Question about RCA TruFlat 27F520T 27" TV
Will not come on
It started shutting on and off by itself. now it will not come on at all either manualy or with the remote.
  • ATURNER79 Sep 25, 2008
    I AM HAVING THE SAME PROBLEM. IT COMES ON AND OFF WHEN IT WANTS TO. IT CAN BE OFF FOR HOURS AND JUST TURN ON ALL BY ITSELF AND THEN TURN OFF AGAIN. THE LONGEST IT WILL STAY ON WITHOUT SHUTTING OFF IS 10 MINUTES.
Same with me
Posted on Oct 14, 2008
Cool start remote starter
start it manualy if is the same problem.. not enough power getting for a cold start.. if thers enough power.. thats a remote problem
Jan 15, 2014 | Vehicle Parts & Accessories
Whenever i unlock my camry manualy ( key in the door ) the alarm goes off. Also if i open the back door before the front door the alarm goes off. I have to use the remote key or i cant get into my car and...
this is due to a bad switch in the drivers door, when you use the key to unlock the door it should shut down alarm, also the alarm module may be going bad, the alarm is setting itself on, when ever you lock the door the alarm turns on, you will need to replace the switch on the drivers door or unlock the passenger side door that also has a switch that disarms it, the switch is on the lock itself, thats the problem you are having , good day,
Apr 15, 2011 | 1997 Toyota Camry
Lost the manual and can't get tv to turn without the right code
if the remote has a set-up or code button you can search for the right signal manualy.first turn the tv on.press the "tv" button on the remote,then hold down the "set-up or code" button til the remote light stays on.the keep pressing the power button on the remote until the tv turns off,careful not to press the button again or you'll lose the code.omce the tv shuts off.hit the enter button on the remote,that should do it:) good luck
Sep 22, 2010 | Universal Remote Control GE174Universal...
My 2001 tahoe alarm keeps "auto" arming itself after about 30 seconds. How do I stop it from "auto" arming? Its driving me crazy
this alarm works with the remote and the key, if you lock with the key it arms if you lock with remote it arms,when you unlock it it should disarm, if your having a problem with it not working try the pass/side lock with key, that should shut it down but if it keeps rearming without locking doors then it may be aftermarket, also in your manualy it will show you that some factory alarms are also self arming this is programed through the cluster, using the buttons on the dash, you scroll through the options and shut off auto arming, this is done the same way you scroll for mileage or trip time or oil change life. hope this helps.
Sep 21, 2010 | 2001 Chevrolet Tahoe
How doyou disarm the factory alarm system in a 1994 jeep grand cherokee my alarm system keeps shutting down the whole car it is a real pain to get it started again i just want to totally shut the alarm...
The security alarm system on the 1994 Jeep Cherokee arms itself on any normal exit from the vehicle, i.e. ignition off, open door, lock door with power door locks, close door. If the doors are locked with the key, it does not arm.
If the battery is disconnected, then reconnected, the alarm system will go into powerup alarm mode. The lights will flash, but the horn will not blow.
The alarms can be disarmed by a keyless vehicle remote or by unlocking either of the front doors or the read lift gate with the key. If the key method does not work with any of those three entrances, there is a problem either with the input to the alarm module or the module itself.
There is a switch in both front doors and the tailgate which is activated by manualy unlocking those doors. The alarms can be disabled by permanently grounding the wire going from either of those switches to the alarm module, but this will remove all theft protection.
The best thing to do is to find out why the system is going off in the first place. It could just be a glitch, a loose connection that can be fixed fairly easily and keep your theft protection intact.
Glenn
Feb 23, 2010 | 1994 Jeep Grand Cherokee
Have a pt cruiser and my remote start wont start the car. but when we hit it all the bells and the whisles come on but just don't start. but when we start it manualy it start but shuts off what could be...
sounds like the transponder bypass module is stuck in the on position, remove both fuses on the remote start unit and then try with the key, it should start, because you have removed power to the unit
Jan 29, 2010 | Prestige Remote Start
I was given a pioneer tv sd-p5575 and i dont have
MY PROBLEM IS ANTIVIRUS IX DIRTY AND NEW ANTIVIRUS
Dec 06, 2009 | Pioneer Televison & Video
Alarm system won't shut off
You might try locking all the doors from the inside and then closing them all. Then try unlocking the car with the key itself (NOT THE FOB) manualy. Try a combination of these things, like maybe locking it manualy with the key itself too. Usualy some sort of locking or unlocking manualy with the key will reset the system. Its almost luike proving to the car that you are who you say you are.
Joel
Dec 28, 2008 | 1993 Jeep Grand Wagoneer
RCA TruFlat  27F520T 27" TV Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
