Question about Indesit W 123 Front Load Washer
Indesit washing Machine W93
Our Indesit W93 washing machine will not drain water. Its washing normally according to the cycle chosen, but when teh cycle finishes the dial keeps turning around non-stop. The water does not drain. We checked the pump and found a hair tie stuck to it. we removed it and tried to run the machien again, but same problem. Could the pump motor be burnt out? where is the fuse for the pump motor?
thanks
t
  • 99 Answers
Pump or hoses still blocked,Or pump has had it,Can supply new pump by post if req.
Posted on Oct 11, 2008
Indesit w93 washing machine
take out the plug first
did you try to change a program if not check all the wires on the board at the rear bottom left hand side are on
Jun 30, 2014 | Indesit Washing Machines
Indesit 657w
CHECK TO SEE IF THE DRAIN HOSE IS RAISED ABOVE THE REQUIRED HEIGHT. IF THE WATER IS OVER FLOWING THE TUB THEN IT IS USUALLY THE A BLOCKAGE IN THE PRESSURE SWITCH HOSE, OR SOME INABILITY OF THE WATER LEVEL SWITCH TO MEASURE THE AMOUNT OF WATER IN THE TUB.
Dec 23, 2013 | Washing Machines
Indesit washing machine wie167 the word door came flashing up, the cycle has stuck and the door wont open
Ok the machine needs to be drained. Then switch the machine on again. The door should open.
Oct 06, 2012 | Indesit Door Handle Kit for W123, W133,...
Indesit w123. motor burnt out?
If your seeing flashes from behind the dial I'm thinking that the timer needs to be changed. Even with the motor shorted out, it still wouldn't cause that effect to happen.
Jun 17, 2012 | Indesit Door Handle Kit for W123, W133,...
Indesit w93 is not rinsing,
this is most likley to be the programer brain its gone fulty on you,, its not a cheep part to get fixed sorry
Oct 26, 2009 | Washing Machines
Indesit W93, the light flashes but does not work
On certain Indesit washing machines, if the on off light is flashing 3 times, with a slight pause, followed by flashing a further 3 times, or if it is didplaying F03 you have an error code that is explained as follows -
NTC fault - check Thermistor and module connections.
The NTC is the thermistor, which is a modern-day thermostat. It’s inserted into a tube in the heating element and is filled with heat sensitive crystals that change their electrical resistance according to their temperature. By knowing what electrical resistance the crystals have at given temperatures they can tell the water temperature.
With this fault the NTC is either faulty, or there’s a dodgy connection to or from it or there’s a connection problem where it connects to the main PCB.
It’s not something you can easily fault find yourself unfortunately, apart from if there was an obvious broken wire.
Mar 29, 2009 | Indesit W 123 Front Load Washer
Washing machine fills with water when not in use.
You have an open solenoid on your water valve where the fill hoses connect. Change the water valve and you should be good.
Jul 25, 2008 | Washing Machines
Indesit w93 washing machine fills with water but doesn't start washing
Hi there. I have an old model, the indesit WM12. Never counted the flashing light (yours was 10) but my dial started clicking constantly at the drain part. I called Idesit and they told me it was a blockage in the filter.
The filter they speak of it located, on mine, at the front of the machine at the very bottom on the right. It is a black dial about 3 - 4 inches in diameter. Unscrew that anti-clockwise (a real pain because so much water comes out. My wife and I unscrewed it, filled a baking tray with water, screwed it back up, emptied / substituted tray then same all over again - until empty. Though putting it on drain again and again helped at same time). When I pulled out the filter found a 'colour catcher' sheet in it. We used them first time ever the other day. Removed that, gave filter a wee clean and, hey presto, all is working again. Hope that helps. Jim
Feb 26, 2008 | Indesit W 123 Front Load Washer
Indesit W1A111 starts cycle when selector set to "off"
many indesits have a memory on board, set the timer to off position, turn on the mains press start let the machine finish what it is doing, and it will reset normally, turn off at mains for a few minutes can also do the trick, it sounds like one of the option buttons was pressed and you didn't let the timer finish its course,
Aug 29, 2007 | Indesit W 123 Front Load Washer
i have same problem and have had a srvice engineer change almost everything on my machine with no success....
Jan 09, 2007 | Indesit WA 125 Front Load Washer
Indesit W 123 Front Load Washer Logo
343 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
