Question about Sony BRAVIA KLV-40U100M 40 in. HD-Ready LCD Television
Set up a channel ( 2,7,8,9,10,sbs ) on TV sony LCD
Sydney 19/9/08
Hi.
I just buy a brand new LCD sony TV 40 inch, but i don't know how to setup a channel TV, i just heard people say, just press auto program, and then they will set up auto for you, is that correct.? please help me.
Thank you very much,
  • 10,594 Answers
If you want to set up tv channels in your tv, connect antenna cable in RF Input at rear of tv, go to tv menu and select preset, then press auto-preset and rest will do tv itself.
Posted on Sep 18, 2008
I don’t have a manual on how to use my new tn. All I am getting are the ordinary channels and sbs. I would like to know how I set up tp gain access to all channels, also how do I record
hi there, could you please expand on the question, such as.What is 'sbs' ? and which other access to channels are you referring to ? also why would you think you can record on your tv ?. I may be able to help with a manual, but in order to do so I need the make and model number.
Oct 12, 2017 | Televison & Video
How do I program tv channels for Sydney if I am receiving channels from Wollongong?
(Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Pull up older posts.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Sep 19, 2014 | Hisense LHD3204US 32 in. LCD HDTV
Hooking up a sony dav is 10 to my 40 inch coby lcd tv
Hi, unfortunately Coby is not manufactured any longer. I have a problem not the same as yours, but I can't use my headphone when using my Panasonic Blu-Ray player. Have to use the sony digital surround sound. nothing comes through the Coby...If you have an extended warranty, I would call and have it replaced with another 40 inch brand..They can't fix it.I'm calling to have mine replaced or repaired...sorry i couldn't be better at helping..
Jul 05, 2014 | Coby 40 TFTV4028 LCD TV
Samsung UA40EH5000R power not on via remote control
If all other buttons except power button on the remote control works, the fault should be of remote control. Its internal circuit will have a break; and is irreparable. If no buttons works, check the remote control for its infrared emission. For more information http://electronicshelponline.blogspot.com/. If the remote control is found faulty, buy a new one.
If you wish to buy its original remote control, you have to contact the authorized service center. If you wish to buy a universal remote control, you should know about, which brand remote control have setup code to your TV/device brand. You should first make sure about the number of digits in the codes to your device have. There are 3-digit, 4-digit, 5-digit and even 2-digit codes. You can get this detail by the code list attached to every universal remote control. The brand name of the remote control you select isn't a matter; but, its code list should have setup codes to your TV/device brand, otherwise you can't set it up with your device. Check this link and note which brand remote control have set-up codes to your device brand, and buy that brand remote control, according to availability. For more information http://electrohelponline.blogspot.com/ Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
Dec 21, 2013 | Sony BRAVIA KDL-40S2010 40 in. LCD...
I have done an autotune on my sony bravia tv but am not getting channel 9 sbs. the television in the bedroom is a smaller digital tv and that picks up all the channels. the two tv's are connected
Is the splitter an amplified splitter or not? Have you tried the channel search when you connect the antenna directly to the TV? (Disconnect the cables from the splitter and use a coupler to join them together.) Tuners do vary in their sensitivity. For digital signals, your TV should report the signal strength. This is often under the Settings sub-menu. Some TVs will give this information in the Channel Edit option.
If the straight through connection gives a better signal, check your antenna direction and try a different splitter. Amplification will often help; however, when my amplified splitter was damaged the less sensitive tuner lost a number of channels that the other TV received. (Looking at the signal strength, one TV was getting adequate signal with one bar out of 8. The other needed at least 4 bars to process the signal.)
I hope this helps.
Feb 01, 2012 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
My sister has just bought me a Sanyo 26 inch TV (LCD-26XR9DA) but it won't pick up SBS and ABC jumps all over the place. I have an outdoor antennae and had no problems picking up the channels on my old...
Go to the TV setup menu and autodetect all channels. This should fix it. This is assuming your Sister is not using a set-top box.
In that case, you neet to leave the set on either channel 3 or 4, or use the video/audio input jacks and leave the set on VIDEO IN. The best picture with a non-HDMI set-top box will always be with the AV OUT from the box going to AV IN on the set [the white/red (audio left/right) and yellow(video) connections].
If she is using a set-top box with an HDMI output, connect an HDMI cable to the set and select HDMI IN for the absolute best picture.
Jan 29, 2011 | Sanyo Televison & Video
Scan Channels
the samsung service center can help you on that problem. just try to consult them.
Jun 19, 2010 | Samsung LA40A550 40 in. HD-Ready LCD TV
Wondering if 40 inch 1080 LCD element was a good buy?
Not a great brand, generally when out of warranty, you are on your own. No repair except by independant shops if they will even touch it - no manuals or parts that they can get... Considered a disposable set.
Mar 24, 2010 | Element Electronics FLX-3211B 32 in. LCD...
How do a program or scann the channels in my sony bravia t.v?
If you're referring to the KDL-40V2500 TV, please refer to the page number 37 in the manual to Auto Program the TV.
Press the MENU button on the Remote. Then, select the ANALOG SETUP SETTINGS.
Then, select the AUTO PROGRAM under the ANALOG SETUP SETTINGS.
Jun 13, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Sony KLV-40U100M Screen replacement
If this were just about any other brand, you'd likely be able to find another brand of TV with the same size screen and swap the inverter boards and the LVDS board. The problem with Sony is that the company uses internal designations. If you have homeowner's or renter's insurance, it might cover some of the cost. Otherwise, put the damaged set on eBay (you'll get a couple hundred dollars plus shipping) and go buy a new set. Likely, any larger set for sale with a good screen is going to go for more on eBay and finding one is rare.
Jan 31, 2009 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Sony BRAVIA KLV-40U100M 40 in. HD-Ready LCD Television Logo
205 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
