The power light is blinking and the tv wont turn on
I have two 46" Sharp Aquos tvs,so i know this tv model well.Tv have Power and OPC LED lights flashes?Yes.Tries tv unplug,replug it back like about an hour later.The tv should be working again.This problems happen to Sharp tv alots,later on,should it happen again,just tries push the power switch on the remote again and wait the backlight will light up and tv will work again,some it will go back to Power and OPC LED lights flashes again,just push power switch again and wait,sometimes,u have to do this three or four tines to make the tv Tuner signal board to take to make the tv to work again.If u have to pushes power switches 10 or 11 times and wait and Power and OPC LED flashes lights again,it time to replace the tv Tuner signal board,that the board,where that take the tv incomming broadcasting signal cable plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
same here, my tv wont turn on and both the power and opc light are lit.
Same problem, but no flashing light.
Sharp 37" LC-C3242 U shuts itself off and two green buttons start blinking. they blink 3 times and then a slight pause and 3 more flashing lights and a pause. I can uplug the power source and plug it back in and sometimes the tv will come on but after maybe 10 minutes it shuts off again.. It is not a cable problem, I had them out to check out their cable. Technicial said it was something in the tv .
Its blinking continously
