Question about Bravetti EP4305FS Deep Fryer
I've had my deep fryer for about 1 1/2 yrs it always went well, the other day we deep fried fries unplugged it from the wall and even removed the magnetic electrical from the deep fryer about 5 mins later it started boiling but boiling to the point we had to take it outside in the yard and it actually spilled over this went on for about 5 min then it slowly cooled off on its own. We still don't know exactly what happened but I would like to inform people not to leave their deep fryer unattended and don't leave children of any age alone with a deep fryer. Do you have an explaination for our mishap we sure don't! thank you for your time mo
  • Anonymous Feb 02, 2009
    it's because of the moister from the fries or if you put water on your fries it will cause it also
He product has been recalled in canada you can find more information on the government health and safety website here:
http://www.healthycanadians.ca/pr-rp/recall-retrait_e.php?langCd=eng&searchTyp=1&re_id=466&searchstring=&searchyear=2008&searchcategory=&StartIndex=1
Posted on Oct 03, 2008
Where can I buy a Deep Fry Basket 6" x 17-1/2" x 16-3/4"?
Wasserstromrestaurant supply seem to be the suppliers for most deep fry baskets. Check outthe link to their site for details http://www.wasserstrom.com/
Jul 16, 2012 | Dean Guitars Fry Basket
A friend told me to buy an 8 inch deep fry thermometer for making fish. Is it worth buying one?
Deep fry thermometers help you cook fish perfectly, so that you don't undercook it or dry it out completely. The 8inch thermometer clips to the side of the fryer. I love mine!
Jul 15, 2012 | King Kooker Deep Fryer Thermometer SI 1
Anyone know if covers exist for Dean Frymaster deep-fat fryers? I have three in a mobile unit and want to be able to move the trailer without draining the oil.
Hi there!
For open fryers, oil will still spill even with cover during transit because open fryer cover is not designed to contain/ hold oil inside the fry pot to prevent the spill, it is only designed to prevent foreign objects from falling inside the fry pot when not in use, draining the fry pot before moving the trailer from one location to another is only the best solution.
Regards.
May 08, 2012 | Frymaster Dean 2424G Deep Fryer
Does not heat to 375 degree. cooked but soggy fries. green ready light goes on and off. tried preheating 20 minutes. not much better.
you can fry fries at 325 degrees.pre heat for 25 min. rinse fries with water first, fry for 11-14 min. should be golden and crunchy. Deep fry guy :) Fresh potato recipe after fries are fried sprinkle w/seasoned salt &little red pepper
Sep 07, 2009 | Rival CF275 Deep Fryer
I need to purchase a fry baby
The fry baby is no longer manufactured. The smalles deep fryer is the fry daddy.
Aug 07, 2009 | Presto 05430 FryBaby Deep Fryer
French fries always turn out soggy
It seems to me that if the fries always turn out to soggy what you need to do is to cook them at a higher temperature for a shorter period of time, I think they are sitting in the oil far to long hence the soggy result.
Mar 20, 2009 | Presto 05430 FryBaby Deep Fryer
Presto fry baby
I just got one of these w/Instructions, Says fill oil to fill level line inside. Cooking oil or shortening. Never use more than (2) - 8 ounces cups of cooking oil or (1) pound of shortening. Hope this helps!
Dec 12, 2008 | Presto 05430 FryBaby Deep Fryer
How to change a thermostat on a pitco fryer
First off make sure you get the OEM pitco t-stat.
1. Unplug all power sources from the fryer.
2. Remove all oil or shortening from the fry pot.
3.Remove the sensing bulb from the brackets inside the fry pot.
4.There will be a double compression fitting entering the fry pot from inside the control area, remove both of these compression fittings.
5. Slide the sensing bulb and cap tube out of the opening in the fry pot.
6. Remove the mounting hardware holding the old t-stat to the cabinet
7.Disconnect the wires on the backside of the t-stat (Make sure to note the wire locations)
8.Connect the wires to the new t-stat.
9Repeat the order in reverse to reinstall the new t-stat
When you connect the larger compression fitting to the frypot make sure that you get a pipe sealant that is rated to 600 deg. F
any high heat pipe sealant for stainless steel should suffice for this.
Hope this helps You
Dont forget to rate me
Jul 07, 2008 | Pitco Frialator SG14 Deep Fryer
Cleaning
From http://www.rivalproducts.com/help.aspx?helpNav=1: How can I clean my fryer? - Unplug from outlet and allow unit to cool. Always turn control to OFF then disconnect plug from wall outlet BEFORE disconnecting BREAK-AWAY CORD. - Clean the outside of the fryer and lid with a damp cloth. CAUTION: Do not use abrasive pads or alcohol to clean the fryer. - Remove basket handle, if one is included. Frying basket can be washed in hot soapy water. - Rinse and towel dry carefully. - Pour out oil and discard properly. - Wipe the inside with paper towels to absorb excess grease. Wash interior of fryer with hot soapy water. Rinse and dry thoroughly. CAUTION: Never immerse the fryer in water or wash in running water. If you own a fryer with a removable bowl or other removable parts, refer to the Owner?s Guide for your specific fryer to determine which parts can be cleaned in the dishwasher.
Mar 08, 2007 | Rival CZF630 Deep Fryer
Bravetti EP4305FS Deep Fryer Logo
177 people viewed this question
Top Bravetti Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Mike
Henry  Thomas
Henry Thomas
Are you a Bravetti Kitchen Appliances - Other Expert? Answer questions, earn points and help others
