Question about LG TROMM WM2688H 4.0 cu.ft. Front Loading SteamWasher
Tromm LG Washer
Giving me a OF code??? Its not draining or spinning.
NEED help if you can, on Christmas Eve so I know I will not get any service for a few days.
thanks will not spinn out already checked the drain on front
  • Anonymous Feb 07, 2009
    MY LG TROMM WASHER IS NOT GIVING ENOUGH WATER PLEASE HELP
  • Carl Schulzetenberg
    Carl Schulzetenberg May 11, 2010
    What is the model number of your machine? I looked up a current washer and there wasn't any OF code. And what is that about Christmas Eve, when you are posting on Sept. 18 ?
  • 1,543 Answers
Santa says that "OF" code is really a "DF" (drain fault) which means check the filter (behind the access door at the lower left on front of the machine). There is a small drain hose next to it which should allow you to drain out the remaining water in the machine before you remove the filter. If the filter is clear, it is possible that the impeller on the pump motor is off, which requires a new pump motor. (if you push the impeller back on, it will only come off again) Santa would like a "fix ya" rating this year. thanks.
Posted on Sep 23, 2008
    Carl Schulzetenberg Sep 25, 2008
    You're on Santa's list of good boys and girls this year ! Glad I could help.
LG Tromm wm2077cw front load washer would not drain Looked at drain pipe and drain pump filter, both was good no clogs
Does the pump work? if so common problem is something stuck blocking the sump pipe between drum & pipe 2 the pump
Dec 23, 2015 | LG Washing Machines
LG tromm spins on washer,but doesn't on rinse and won't drain
ur confusing me its not suppose to spin first , first it rinses, then drains then spins
Jul 12, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have a LG Tromm with an LE error code. I just replaced the hall sensor
With a digital volt meter you need to measure the ohms value of the hall sensor. It has 4 wires. White red blue and gray. With the meter set at 20k ohms check hall sensor at the control panel. From white to blue you should read 9.5 K ohms. Same with white to red. If u get 9.5k ohms on both readings u have a bad main board. However to me I think your pump is bad. LG washers will not spin if they don't drain.
Apr 03, 2014 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Hello, I have a front load LG TROMM WM2277HB and yesterday it wouldn't spin anymoreand there was a noise coming from inside like 2 metal cylinders were rubbing on each other. I called SEARS Serv
if the machine fails to spin and makes noise there are thee things to check .if it fails to drain the water check if something is stuck on the drain pump no 2 turn the drum with your hand and check if the drum is moving freely if not something is stuck between the drum and the housing if the bearings are faulty the machine spins but makes alot of noise towards the end of the cycle i hope this will help you.
Jan 21, 2013 | LG 4775er2002a Door Hinges for Wm2277hb...
LG TROMM WM3431HW(?) soaks clothes in Dry Cycle
LG says to unplug unit. Or remove power by tripping circuit breaker. Wait a minute and plug back in. Good luck.
Mar 25, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
On my frontload LG tromm I have the error code EO it will
There is a filter on the bottom left of the machine. If you pop the door off you can drain it with the hose, then spin the black filter out of the housing. This may help. Keep a wet/dry vac handy.
Nov 28, 2009 | LG WM1814CW Front Load Washer
My washer isn't drying anything very well. getting a oe message lg tromm wm2277hm
the OE message means that the machine has not fully drained out all the water. you can try to re set on drain or you may need a service call. hope this helps.
Oct 15, 2009 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I need the user manual for my lg tromm wm2277hw because I don't know how to get it to spin without going through the whole wash cycle
for a drain and spin : turn unit on hit spin Button 1 time then start/pause button
this a drain and spin only..
Jun 15, 2009 | LG WM-2277HW Front Load Washer
Tromm washer full of water
You have a jammed drain pump and will require the pump to be removed and cleaned out.  You will need to call a qualified LG technician to resolve this problem.
Mar 26, 2008 | LG WM2688HWM TROMM SteamWasher
Tromm LG Washer
On my LG TROMM model # WM1814CW, the door pops open a bit so that water leaks out onto the floor. Is it a simple repair or is it time to get soaked by a repairman. I'm fairly handy, but I don't know if it is an electrical issue or it is a mechanical issue. If you have a suggestion, send it to repihl@yahoo.com.
Thank you,
Bob
Dec 24, 2007 | LG WM2688HWM TROMM SteamWasher
Washing Machines Logo
240 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
