Question about Dell Computers & Internet
Dell GX60 CD-ROM will not copy
When I try to copy documents to my CD-rom I keep getting a message telling me to insert a disc into Drive D, event hough thre is already one in the drive.
The CD-rom is fine at detecting software.
  • 40 Answers
Hi, this issue may occur if the firmware is not installed. Please Click on start>>> run >>> type devmgmt.msc and hit enter.
Look under DVD drive. You should find the name of the driver. Search for available firmware at support.dell.com by either entering the service tag of the computer or by product type. That should make it work.
If not, try in safe mode. If that too does not work, call Dell tech and mention the steps and ask for a replacement. YOu will get it in no time if system is under warranty
Please rate if useful
Posted on Sep 19, 2008
We have a dell hard drive and my daughter scanned a paper onto MS word document and now we cannot get our computer to work as it keeps saying to insert CD Rom set up in order to open windows. We cannot...
it seems that your windows os has got corrupt, boot your notebook, and keep on pressing f8 key then select the last known good configuration then check........thanks
Aug 06, 2011 | Dell Inspiron 6000 Notebook
Keep getting "Target Overflow" error message, even
you may have a bad ROM. If you have a multiple target unit, switch the source from the ROM to one of writers and try copying that way, if it copies then it confirms that the ROM is defective.
If you have a Single target unit, check your master disc under disc info, depending on which controller you have it should be under utility or disc info. Once in disc info it should tell you the size of your master disc, for DVD-R it should be under 4488MB, for DVD+R it should be under 4482MB. Then double check the master in the PC just to confirm.
Jun 12, 2011 | EZ Dupe EZDupe Two Target DVD Duplicator...
My dell latitude c400 will not boot from external cd rom or the brand new hard drive i need to put windows xp on it but it will not boot from anything can you helpnow i have found i have no drivers...
try other known good windows installer. if it boot, then the problem is in xp installer, if it not. try other external cd-rom drive. also be sure the disc rom drive are dvd rom drive because a cd rom drive cannot read dvd disc but a dvd rom drive can read cd rom disc installer
Feb 15, 2011 | Dell Latitude C400 Notebook
Boot
what disc your using to boot?
just leave bootable disc in the dvd drive such as OS and drivers dell disc.
power off then on the laptop keep tap on F12 then select onboard CD/DVD ROM then press enter then tap space bar.
if still not reading any disc then have you dvd drive replace.
Dec 06, 2009 | Dell Computers & Internet
I am trying to install windows service pack 1. I keep getting an error code: 0x00F0826. Can you tell me what this means and how to fix it? I am running windows vista basic. 32-bit. Thanks.
if there error appeared while windows copying files then disc OS or the DVD ROM might be faulty. Try to test first the ODD if it is faulty. Use the drivers and utilities cd from dell to test the DVD ROM. If DVD ROM reads fine the drivers disc then try the OS disc to a different computer if it can load vista files. if not the OS disc has the problem. If no issues with OS disc and DVD Rom then it might be the HDD.
Oct 22, 2009 | Dell Inspiron 1420 Laptop
Cd rom not working and computer keep on freezing
try with other disk if all disk getting same issue then you have to first clean your cdrom or dvdrom lense.
For that you need disk cleaner disk pur chase it and put in rom then play it.
then it clean lense.then check.
if still face problem then you need to repair or replaced lense if it in warrenty replace it.
Jul 29, 2009 | Dell Dimension 5150 (DIM515MIN) PC Desktop
When i put a disk in the cd rom keep getting message please insert disk
Try known good disk. Other than that the unit has probably failed. Make sure disks can be read on a buddys computer?
Jul 28, 2009 | Dell XPS 400 PC Desktop
When i try to copy dvd it keeps telling me to insert blank disc even though one is in there i can burn cds but not dvd it tells me to put in writeable disk and ive put in dvdr-w and dvd-r and still it...
Go to the device manager to insure your optical drive is in fact a DVD/RW. You should also be able to tell by looking at the front of the drive and see what it says. If it says CD Writable or DVD Rom, you cannot do it. Kind of sounds like you have a CD/RW-DVD Rom combination drive, which does not allow the burning of DVD's.
Let me know, OK.
Mar 15, 2009 | Dell Inspiron 1501 Notebook
Do not recognize any cd/dvd in dell vostro 1510 bios A13
i have dell vostro 1510 labtop < bought from SA 2 y ago, dvd rom not work, always rejected when inserted, also bluetooth and toutch pad not recognized, i use windows 7
find me a solution
Jan 24, 2009 | Dell DVD-rom DVD Drive
Windows could not start
you can use any xp disk.re install fresh copy not repair.im sure you know someone who could lend you a copy for couple of hours
Feb 20, 2008 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Computers & Internet Logo
171 people viewed this question
Alun Cox
