Can't turn on, timer button keep on flashing on and off
    Problem Solver:
  • 5 Answers
Is there a reset button? if so click it :)
Posted on Sep 18, 2008
I have the pth5498 and my tv won't turn on. My
Timer is not the problem---the tick ticking sound is the shutdown circuit in the set that has been triggered by a short somewhere likely in the high voltage area or the convergence circuit---shop repair---says Akai but I suspect set was made by Samsung who owned that name at one time.
May 25, 2012 | Akai Televison & Video
CAN ANYONE HELP i'm having a problem keeping the timer from going off and shutting the whole tv off. My kp-46wt510 sony widescreen from 2003 is doing the same thing, picture is bowed in the middle and...
Most likely you have turned on the sleep function. 2nd button from the left on the top of the remote hand unit. Keep pressing until "sleep off" appears on-screen.
Or
Timer in user's menu is activated to turn off TV a specific time. Go to timer menu and adjust timer, then push cancel on the remote, this should reset timer to zero. Same with current time, adjust and select cancel, this should reset current time.
If you do not have the original remote, you are in trouble. Service tech will have remote.
easyab
Feb 23, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
TIMER LIGHT BLINKING AND POWER IS NOT COMING ON CD-SW330
i have the sharp cd-sw330, it has no display and won't turn on but the timer just keeps flashing, i have done the bit it says about pressing the timer button then arrows and memory but that doesn't seem to work help?
Jan 09, 2011 | Sharp CD-SW330 Shelf System
How do I program a Noma N1506 timer?
All Woods timers and manuals
ttp://waterheatertimer.org/Woods-timers-and-manuals.html
N1506 manual:
http://waterheatertimer.org/pdf/Woods-49122-N1506-manual.pdf
N1506 is heavy duty outdoor timer with display screen.
Plug timer in and display flashes C.
Set current time: press Time button once and display shows 1 am
Keep pressing time button until current time with am pm displays.
Dot in lower right corner corresponds to pm hours.
To set timer program:
Press Mode button, display flashes P
Press Time button until desired ON time displays.
Press Mode button again and display flashes E
Press Time button until desired OFF time displays
When programming is finished, press Mode button and display shows current time.
To reset timer, unplug timer for 10 seconds and re-program timer.
Timer must be reset after power outage. Display will warn by flashing C.
Plug lights into timer.
If lights have a switch, switch must be on.
For manual override, press Mode button, and display shows O and lights will be ON until next program change.
To use timer function, press Mode button until current hour displays.
Dec 12, 2010 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
How do I set the Woods N1506 timer?
N1505 timer manual:
Dec 01, 2010 | Woods Outdoor Lighting Timer
Model N1506, I need Operation instructions for this Woods Light Timer?
N1505 timer manual:
Dec 01, 2010 | Hardware & Accessories
The timer light keeps flashing and unit does not respond to the on by cooling the room when the on button is pressed
timer button keeps flashing and no heat coming from unit. cool air works, but absolutely no heat.
Oct 13, 2009 | Daewoo DSA-122L Air Conditioner
Timer light keeps flashing
sounds a s if you have ablockage within oyour pump assy, remove th elower acess panel and undo the "button trap" your problaby clogged up, the drain pump is humming, causeit cant pump any water
Jan 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My tv won't turn on, the timer keeps flashing
http://www.jyerdon.com/tv/
If it`s a 65513 mitsu, this will fix the flashing green light, most of the time, e-mail me with any questions, good luck
buranc@bellsouth.net
Dec 28, 2008 | Mitsubishi WS-65513 65" Rear Projection...
TV won't turn on, delay/timer light flashing
Please update this with the blink count. That will indicate the circuit in which a problem was found. Once I have that information I should be able to give you the probable cause and remedy.
Dan
Dec 02, 2008 | Sony KV-27S45 27" TV
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
