Question about Samsung NV10 Digital Camera
My camera turn on but the amber light stay solid. Anyone know?
  • hemmert Sep 30, 2008
    I also have the amber light but mine won't turn on or will it take a charge.
Not a cheap solution but Samsung tells me its a circuit problem and may not be economic to repair. Very poor show when its little used just out of warranty. Most likely will not have any other Samsung product unless they come to the party and fix it.
Posted on Sep 14, 2009
Pride Jazzy 1103 Ultra controller code: when the "on" button is pushed and held down, three red, four amber, and one green LED come on and are solid (not flashing), and there is a second LED gauge...
Seven blinking LED's indicate a "Joystick Fault" on the controllers Pride uses. Could be just the actual joystick itself, the part you move to make the chair move, or it could be other electronics in the controller. Here's a link to troubleshooting info:
Pride Mobility Products Corp Basic Troubleshooting Instructions
Dec 21, 2014 | Pride Health & Beauty
Flashing amber and green when charging
I don't know your computer, have you read the Trouble Shooting chapter in its manual? You could try plugging the computer in and leaving it to charge for several hours; my notepad will not display if the battery is flat. Good luck!
Jun 25, 2013 | Dell Inspiron 5160 Notebook
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
I need the manaul for this product. I do not know what the the flashing light mean, and I was given this product from another co-worker....but no one knows what the lights mean?
Hello, you can download the manual here: http://www.plantronics.com/us/media/media-resources/literature/user_guides/73156-01_CS55_US_DL.pdf?WT.dl=20 It says that a flashing amber light means charging, a solid amber light means charged, a solid red light means power, a solid green light means talking, and a blinking green light means muted.
May 16, 2011 | Plantronics CS55 Wireless Headset
Pc has a solid amber light when i try to turn it on now so i unplugged it. I moved the comp around and turned it on again and it had a solid green light but nothing was on. the third time it went back to...
Hi Thanks for your question
I think you are right about power supply. This would be my diagnose. Be careful with your PC because faulty power supplies may fry your motherboard. I would recommend replacing it. This isn't expensive and it's pretty easy to get done. I hope this helps. Good Luck
May 19, 2010 | Dell Dimension 4400 PC Desktop
My projector won't turn on, solid amber light
main board issue. could be zero volt ground problem. if that's the case, all you need is a jumper wire from the power supply to the main board, but you have to know where to put it. best to send it to an infocus service center. try www.avsolutionsny.com. they're really good.
Jan 08, 2010 | ASK Proxima M2+ Multimedia Projector
1 green 7 amber
I have the same problem and haven't yet got an answer!
May 31, 2009 | Canon BubbleJet i560 InkJet Printer
Ineed to know what blue light tells me that my router is working?
Hi jackmyrtue,
Here's what the lights on the front indicate:
A. Wireless Security
  • OFF Wireless security is off
  • Solid Blue Wireless security is on
B. Wireless-Computer Status
  • OFF Wireless computer is not present
  • Solid Blue Wireless computer is connected to the Router
  • Blinking Amber Problem with wireless computer onnecting properly to the Router
C. Wired-Computer Status
  • OFF Wired computer is not present
  • Solid Blue Wired computer is connected to the Router
  • Blinking Amber Problem with wired computer connecting properly to the Router
D. Router/Power Status
  • When you apply power to the Router or restart it, a short period of time elapses while the Router boots up. During this time, the "router" icon blinks.
  • When the Router has completely booted up, the "router" icon becomes a solid light, indicating the Router is ready for use.
  • OFF Router is off
  • Blinking Blue Router is booting up
  • Solid Blue Router is on and ready
E. Modem Status
  • This icon lights in blue to indicate that your modem is connected properly to the Router.
  • It turns amber when problem is detected.
  • OFF Router is NOT connected to modem
  • Solid Blue Router is connected to modem and functioning properly
  • Blinking Amber Problem with modem
F. Internet Status
This unique icon shows you when the Router is connected to the
  • Internet. When the light is off, the Router is NOT connected to the Internet.
  • When the light is blinking amber, the Router is attempting to connect to the Internet.
  • When the light is solid blue, the Router is connected to the Internet.
When using the "Disconnect after x minutes" feature, this icon becomes extremely useful in monitoring
the status of your Router’s connection.
  • OFF Router is NOT connected to the Internet
  • Blinking Amber Router is attempting to connect to the Internet
  • Solid Blue Router is connected to the Internet
I hope this helps figure out your PS3 issue.
Thanks and don't forget to leave a rating.
Mark
Feb 01, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
Samsung NV10 Digital Camera Logo
60 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
