Question about KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher
Lights flash Intermitten and tiemr counts backwards
The lights flash in sequence starting from the outside traveling inward. The timer counts backwards from 50 to 1. Then the sequence starts over. and continues over and over. I'm able to clear it when the time reaches 1 or 2. It stays off for a while (3-4 hours) then starts over. I can not clear the countdown until it reaches 1 or 2. After I clear it the dishwasher will work, but until then, no way. This happens with the door open or closed.
  • pieyowl Nov 08, 2008
    I have a dishwasher model:kud1021rbl1. serial :ft0407671
    the lights flash in the control panel and the washer does not run.
    Sergeant:
  • 409 Answers
it's either the touchpad or the control board that's malfuctioning. have you checked those yet?
Posted on Sep 23, 2008
Hi there I have an r410a and the timer is flashing continuously if I turn the unit off outside ie reset it then it comes on for a few minutes then shuts down can you help please
brand and model number would help here. Flashy lights usually mean error codes. count the flashes or if it is flashing fast or slowly.
Jan 04, 2015 | Heating & Cooling
Why is Utilitech wall timer making lights flash?
You have connected white and red wires together.
White wire must be connected to neutral or to ground to operate timer mechanism, display and switching.
Copy following links to see correct wiring for Utilitec timers.
http://waterheatertimer.org/How-to-wire-timers.html
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Jul 30, 2012 | Hardware & Accessories
Samsung DLP Flashing Lights
Make sure lamp is in correctly and as far as the color wheel: The ribbon cable from it to the DMD box only has connections on one side where it plugs in---it is possible to put it in backwards and set will detect wheel is not working..............
Jun 14, 2012 | Televison & Video
Samsung Flashing Lights
a new lamp is possible or even the ribbon cable from the wheel to the engine may be in backwards.
Lost instructions for photocell Type:ET321
Here is how it works. The push button repeats itself in following sequence (must plug in).
F 1 2 3 4 5 6 7 8 9 A d 1. 2. 3. 4. 5. 6. 7. 8. 9.
F: timer is off.
1 2 3 4 5 6 7 8 9: from dusk to dawn count down number of hours repeated every day. That's most useful to control outdoor lightings.
A: from dusk to dawn count down number of hours which is randomly selected by this timer. Which is usually for indoor use to turn lights on and off for number of hours. The randomly selected hours is a security feature so that lights on (on from dust, but off randomly) time shows no pattern to outsiders.
d: just on from dusk and off at dawn. It is also used to control outside lights but just a little wasteful in my opinion.
1. 2. 3. 4. 5. 6. 7. 8. 9.: meaning count down number of hours starts from the time when the button is pushed so that you can have a countdown timer at any time.
Dec 08, 2010 | Impact First Alert Outdoor Digital...
I am looking for a download link for the First Alert ET321 with photocell. I have misplaced the original package instructions and cannot find this material anywhere! Your assistance would be greatly...
Here is how it works. The push button repeats itself in following sequence (must plug in). F 1 2 3 4 5 6 7 8 9 A d 1. 2. 3. 4. 5. 6. 7. 8. 9.
F: timer is off. 1 2 3 4 5 6 7 8 9: from dusk to dawn count down number of hours repeated every day. That's most useful to control outdoor lightings. A: from dusk to dawn count down number of hours which is randomly selected by this timer. Which is usually for indoor use to turn lights on and off for number of hours. The randomly selected hours is a security feature so that lights on (I believe the on time is within the range of 1 hour from dusk set by the timer) and off (it is randomly set, you can see the display blinking showing the selected countdown hours) shows no pattern to outsiders. d: just on from dusk and off at dawn. It is also used to control outside lights but just a little wasteful in my opinion. 1. 2. 3. 4. 5. 6. 7. 8. 9.: meaning count down number of hours starts from the time when the button is pushed so that you can have a countdown timer at any time.
Oct 11, 2010 | Impact First Alert Outdoor Digital...
Instruction for first alert et321 timer
F: timer is off.
Dec 13, 2009 | First Alert Hardware & Accessories
Maytag 300 Litghts flash in sequence
Yes I think I was able to solve the problem. I'm not sure, but it appears to be working properly now. Since I was able to possibly solve the problem, if you want the answer, I would like to direct you to my Premium Assistance Plan. For $9.99 I will give you the answer, just like you offered me.
Sep 19, 2008 | Dishwashers
Maytag quiet series 300
Maytag Quiet Series 300. The lights flash in sequence starting from the outside traveling inward. The timer counts backwards from 50 to 1. Then the sequence starts over. and continues over and over. I'm able to clear it when the time reaches 1 or 2. It stays off for a while (3-4 hours) then starts over. I can not clear the countdown until it reaches 1 or 2. After I clear it the dishwasher will work, but until then, no way. This happens with the door open or closed.
Sep 15, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
All the lights are flashing on Maytag Quiet Series 300
Try pressing heated wash, heated dry, then heated wash, heated dry. It should reset it. Also try pressing and holding the cancel button for 5 seconds to see if that works if the other doesnt.
Sep 23, 2007 | Maytag 24 in. MDB5651A Built-in Dishwasher
KitchenAid 24 in. KUDI02IRBS Stainless Steel Built-in Dishwasher Logo
165 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
