Question about Philips Magnavox 20MT133S 20" TV
Top picture overscan issue, again ...
I posted my problem on 10Sep08:
http://www.fixya.com/support/t1029551-top_1_picture_being_overscanned_into
Dan responded, as did I, and I have heard nothing back from Dan on how should actually proceed.
  • 2,071 Answers
Overscanned in the top of the screen,is the symptom defected capacitor in the vertical section. Filter capacitor 100uf or microfarad or it is better you replaced all capacitor there and reworks or resolder all solder joint there in vertical section.So it will works better again..
Regards,.
VOTIT
Posted on Sep 22, 2008
Repaired the convergence and now the image quality is good but the TV seems to be over projecting the screen. The top, bottom and sides of the image are cut off slightly. is there a way to adjust?
Hey! its me again. I think what your experiencing is called overscan. This website might help but if not just google how to fix overscan on a projection tv.
http://www.cnet.com/news/overscan-youre-not-seeing-the-whole-picture-on-your-tv/
May 24, 2016 | Televison & Video
How do I enter the service menu on an Emerson EWF2004 CRT Television? (Pictures of the OVERSCAN ISSUE will be provided if needed.)
Older sets had vertical and horizontal size controls. If you have the horizontal size control, turning it counterclockwise will reduce the size of the picture horizontally and reduce the overscan.
Feb 25, 2016 | Emerson EWF2004 20" TV
Screen zoomed in zoom out
Go to Display settings and make sure Auto Detect is off.
Then if it's off or after reset go to HDTV settings and select 1920x1080, if there is no picture wait till it comes back and select 1360x768. Just keep going down till you find one that works.
It's a bit of a bummer some TV's out there have no option to disable the overscan. Also a bigger shame that a lot of TV's are sold as 1080p yet only have a 1366x768 native resolution.
However this solution should fix overscan issues if it can't be done through the TV.
- Answer Found on http://forums.xbox.com posted by sn1p3t sk33t
Apr 08, 2014 | Hannspree Computers & Internet
Can you adjust pincushion, overscan on Sony kdf46E3000?
Steve, I am not an expert on this model but I can provide a link to the manual that may be helpful. It is a PDF format and the pages that refer to your issue are 32-36. I hope this assists you in resolving your issue. Thanks for using Fix Ya.
http://www.retrevo.com/d/ds/progress?doc=422217ceb653da53024f151f0e38f2ce&rk=0.4228925186481609
May 15, 2012 | Sony Bravia Kdf-46e3000 46-inch 1080p 3lcd...
AOC monitor 2436vh does not fill the screen using the HDMI connector. There is a 1 inch black border around the window. Controls to stretch the display are locked out (not accessible) when using that...
The "Best Solution" fixes a problem that is unrelated to the original poster. anononline19's solution is to fix the entire OSD being locked (displays OSD Locked when the menu button is pressed).
Original poster's problem can be fixed by changing your graphics card's "overscan" settings.
Overscan on ATI cards:
http://nigelt.wordpress.com/2009/09/21/overscan-options-in-catalyst-9-9-on-windows-7/
Overscan on nVidia cards is currently not supported.
Oct 16, 2010 | AOC Computers & Internet
HEy Dan, this ones for you http://www.fixya.com/support/t1029551-top_1_picture_being_overscanned_into
Thanks for the pointer. This was was posted to me directly, but I was called offsite to a majopr production problem. I should have this resolved by tomorrow.
Thanks again for the pointer.
Dan
Sep 21, 2008 | Home
Horizontal white lines across top of TV screen
Hi I had the same problem. Broken white lines across the top of the screen. This is called overscan. You need to go into the Setup menu, other settings. 16:9 overscan needs to be on. Hope this helps.It solved our problem.
Sep 15, 2008 | Panasonic CT-2006S 20" TV
Top ~1¼" of the picture being overscanned into top ~½"
a missing power supply voltage, defective vertical output IC, or a component associated with it is likely bad. A bad connection or blown fusable resistor may be the cause of a missing power supply voltage
Thanks for using Fixya!
tc
Sep 19, 2008 | Philips Magnavox 20MT133S 20" TV
Overscan
do you mean the top of the picture is cutt off? if so then go into tv menu and set screen size to 16:9 not auto. if that doesnt work then try settings on ps3 hopefully that works
Jul 23, 2008 | Toshiba 55H70 55" Rear Projection...
Top of picture cut off
Sounds like a problem on the deflection/power board....You can try replacing the vertical I/C and caps.......Or go for a new board.
Jan 01, 2008 | Pioneer PRO-710HD 64" Rear Projection...
Philips Magnavox 20MT133S 20" TV Logo
131 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
