Danby DMW1153 1100 Watts Microwave Oven
Problem for Danby DMW1153 1100 Watts Microwave Oven
Not working
By varumr on Sep 18, 2008
My microwave is not working... it gets switches on n runs.. but teh stuff dosent get cooked.. not even heated up/..
What could be the proble..?
it is an year old
Clarification Request
Posted by MicrowaveSvc on Sep 26, 2008
When you hit Start to cook, do the inside light and turntable come on?
Any unusual noises?
Is it louder or quieter than usual?
Do you have the model number?
These answers will help me judge whether it's in the high voltage section (magnetron, transformer, or diode) or the control section (door switch or control board relay or connection).
Same Problem
Feb 09, 2009
-   The microwave runs and doesn't shut off. It doesn't heat anything up. Have to unplug it to shut it off.-   flutechick
Dec 22, 2008
-   microwave starts and runs but will not heat or cook. Is there anything that can be done
-   gerrib113
Oct 24, 2008
-   Everything works on the microwave except it does not heat up.-   bhupshall
Best Solution
posted on Aug 08, 2009
Very Helpful)
localwonder
Rank: Guru
Rating: 92%, 2811 votes
HI. in most cases, this will lead to a failed Heating device(magnetron tube).It would be wise to check the Magnetron cutoff fuse to be sure of its integrity. if the fuse is blown, simply replace it. if the fuse continues to show continuity, replace the magnetron.
(((The fuse is located inside the unit along side the magnetron)))
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Danby DMW1153 1100 Watts
Questions and Unsolved Problems for Danby DMW1153 1100 Watts
Do you recommend Danby DMW1153 1100 Watts Microwave Oven?
Answer
Answer
buzzer sounding,the buzzer would go on and on intermittently and during this time microwave will not... (More)
Answer
my chefmate microwave p70d20al-d4 started beeping and displaying 66666. what can be done?
Answer
I bought my Danby microwave about a year ago from Walmart and just recently I've been getting... (More)
Answer
i try to re-se microwave oven P7OD20AL-D4 By unblaged it yet i couldent, how can re set it thanx
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Danby DMW1153 1100 Watts...:
Top Microwave Oven Experts
Rank: Guru Guru
Solutions: 901
Experience: im the jack of all trades but a master of none! and being an old git you get to learn a fuw tricks
Ask Me
Find more Microwave Oven Experts
Top Small Appliance Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
