Question about GE JE1540 Microwave Oven
GE Microwave Keypad or Control Panel
I have a GE JE1540 turntable microwave oven. It seems some of the numbers on my keypad don't work but some do. I noticed on the parts list there is a "control panel" and a "keypad". How do I know which one has gone out? Also how do you replace the lamp in this oven? Do I have to remove the entire oven from the wall?
  • mom2anw Mar 03, 2009
    My GE Profile JE2160BF03 microwave has same problem:  buttons 7,8,9 suddenly stopped working.  All other buttons/functions work.  Any guide available if I want to repair/replace keypad/circuit part(s) myself?
  • Vince Mcatee
    Vince Mcatee Jan 20, 2013
    My GE Profile JVM1870BF06 is the same but looks like a diffrent style could you please post photos or info of how to change this one Thank Vince
  • GE Master
  • 9,098 Answers
If some pads on the keypad are not working, then you have a failed keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
On this model, the cover will have to come off to replace the light bulb. If it's mounted in the wall, it will have to come down.
The installation instructions are nice to have in this case. You can download GE owner's manuals and installation instructions here.
I have attached a drawing to show where the bulb is on this model. It is located on the right side of the oven next to the wall of the cooking cavity.
The bulbs are available in local grocery stores, hardware stores, and stores like Wal-Mart and Lowe's.
Please feel free to contact me directly if you need more help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 27, 2008
Why does my ge microwave model je1540gv002 starts and stops by itself?
If and when an oven is coming on or doing anything by itself, this is very dangerous and can result in a fire.
So until it is repaired, please leave it unplugged or leave the door open when it's not in use, and of course one should never leave a microwave unattended while cooking.
Chances are you have a shorting membrane keypad.
Please let me know your full model number and more details on what it's doing and I can give you the information you need.
Jan 08, 2014 | GE JE1540 Microwave Oven
GE OTR microwave model #HVM1540DN188--keypad buttons #1 thru 6 do not work.
The problem is in the keypad control board, this part is at least $97.00 or more to replace and does not include the labour.
Jul 03, 2012 | GE JE1540 Microwave Oven
Ge microwave surface and oven light not working as well as turntable
The problem is in one or two of the door switches, or the keypad control board is the source of trouble.
May 17, 2012 | GE Microwave Ovens
Ge profile microwave jvm1870sf02 buttons don't work do i need to change the control panel frame or Bkt c/panel
You will need to change the keypad along with the control board, because they are essentially of one piece. But the part will equal, if not more than a new microwave oven.
Apr 08, 2012 | GE Microwave Ovens
The display says Reset but none of the buttons will work.
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes.
If it still won't work, you probably have a bad keypad.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Aug 19, 2010 | GE JE1540 Microwave Oven
The 'turntable on' feature does not work it reverts to 'turntable off' each times it is set. Please advise
If the display is changing by itself despite your pressing the turntable pad, i would say the turntable pad is failing on the keypad.
Then if it still fails, you may have a failing keypad.
Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more information & help.
William E. Miller, AS-EET
prototech@usa.net
Microwave Oven Control Panel Repair Nationwide
Aug 17, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Getting error code F-3, microwave beeps with this code, entering Clock, then the time clears the code, then can use microwave, but after sitting code comes back on. Have tried unplugging oven for several...
F3 on a GE / Hotpoint microwave means you have a shorted membrane keypad. It can be intermittent.
On some models, the keypad can be replaced as a separate part.
But on some GE models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame. That is a simple do-it-yourself job.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
prototech@usa.net
Jun 16, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a ge profile microwave,convection oven, hood combo jvm1790sk01. At first the cook button stopped working and after reading the manual it said to press the start button for several seconds. After...
On this model, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
It is part number WB07X10977 and you can get it here for $56.18 (compared to $93.00 from GE!).
You can find links to helpful exploded view diagrams and part ordering help here. I'd recommend that your bookmark this link to your favorites.
Then you unplug the keypad (as per the photo below) and move the circuit board into your frame.
Some connectors on the relays may have a lock as shown below:
Dec 17, 2009 | GE JE1540 Microwave Oven
GE Profile Microwave Keypad
I have the exact same problem at exactly 12 moths and 22 days. Just out of warranty, wouldn't you know. Sears says it will be $150 just to show up. What a piece of junk.
Sep 12, 2009 | GE JE1540 Microwave Oven
Microwave Ovens Logo
7,009 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
