick on to heat the space and it will run until it gets the desired temp/
Oct 23, 2013 | Dometic Rooftop RV Air Conditioner
Honda 1984 cb700 needs parts
Try cmsnl.com for parts. Just found loads of parts for my 82 superdream.Also davidsilverspares.co.uk and lings.co.uk. To use the latter two sites its better if you get the Honda part numbers from microfiche on cmsnl
Sep 03, 2009 | 1984 Honda CB 700 SC Nighthawk
BBQ gas leaking from regulator vent
tou will have to cut off the hose at the crimp point a drimel wors real well then buy a new regulator and hose and automotive hose clamps 3/16 is best
Aug 02, 2009 | Thermos Stainless Steel Gas Grill
Transmission shifts to second gear and stays there
Could Be that your TCM is losing power. I would check to see if the TCM is firmly attached to the passenger side fender wall. If not it could be losing the ground.
Nov 26, 2008 | 1989 Chrysler New Yorker
I have a Weber Gas Go-Anywhere Grill that I want to connect to a propane tap on my travel trailer. The problem is that the tap is low pressure, it's located after the regulator. the Go-Anywhere has a...
You can buy a "T" fitting that connects to the LP tank with a valve allowing you to pull LP gas off for your BBQ before the RV regulator
Most any RV shop can get them from NTP Distirbution
Jul 08, 2008 | Weber Gas Go-Anywhere Grill
Grilling Logo
163 people viewed this question
Top Arctic Products Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you an Arctic Products Grilling Expert? Answer questions, earn points and help others
