Question about Video Game Consoles & Games
I am trying to set up my x box live and i am not able to connect because it says my ip address is failed what to do?
  • 31 Answers
Call 1-8004myxbox
Posted on Sep 18, 2008
Failed Ip adress for xbox live
First i want to know how is your xbox 360 connected to the internet? For example ( Modem Connection?, Router Connection?, Or Wireless Connection?
Here are some steps that you need to try:
1. Turn off your cosole wait for 20 seconds and then turn it back on, then test your xbox live connection
2. Go to your network settings
3. Select restore to factory defaults and test your xbox live connection
Apr 03, 2009 | Microsoft Xbox 360 Console
Xbox live dont work please help
the reason for this part to fail differs along with the difference of the type of connection you are using to connect your Xbox 360 console as follows:
a. Direct connection to modem:
1. Make sure first no other devices connected to the modem at the same time as some modems has an Ethernet port along with a USB port so, you might think you can use both at the same time & connect the PC through USB with the console through Ethernet & that's incorrect so, we need to disconnect the PC first.
2. Turn the modem off then turn it back on after couple of seconds (by turning the modem off I mean to unplug it from the wall outlet even if you have a power button for it), then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Restore to Factory Defaults" and when it ask you to Apply Settings select "Test Xbox Live". 3. If it's still not working we need to get the Physical Address of your PC to put it on the dashboard of your Xbox 360 console as some cable companies are preventing any unknown MAC Addresses from connecting, to get the Physical Address of you PC connect the PC only to the modem then follow these steps here, the physical address will look like this 00-E0-98-C1-88-C2.
4. Go on the dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Edit Settings” then “Additional Settings” tab then select “Advanced settings” & put the Physical Address of your PC without the dashes on the “Alternate MAC Address” part and select "Done", when it asks you to Apply Settings choose “Test Xbox Live”.
b. Wired connection to router:
1. Go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Restore To Factory Defaults", when it ask you to apply settings select "Test Xbox Live".
2. Turn the router off then turn it back on after couple of seconds, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
c. Wireless connection to router:
2. Go on the Dashboard of your Xbox 360 console to the "system" area then "Network Settings" then "Edit Settings" then select your wireless settings part down there "Wireless Mode, Network Name,..." the console will automatically then search for your wireless network and when it find it and you select it, it will ask you to enter your wireless key which is called WEP or WPA key - you can find it written on your wireless router or then you need to contact your ISP (Internet Service Provider) to get it from them - when it ask you to apply settings select "Test Xbox Live".
3. Just a kind of higher security that some router may use than the WEP & WPA key, you have also to accept the Xbox 360 connection to your wireless network on the router settings, you have to access to your router settings as mentioned before to check on the wireless security part whether your router apply a MAC filtering option, which is an option that blocks any unknown MAC address (the ID of any device) from accessing to your wireless network, and if it applies that kind of security you’ll find your Xbox 360 MAC address on the list there so, allow the Xbox 360 to get connected to the network, or even you can just turn off the MAC access control option instead of that, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
4. If it's still not working, you can put the Xbox 360 console - as a trial - in a closer position to the router to see wither it's going to pick up an IP address or not.
5. If even after you turn off the MAC filtering option on your router settings your Xbox 360 can't still get connected to Xbox Live you need then to update your router firmware (The router software) and if you don't know how to do so then call your ISP (Internet Service Provider) to assist you with that, then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
d. ICS (Internet Connection Sharing):
1. Go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then “Restore to Factory Default" when it asks you to Apply Settings choose “Test Xbox Live”.
2. Allow the ICS option on the PC as mentioned before, then test Xbox Live.
3. If it's still not working, set the IP Settings manually to be:
IP Address: 192.168.0.2
Subnet Mask: 255.255.255.0
Gateway: 192.168.0.1
Then go on the Dashboard of your Xbox 360 console to “System” area then “Network Settings” then "Test Xbox Live Connection".
4. If it's still not working, you can get the IP address of your connection from the PC as mentioned before then set your IP manually on the Dashboard of your Xbox 360 console using this IP address, when it asks you to Apply Settings choose “Test Xbox Live”.
