Question about Comfort-Aire BHD-301 Dehumidifier
Compressor will not kick on. Installed new circuit board and the compressor still won't work. The compressor does work when it is jumped.
  • Bob2691 Sep 19, 2008
    That would be great if you would. Thank you.
  • 1,543 Answers
If the fan runs, the only thing left in your case looks like the defrost control. Sorry I don't have my user ID and password for their service site here at home. I can look up a part number for you tomorrow if you'd like.
Posted on Sep 19, 2008
  • Carl Schulzetenberg
    Carl Schulzetenberg Sep 19, 2008
    Companies put a lot of different names on some of the products they make. This one is actually manufactured by LG. The defrost control (they call it a sensor) is part # 6877A30013L.
    Hope you can get this one "FixYa!" ed. Good luck.
Compressor not working
ck your setting on control panel sometimes they get changed , also ck that your catch bucket is fully installed sensors are there that keep it from running if it does not have a bucket installed
Feb 05, 2014 | Kenmore 54501 Dehumidifier
Hi... my dehumidifier compressor will not turn on, the fan runs fine and the time 2 hr/4hr cycles work, but the compressor wont kick on, the filter is clean and the unit is no more than 2 yrs old. Any...
Sounds like the compressor is inoperative. Most, if not all new units have no means of recharging the freon if it leaks out. If the coils are not cooling, the compressor is not operating and the unit will not dehumidify.
Jun 26, 2011 | LG LD65EL Dehumidifier
I have a GE AHH50LMG1 dehumidifier. It is less than 2 years old. When I turn it on, it displays 20% RH. The fan runs but the compressor does not kick in. I assume that is because it thinks the humidity...
It could be just the sensor, but not likely... many times it is the circuit board that goes bad, making the repair almost prohibitive.. as the circuit board, if you can find one, is often half or more the cost of a new unit...
But you are correct... if the unit thinks the humidity is 20% then it will not bring on the compressor...that is what is happening...
heatman101
Jun 25, 2011 | Haier HD656E Dehumidifier
When compressor cycles on the circuit breaker kicks off
Your compressor has a direct short there is nothing that can be done just replace dehumidifier. If you replace compressor it will exceed cost of new unit. If this helps you please rate me and do a testimonial.
May 21, 2011 | Dehumidifiers
The Kenmore 106.955501 dehumidifier works well when first started, coils get cold quickly, fan runs, air moves well. after 1 hr when the compressor needs to kick back on, the lights on that circuit dim and...
The compressor will not start when it is hot or it is no longer bleeding the pressure off fast enough on the high side of the refrigeration system and it cannot start under the load. The start relay and capacitor could also be bad...that would give the same symptoms...
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
May 01, 2010 | Kenmore 54501 Dehumidifier
Dehumidifer runs for about 45sec to 1minute and then shuts off. wqhat would be making this happen
If it does that consistently, then it's likely that the compressor is overheating and shutting down. (It has a thermal overload circuit to prevent a potential fire). Another cause could be a malfunction of the control circuit board which runs all functions of the unit. To check for possible compressor problem, unplug the unit, remove the housing to expose the compressor, plug it back in and power it up. When it shuts down, feel the compressor. It should be warm to the touch, but definitely not so hot that it singes your fingers.
If you find that the compressor is just normal warm, then the control circuit board is shot and needs to be replaced. Check with the merchant or manufacturer for availability & cost. If prohibitive, you're better off simply replacing that unit with a new one.
Jun 10, 2009 | Goldstar DH304 Dehumidifier
Dehumidifier won't run
After all that testing you have diagnosed the problem. It is the main circuit board. So there is not reason to do any more test. I would just get a new control board and off you go
Apr 21, 2009 | Haier HDN305 Dehumidifier
Problem
I was able to find a part list on the internet and see a picture,description of the part, the part number, price, and availablity.
Sep 13, 2008 | Comfort-Aire BHD-301 Dehumidifier
DH30 Dehumidifier Compressor Does not Operate
I just picked one up at a tag sale, seller said it worked sometimes. Seems to have the same problem as yours. I took the time to tweak all of the connections and then re-soldered the control board with no luck. I finally disconnected the humidity control and it worked fine. By disconnecting the humidity control the unit defaults to it's highest setting and you have to unplug the unit to turn it off. Conclusion so far is that the humidity control rheostat is bad.
Note: Now while running the fan runs continuously and the compressor cycles on and off every 10 to 15 minutes. This may to be normal since the unit appears to be doing its job and I'm not sure how it is supposed to run since a purchased it broken.
Aug 05, 2007 | LG DH30 GoldStar Dehumidifier
Comfort-Aire BHD-301 Dehumidifier Logo
449 people viewed this question
Top Comfort-Aire Dehumidifiers Experts
Mike Squire
Bill Long
Michael Youngman
Michael Youngman
Are you a Comfort-Aire Dehumidifier Expert? Answer questions, earn points and help others
