Question about Samsung ML-2551N Laser Printer
Samsung ml-2551N - Keeps flashing and a noise
Hi All have a samsung ml-2551N - on start up it just sits and the LCD screen flashes it also make a noise (like a soft clunk) - can be a minute or hours - then stats working properly
Any idea's on what it could be only just started doing it
john
  • jonno112 Dec 18, 2008
    I have a couple of printers all the same brand that do this. I took the print cartridge out but i couldn't find the drum.
    Any ideas on how to fix this issue.
    Master:
    Sergeant:
  • 449 Answers
Hi!!!!
ok try to remove the drum first
and put it back properly!!!!
Posted on Sep 18, 2008
Samsung ml 2551 Engine hsync error
Dear The problem is with LSU (laser scanning unit) unit. If you are experience open the lsu clean all optical path and test. This may operate .Replace the LSU unit.Thanks.
Oct 13, 2014 | Samsung ML-2551N Laser Printer
My samsung 2551n printer display keeps blinking and makes sound, tried to reset it and remove ink cartridge but no use.
This is a somewhat common problem with this printer. You are going to have to have the power supply repaired. The power supply in your printer sits right under the fusing unit and thus gets hot. Over time this causes the electrolytic capacitors in the power supply to swell and go bad. This causes the power to cycle on/off as well as other issues. You will need to order a new power supply board or have your existing one repaired. If you have it repaired or repair it yourself you will need to replace all the capacitors. There are about 5 or 6 of them all grouped together.
Good Luck and Thank You for using Fixya.
WheatlandServices
Dec 28, 2010 | Samsung ML-2551N Laser Printer
Samsung printer ml-2551 internal error
Make a service request here or contact Samsung here
Mar 27, 2009 | Samsung ML-2551N Laser Printer
Samsung ML-2000
from where i can download printer driver for samsung ml-2000 series laser printer
Nov 06, 2008 | Samsung ML-2551N Laser Printer
Constant paper jam
Replace all electrolytic capacitors in power supply section on mainboard. caused by poor quality lower voltage caps being used in powersupply. Problem will reoccur every 2 to 3 years if 105oC caps are not used. If mainboard is replaced with new mainboard problem will reoccur within same timeframe. Fix old mainboard using higher voltage and higher temp caps and problem will be gone for good.
Apr 04, 2008 | Samsung ML-2551N Laser Printer
Printer installation
If you can not load from the CD try going to the this website and download the drivers to your C: Drive. This should work.
http://www.dirfile.com/lexmark_printer_optra_color_1200.htm
Feb 18, 2008 | Samsung ML-2551N Laser Printer
Ml 2551n printer
contact problem between toner & printer. clean contact point in printer to solve this problem
Jan 15, 2008 | Samsung ML-2551N Laser Printer
Maintenance list + common problems
The most common problems come from uneducated users. Please make sure you read and understand the user's manual, it provides even troubleshooting guides. As with all laser printers, you will eventually need to replace the following: 1. On paper trays and bypass: pickup rollers and separation pads. 2. On printer: fuser unit and transfer roller.
May 18, 2007 | Samsung ML-2551N Laser Printer
Samsung ML-2551N Laser Printer Logo
351 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