If you faced any other kind of troubles with this part failing even after you tried these steps please check me
Jan 03, 2009 | Microsoft LIVE ONECARE 2.0 XP/Vista for PC
I cant get an IP adress what i it it says faild
If the X-Box is trying to connect wirelessly to your network, you might need to access the router page and check the wireless settings and make sure that you have the correct encryption or network key, Check the MAC address filtering of the router and make sure that it is disabled or it is off, If you are using a D-link router it is under the Advance tab, Network filter, on the other routers mostly they are under security options, Now after checking those on your router follow the following steps
- Go to the X-Box Dashboard
- Go to Network settings
- If the X-Box is wireless you should have on option for wireless at the bottom of the page
- Select your wireless network and test the X-Box Live
- If it is a wired connections
- Test X-Box Live It should now all connect and confirm the IP, DNS, ICMP
- NAT may show as strict but it should be able to connect to X-Box Live
- If you want to Set the NAT to Open
- Check the IP address of the X-Box by going to Network settings then Edit settings
- Then go to the computer again
- Access the router page
- Go to port forwarding normally located under an advance tab
- Open the ports UDP 88, UDP 3074, and TCP 3074 (here's one example, http://www.portforward.com/english/routers/port_forwarding/Dlink/DIR-655/Xbox_Live_360.htm)
- The IP address field must be filled with the IP address you got from the X-Box
Hopefully this solve's your problem sir
brakke_usaf..Good Luck and Merry Christmas to you and your family..
Dec 25, 2008 | Microsoft Xbox 360 Elite Console
Ip address failed
I think you need to ring your internet provider and they will enable xbox live from their side. Its fairly simple and they will know what your talking about.
Oct 20, 2008 | Microsoft Xbox 360 Console
Linksys wrt54gs router and Xbox live
make sure that internet connection working fine first..if it is connect you xbox via wired or wireless(if wireless, make sure that you connect to your own wireless network and enter the wireless security if there is)...check if you can get an ip address, better set to obtain the ip address and dns of your xbox, if all set and still unable to access internet, access the linksys router setup page by typing 192.168.1.1 on the address bar of your internet explorer, when pop-up for username and password type admin under password, leave it empty for the username. Click administration tab and disabled UPnP. Check if your X-BOX working fine. Hope this help you.
Sep 29, 2008 | Linksys Wireless-G WRT54GS Router...
IP address
Try this fix:
http://xbox360help.blogspot.com/2007/04/ip-failed-xbox-360-live-test.html
Apr 13, 2008 | Microsoft Xbox 360 Console
Xbox live
ok, this is what i have to do whith normal computers.
(the xbox is the same)
(make sure youve got a crossover cable (red one))
1.turn on ur xbox
2.goto the system tab
3.goto Network settings
4.edit settings
5.ip settings
6.change it to manual
7.ip address
8.type in 192.168.1.2
9.Subnet mask
10. type in 255.0.0.0
11.default gateway
12.Type in 192.168.1.1
On your computer
(vista)
1.start
2.control pannel
3.Network and Sharing Center
4.manage network connections (on side Bar)
5. right click on Local Area Connection
6. go propertys
7. doble click on tcp/ip v4
8. click use the following ip addess
9. ip address
10. 192.168.1.1
11. subnet
12. 255.0.0.0
13. default gateway
14. 192.168.1.2
15. click ok
16. click ok
17. right click wireless network
18. goto propertys
19. got the sharing tab
20. tick the only box you can
21. press ok
22. your done!
phew that was a long one.
hope this helps.
Maxicube.
Feb 09, 2008 | Microsoft Xbox 360 Console
Joining XBox Live
Make an account offline that should work.
Feb 06, 2008 | Microsoft Xbox 360 Console
Connecting to xbox live with speedstream 4100
force the gateway on the xbox configuration... retrieve gate from command prompt of your pc depending on the os.
Jan 28, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Get go to xbox live
For some reason everyone has the same problem buy the Xbox 360 wireless kit and should work but for now you might as well just wait untill get its fixed
Dec 30, 2007 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
16 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
