The TV has a double vision thing going on. Kinda like its in 3D. The focus or alinment is off.
  • Anonymous Dec 31, 2008
    I turned my TV on and it looks like I have 3D. I'm not sure what to do.
    Problem Solver:
  • 5 Answers
This happened with my old tv (but it was liek a holographic picture behind the actualy program) it ended up being the normal tv channels, to solve this i just put my normal tv to like channel 6 (nothing waso n that channel) then usedm y cable as normal andi t was fine
Posted on Sep 18, 2008
We recently moved the tv and now when we turn it on it has double vision. It kinda looks like a 3d movie. What could be the issue? Is it worth fixing?
If tv picture was fine before moved then check dry/ cold solder joints/ connections on convergence output ICs and nearby circuit area.
Local tv repairman will resolder loose/ dry solder connections to solve double vision picture problem.
TV worth fixing if picture is good.
Thanks.
Feb 18, 2011 | Sony KP-57WV700 57" Rear Projection HDTV
Everything looks like its in 3D vision. Im pretty sure somthing isnt alined right so i was wondering what i can do to fix it.
Replace convergence output ICs in your tv to fix this 3D look picture, it happens due to convergence output chips failure.
Local tv repairman will fix it for you if you have no prior experience of part replacement in tv circuit board with proper tools.
Sep 26, 2010 | Panasonic PT-53WX53 53" Rear Projection...
Ai'm seeing 3d vision and the edges are curving
THE GUNS NEED RE-ALINEMENT {RED.BLUE AND GREEN LIGHTS}AND ALSO A PART WHICH ONLY COST 50 CENTS,BUT YOU WILL NEED A TECH.THIS HAS HAPPENED TO ME AND I HAVE HAD 3 IN MY TIME.
Apr 24, 2010 | RCA HD52W58 52" TV
My rca projection tv has blue and green images like a 3D picture would without your 3D glasses, a double vision image and no other colors
sounds like the sensors are out of focus and your red sensor isnt turning on. look in the back of the tv for a master reset button or in your menu screen some sort of "Flash focus" or "convergence". They will realign the 3 sensors.
Dec 27, 2009 | RCA HD52W56 52" Rear Projection HDTV
Double vision in red and green
Its failure of convergence ICs and will be replaced.
Convergence ICs are mounted on silver heat-sink on D board of TV
Let me know exact model number to help you with more technical info.
Mar 21, 2009 | Sony KP-57WS500 57" Rear Projection...
Flash focus
http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
Go to this Blog. It "should " solve the problem.
Really, Really simple, do it your self solution !!
Instructions and pictures included :D
Ken , the poster of that Blog writes........
"The problem is with the convergence via the voltage on the
color ray gun tubes that get out of adjustment.
They are also known as retrace lines."............
This blog covers many makes and models with many
issues solved, just with that one solution
Give it a try, it's FREE and SIMPLE :D
Had very similar problem, that blog helped me save
my TV and hundred's of $$$$ in repair costs ! :D
Hope the blog helps you also :)
Jean
Feb 26, 2009 | Sony Televison & Video
I am seeing double vision on my television.
I do not know your TV's model number, if your TV is a 3D television, please turn the 3D function off in the system menu.
Jul 01, 2017 | Sony Televison & Video
Convergence perfect focus not working and double vision
The problem you have is the 2 STK - 392 convergence integrated circuits need replacing the cost in the UK is about £150.
SUPER8
Nov 26, 2008 | Televison & Video
Touch focus error will not correct
If the touch focus isnt working and the picture has a 3D look you will need to change the conversion ICs. This is a straight forward repair just unsolder the old and solder in the new. You will need to replace both. They are located on a large aluminum heatsink and they will have STK numbers stamped on them they are quite large easy to find. The numbers will be something like STK392-110 or simallar. Let me know if you need anymore info.
Mar 23, 2008 | Toshiba 53H71 53 in. Rear Projection...
53UDX10B 53 in. Rear Projection "3D vision"
the convergence IC`s and associated resistors have to be replaced, do not repeatedly push magic focus or the alignment after the parts change out will take longer which of course means higher repair bill, good luck
Nov 10, 2007 | Hitachi 53SDX01B 53" Rear Projection...
Open Questions:
I have horizontal white lines across the display of my LCD Tv, I've included more info in the details section below I have an Insignia model# NS-46L780A12 LCD TV MFG date July, 2011 , recently the display has been acting very strangely because the issue comes and goes consistently dependent to whether or not there's caption writing on the screen - examples being programming information , channel , time etc.....these info blocks are each in their own particular areas on the display , where this gets odd is when your watching live TV ,these info blocks are always filled in with whichever program that's on, the best description of this issue is from these individual blocks of written captions on the screen example - from the top , there will be a continuous vertical row of horizontal lines starting directly underneath said caption all the way to the bottom , this will happen consistently wherever there happens to be writing on the screens display, so you get multiple rows of these horizontal lines from top to bottom of the display and they'll stay there for the entire time you watch your show , some shows have more ,some less ,depending on the writing for that show , this is all on cable TV / live TV I guess you can call it , and when I use my Fire TV stick with certain apps , I'll get no vertical rows horizontal white lines on the display with the exception that I push the mute button or change the level of the volume and the lines start to want to show up and do partially just for a little while ,but almost as soon as the info on the screen disappears as far as mute/ no mute or the volume level , the vertical rows of horizontal lines go away , I should also say that in either case Fire TV stick or cable , these vertical rows of horizontal lines take a little time to develope all the way from where the caption lettering begin and same process for when they go away , it's not instant in either case , it can take up a couple of minutes for either process to happen , one other oddity I guess you could say , in watching a cable tv program where you may get let's say 5 vertical rows of horizontal lines top to bottom at the beginning of the process , if you happen to try to watch that show ,those individual vertical rows of horizontal lines of varying widths will eventually connect with each other horizontally across the display
Feb 18, 2018 | Insignia Televison & Video
Televison & Video Logo
102 people viewed this question
Top Televison & Video Experts
