Question about GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker xl1800
My spacemaker appears to be running when the door opens. When the door is closed and no cook time selected it's fine. However when you open the door the fan begins to run. It has never done this in the past and is there anyway to tell if the micro way is actually active or the fan is just running.
Thanks
  • 706 Answers
A simple test is to place a piece of bread in the microwave ( it heats up very fast) and then if your microwave was actually ON and generating RF, the bread would get hot very fast.. If it remains cool then only the fan is on. It appears that you may have a faulty door switch thou because once you open the door, your microwave should be off..
Are you sure the VENT is not on? That blower will operate regardless of the door open or closed so you must switch it OFF.
Posted on Sep 19, 2008
GE SPACEMAKER XL1800 IS NOT HEATING FOOD - GIVING "SENSOR ERROR" ON DISPLAY. I am a handy guy capapble of fixing if you can help me out w/the part I need
hello,
if you have a sensor, it means, the door was opened before steam could be detected. Do not open the door until stream is sensed and time is shown counting down on the display.
Steam was not detected in the maximum amount of time. Use Time Cook to heat for more time.The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
thanks.
Jun 16, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Ge spacemaker xl1800
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101][]=--=
May 02, 2010 | GE XL1800 1100 Watts Microwave Oven
Not heating up anything
Tat would be a magnetron problem. The magnetron is what provides the heat
Apr 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker 1400 acts like everything works but does not heat.
Hello :
This happens because of a bad door switch . The plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door .
Check also the turntable . It could be out of it's right place .
WARNING :
1:Don't slam your microwave door because this may cause the fuse to blow and this is the reason of bad door switch problem .
2: A microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck
Apr 09, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE SPACEMAKER XL1800 MODEL: JVM1860BF001
MAGNETRON, 99% of the time with your complaint
Nov 20, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My GE SPACEMAKER XL1800 APPEARS TO BE RUNNING FINE,HOWEVER NOT HEATING
I have posted this answer many times here at Fixya but will do it again for you. You may want to review some of those comments for additional details.
Check the door switches .
Do you open the door when the oven is running? If you do, the contacts in the little switch arc and burn. As they burn, eventually, they will not close. The circuit is then not complete and the oven thinks the door is open. When this happens, the oven will not turn on the magnatron. When this happens, no heat.
Do not touch the silver can in the back, oven plugged in or not. It potentially retains lethal levels of electricity. Definitely unplug before you remove the cover. Screws on the back and probably on the sides at the bottom. Make sure you reinstrall the cover properly and use all the screws.
I hope you find this resonse will help you solve your problem
a
Oct 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker xl1800 - Funny noise, flickering light
very possible your magnatron is faulty. Disconnect 2 transformer wires and make sure they dont short. try the program again. if no noise, replace magnatron:capacitor and HV diode Please i strongly suggest an electrician help you as it is truely dangerous in there. .
Sep 15, 2009 | Microwave Ovens
When opening the door a venting sound immediately starts up.
The charcoal filter needs to be changed every 6-12 months, or sooner if it gets clogged.
You can download GE owner's manuals and installation instructions here.
You can find helpful exploded view diagrams and order parts (including charcoal filters) by entering your full model number from the tag on the oven here.
Feb 11, 2009 | GE XL1800 1100 Watts Microwave Oven
Spacemaker XL1800 runs but doesn't heat.
I think you should check the fuse first that runs the magnatron if the fuse is good that means the magnatron is bad! but if its only the fuse then you save time and money!
Jan 21, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Micro stopped working
Try looking at the microswitches behind the door.
Apr 05, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
963 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
