Konica 7033 error code F-51-4 - Office Equipment & Supplies
  • 1 more comment
  • stephen Vasquez
    stephen Vasquez Sep 18, 2008
    Prior to this had a bad paper jam in the registration area, cleaned this out. Had a lot of toner spilling out of the drum-to-frame that houses the Drum unit. once this was done re assembled the Drum unit assembly back into the Copier an attempted to re-initialize the copier, that is when it gone into a" F-51-4" any help appreciated I know it is a Developer failure, but is there a simulation I can run to a Reset to clear the code and see if the jam encouraged this problem?
  • stephen Vasquez
    stephen Vasquez Sep 19, 2008
    I understand in the age of "making profits" that you have the service for paying for what you know.....I have not corrected the problem of the Konica 7033 error code "F-51-4" I know it has to do with the Developer unit....is there a simulation key stroke to see what part is or has failed? Thanks, Regards,Steve
  • Anonymous Mar 25, 2009
    when i started my konica there is always that code f 51-4?can somebody help me?
My machine incounter problem F 51 - 4 KONICA 7040 ,pls help to solve this problem.I already done checking the drum cart.
Posted on Jun 07, 2011
This a fuser/heating section code.
Posted on Jun 10, 2013
How do i fix may konica 7033 displaying f52-1 error
F52-1 Cooling fan problem
or
F52 Main motor drive problem
Mar 27, 2015 | Konica Minolta Copier Toner 7033/7040...
Konica 7033 F-28-2
High Voltage issue have a tech come. Will have to have Old School knowledge you have a legacy Konica Machine.
Jun 12, 2014 | Konica Minolta Copier Toner 7033/7040...
ERROR CODE F-46-8 IN MY COPIER
I think you need to replace the front door interlock switch ( very common part ), and then take some time and adjust the bracket for a really good positve closure on the switch....leave the display panel off during this adjustment so you can get a good look at the switch closure. There is no factory adjustment on the bracket- you might have to bend part of the bracket to get a good closure. Open and close the front door a couple of times just to be sure and there you go. This front door interlock switch is a common failure on the 7033, 7040, and 7045's and will give you all kinds of crazy symptoms.
May 11, 2014 | Konica Minolta Copier Toner 7033/7040...
Konica 7040 trouble code 51-4
This 51-4 code is directly related to the write unit. It can either be a bad lazer index control board mounted externally to the side of the write unit or a bad M5 polygon motor. It is better to replace the whole write unit. Konica P# 26WA-6500.
On a side note, the 7020 write unit can be used in place of the 7022 write unit & is far less prone to failure then the 7022 write unit! 7020 write unit Konica P# 26NA-6500.
Nov 07, 2012 | Konica Minolta Copier Toner 7033/7040...
F-36-2
Jeruel:
The Error code F36 indicates an error in the fuser, (the part of the copier that fuses the toner into the paper. Unless you are a copier technician, I would leave this one alone and call for service. An improper repair to the fuser can cause a fire as the fuser works at 375+ degrees. (That's why the copy is hot when it comes out of the machine.
Aug 11, 2012 | Konica Minolta Copier Toner 7033/7040...
CODE F51_2
F-51-2, This error code appears in following copier models.Konica Minolta 7222/7228/7235/7135/7145This error code means "Fixing unit motor speed abnormality"Fixing unit drive motor is Motor Number 11.M11.Open the back cover and remove the main board and there you will find this motor.
Jan 04, 2012 | Konica Minolta Office Equipment & Supplies
I have a Konica 7033 copier with error code F-35-2
Access the 25 mode (power the machine ON, while pressing the 2 and 5 keys).
2. Press [1: Software SW].
3. Select software dipswitch 3-1 using the arrow keys.
4. Set the switch to OFF (0).
5. Press [Return] to end the setting.
6. Power the machine OFF/ON to exit the 25 mode.
good luck
May 04, 2009 | Office Equipment & Supplies
Error code f-51-6
this is your WRITE UNIT CODE.''''PRIT HEAD''''
you chould try to reseat all connectors ,and especially the write unit ,how handy are you?????
let me know
Oct 23, 2008 | Konica Minolta Di1610 Copier
1,141 people viewed this question
k24674
