Question about Mitsubishi VS-45603 45" Rear Projection Television
Cleanng the projection mirror
My first projection model had some screws which held the bezel and front on the TV. I need to clean my projection TV but cannot figure out how to remove the front protection screen. This usnit is about 6 years old and I used to clean my old one yearly. By keeping it clean the brightness and definition remains great
  • 108 Answers
Remove the speaker grill, you will see the screws holding the front screen, remove the screws and the connectors going to it and slide the screen up and off.
Posted on Jan 09, 2009
How do i remove the screen to my Mitsubishi wd-62638
For the model indicated (WD-62638) the entire screen unit needs to be removed.
Some models had two mirrors--the usual large one in back and a tiny one in the bottom front.
1. Locate and remove front plate below screen (where you may access the lamp as most of these are taken out from front)
2. Remove all the screws ON THE BACK OF THE SET around the top and both sides.
3. Remove a plate behind the removed lower front grill and there you should find a set of wires that go to front keyboard.
4. With that done look carefully at either front side below the screen unit---one screw on either side---do not remove but just back them out.
5. 2 person job---the entire screen unit lifts up and out.
6. DO NOT try to clean the large mirror---if touched with hand or your hair it will smudge and it will show in the picture.
7. If the little mirror is there at the bottom---it can be cleaned with glass cleaner---
8. Insert the screen unit back with the two front lower screws supporting it (have someone hold it in place until you line up and install all all the rear and then the 2 front screws.
Let me know if you have questions.
Mar 10, 2012 | Mitsubishi WD62628 62" Projection HDTV
I need to replce the drivers side mirror. Just seeking instructions on how to.
Remove front door handle bezel screw cover Remove inside handle bezel screw Remove inside handle bezel Lift upward on the rear of the front door inside handle bezel Disconnect electrical connector Remove handle screw cover
Remove handle screw Remove door trim panel upper screw Remove door trim panel lower screw Remove door trim panel (pull the door trim panel outward to release the pin-type retainers)Remove front door sail panel
Disconnect mirror electrical connector Remove 3 exterior mirror nuts and exterior mirror
Mar 07, 2011 | 2009 Ford Fusion
Have a very old rca projection tv. had in basement than our tv upstairs was hit by the wii- we brought this one upstairs it turns on great but it is very dark. tried to change settings but still remains...
It is either the projection lenses are very dusty or are getting weak. I would clean the projection lenses and try it. It has been a while, so bear with me. The bottom speaker covers should should either have some screws around the edges or just pop off (most are the pop-off kind). Under there, there might be some screws that hold the bezel (that frame around the screen). Remove the screws and remove the bezel. You might have to slide the bezel up to pull it (try bumping up on the lower corners with the heel of your hand).The screen should come off with the bezel (just set it aside and be careful with it). Now the 3 projection lenses(red, blue, and green) and mirror are both exposed. Wipe the dust off the lenses with a damp cloth and follow with a dry cloth. If the big mirror is glass, clean it with a damp cloth (maybe a little glass cleaner) and dry with a clean cloth If it is the foil type mirror, clean it real gently with a damp cloth. The big white plastic lens at the front is cleanable with a clean damp cloth. But unless there is a smoker in the house, I wouldn't mess with it. If you do clean it, be sure to use a circular motion with the pattern on the lens...it scratches easily. Then snap the bezel/lens assembly back on and reassemble the front pieces. It has been a while since I have cleaned one of these. There may be a few differences in getting into the projection area depending on the models. Since the projection tubes are aimed up , the dust really builds up in them.
Hope this helps and good luck with it.
Jan 21, 2011 | RCA P52926 52" Rear Projection Television
I have an older Pioneer rear projection TV that has never been cleaned, model SD-P50A5-K. Can you give me the basic cleaning instructions and the do nots for this TV.
Unplug the TV for safety - even unplugged, there is enough energy stored in the electronics to be very dangerous.
The bottom speaker grill snaps straight off. There are a row of screws under the screen around the screen bezel that must be removed. The bottom of the screen will become loose and the whole screen assembly slides up, like opening a window (there is a bracket under the bezel at the top of the screen that the bezel slides off of.) My screen took a lot of effort to disengage the top bracket - careful not to break anything!!!
Once the screen is off, put it safely aside. There is a mirror in the back that can be cleaned with a damp cloth (not dripping wet!). Remove a little dust at a time and keep washing the cloth out between cleanings. Be very gentle. If you push on the mirror it could break If its never been cleaned there is sure to be a lot of crud.
Below the mirror are three colored lenses. CAREFULLY use a clean lightly damp cloth to wipe each one. Don't mess with any of the adjustment screws and levers on the lenses.
Before putting the screen back on the TV, carefully clean it with a damp cloth too. Slide the screen back over the top bracket, put the screws back in, and pop the speaker grill back on.
Its a good idea to readjust you convergence too.
When I cleaned my set, I was amazed at how bright and sharp the picture was!
Be Careful!
Jan 07, 2011 | Pioneer SD-P50A5-K 50" Rear Projection...
I need to clean mirror
Most rear projection sets the screen will pop off the front. Usually a couple of hidden catches. Get another person for this.
Once off you can clean the mirror but not the inside of the screen.
Unplug tv first
Mar 13, 2009 | Toshiba 43A10 43" Rear Projection...
How do you clean the mirror?
It's been a while since I faced one of these, but I believe the bezel around the screen pulls off to expose the screen mounting screws. As I recall it is held on by snap fasteners. It's also possible there is a snap-on trim strip between the screen bottom edge and the speaker grille. If that's the case, remove that to expose screws securing the bottom of the screen. Once they're out the screen swings up and off. Zenith used a couple of methods on different models.
Nov 27, 2008 | Zenith IQC60H94W 60" Rear Projection...
Pioneer SD-P5185-K
pull off speaker grill on fron( held on by velcro )t. then look for screws beneath the screen. remove screws and pull bottom of screen bezel out and lift up. remove screen and clean lenses and mirror
Craig www.classtorations.com
May 30, 2008 | Proscan PS32500 32" TV
Sony Grand WEGA KDF-50WE655 Parts Numbers Needed
1-788-159-21
1-788-162-21
A-1087-018-A
here are your part numbers for the 2 screens and mirror
Oct 12, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
I need to replace the mirror, it broke during transport
Take the back bezel off. It should have many screws around it. then once open you should see the back of the mirror. Carefully take the screws out of the mirror, you may have to do some modifing with the new mirror if it does not come prefabed.
Aug 24, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Projection tv
Yes you can safely clean tv, just remove front speaker panel and you should see screws holding up front prot. screen. Becareful not to snap screws. You can take screen out and there is a mirror that you can clean and 3 lenses.
Apr 01, 2007 | Hitachi 50UX57B 50" Rear Projection...
Televison & Video Logo
83 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
