Question about Panasonic KX-T7453 Corded Phone
Speed Dialing KX-T7453
I have recorded the telephone numbers to dial, but when I press [call] it dials it to the intercom line instead of an outside line. How can i fix this or how do I store outside numbers to dial? Thanks
  • Panasonic Master
  • 2,460 Answers
Part of the number you store in your speed dial has to include a "9" or 8x access code to get an outside line.
Carl
Posted on Sep 18, 2008
HOW DO I CHANGE THE GREETING ON A KX-T7453 PANASONIC CORDED PHONE?
The KX-T7453 phone does not have a message function, you may have an associated voicemail on your system. Try dialing (on the intercom) extension 165 if you do not have a voicemail button. Are you trying to change the greeting for your individual phone or the main greeting people hear when they call your company?
This gets a lot more complicated and you should contact your vendor.
Dec 24, 2014 | Panasonic KX-T7453 Corded Phone
How do I store extensions in KX-T7453?
PROGRAM BUTTON
99
PRESS THE BUTTON YOU WANT TO STORE THE EXTENSION ON
EXTENSION NUMBER
AUTO DIAL/STORE BUTTON
Nov 05, 2014 | Panasonic KX-T7453 Corded Phone
How do we cancel the DND on a Panasonic KX-T7453
Press the dnd button without lifting the handset. The light should go off.
Oct 29, 2012 | Panasonic KX-T7453 Corded Phone
Would you please be able to tell me how to programme a number in this phone.... on a specific button down the side.
What happens when you dial "9" on the intercom? If you get an outside line, then your phone is programmed properly. If you get an empty line, then you need to disable vacant lines in system program 400.
To program the right side buttons for speed dial, press PROGRAM a button on the right side, and dial 9+ the number as you would dial it on an outside line, then STORE.
On the left side, a waste if you're putting speed dial number sin, you dial 29 instead of 9, but normally you reserve them for lines, extensions, and features that require lit buttons. The codes would begin with 0,1 and whatever the magic code for the features are.
Carl
May 05, 2011 | Panasonic KX-T7730 Corded Phone
I have Panasonic kx-T7453 and one of the Outside lines was already connected to a station and while programming a One-Touch dialing ended causing the outside line to be disconnected to this station. How do...
In a TD system, the lines have 2 digit number 01-12 normally, up to 55 actually. So, if line 1 is missing, press PROGRAM dial 99 press the unprogrammed button and dial 0 01 STORE
Press PROGRAM or pick up the handset and drop it back down to exit programming.
Carl
Apr 21, 2011 | Panasonic KX-T7453 Corded Phone
Cannot store numbers for One-touch dialing.
I can.
A lot depends on where you're trying to store these numbers and how you get an outside line. In my system, I dial "9" on the intercom and it gives me any available outside line. Also, IIRC a 7453 has 24 buttons with LED's on them. So, the Pana trick is the digit "2". Try this: PROGRAM 99, touch a button with an LED, and dial 2 + 9 + your number and STORE. The "2" tells the system to use the button as a "one touch" button. In other phones, the "F" buttons (ones without lights) already assume the "2" so it's programmed with just the access code "9" and the number.
Carl
Mar 11, 2011 | Panasonic KX-T7453 Corded Phone
How do you program mobile numbers into the one touch dialing function? It keeps dropping the 0 off at the front and then won't connect to the number.
Exactly what are you programming under the button and are you putting an ACCESS CODE in the number? When you go to the intercom, try dialing "9" or whatever you use to get an outside line. If you use a special line to dial out because you're calling a mobile, then you need to dial 80x instead of 9.
Just an idea.
Carl
Oct 28, 2010 | Panasonic KX-T7633 Corded Phone
I NEED TO STORE NUMBER ON MY PANASONIC KX T7730
The mechanics of storing a speed dial number on Panasonic phones is the same, even if the phone can be connected to one of 18 different model Key Service Units. It involves pressing PROGRAM a button, an access code, the number, and STORE. In the U.S. our access code to get an outside line is "9". You may be using something different, like '0'.
The differences are if you can dial "9" on the intercom and get a dial tone, which collumn of buttons you press, and/or whether you want this to be PERSONAL numbers or SYSTEM numbers.
In a TA-824, lines are accessed high to low. If you have 2 lines on a basic system and dial "9" to get an outside line, you will land on line 3 if you have not told the system that line 3 is disabled (system program 400). So, the fast answer is press PROGRAM, a button on the right side, dial 9+your desired number and STORE. If it's a left side button, dial 29 instead of 9.
System speed dials requrie access to system program 001.
If this does not work on your system, please comment back with your actual system model number.
Carl
Nov 09, 2009 | Panasonic KX-T7730 Corded Phone
NorStar T7316E Corded Phone Manual
1 you can but it must be done via log on to switch with lap top (you may use handset but very tricky)
2 use feature *4
Speed dial -
using
FEATURE 0
Dial an external telephone number using a two- or three-digit code. There
are two types of speed dial codes: system (01-70 or 001 to 255) and
personal (71 to 94). System speed dial codes can be used from any
display telephone in the system. System speed dial codes are assigned by
your System Administrator.
Personal speed dial codes are used exclusively at your telephone.
To make a call using a speed dial code:
1. Press FEATURE 0.
2. Enter the two- or three-digit code for the number.
Speed dial -
programming
To program personal speed dial numbers:
1. Press FEATURE *4.
2. Enter a two-digit code from 71 to 94.
3. Specify the external line by pressing a line button, a line pool button, or
the intercom button. If you do not specify the external line, the system
automatically chooses a line for the call.
4. Dial the telephone number you want to program (up to 24 digits).
5. Press HOLD.
6. Record the code and number you have just programmed.
Note: You cannot program personal speed dial numbers while another
user is programming your system.
May 15, 2008 | NorStar T7316E Corded Phone
Panasonic KX-T7453 Corded Phone Logo
352 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
