Question about D-Link RangeBooster G WDA-2320 (1010075372) Wireless Adapter
Installed upside-down My roommate has one of these on her old Dell. It consistently gets LOW bars/reception compared to our laptops when we put them in the same place. I tried re-installing the drivers but it didn't help. (That might have been a dumb thing to do; I'm not sure). I was just looking here on the back of her machine though and it looks like the actual device (sans the antenna) was installed upside down! So, here's the question, could that have anything to do with it? If not, since my router is all the way across the house would it help if I put it up higher on a shelf? Please help!!! thanks!
  • amilani Sep 24, 2008
    I have the exact same problem, everything you said, exactly the same. i bought mine a week ago and its so frustrating since i thought it would get a real good signal. anyways the only thing is that I think its impossible to install it upside-down, and even if it was possible it wouldnt work at all. im 99% sure. but if you solve this issue let me know, or if anyone has any suggestions. im running it on vista 64bit, but i tried it on xp 32bit, and same problem. :(
  • Anonymous Dec 05, 2008
    Same issue here. I installed it correctly into the desktop, but it barely works. Signal strength is very poor, yet with my laptop at the same location I get excellent signal strength and can browse no problems. Run a speedtest and the desktop that this card is installed in gets about 1/2 the speed as my laptop does.
    Overall, I think this is just a poor card.
Never buy d-link again i have 1000 pounds of problems with this ****. When you spend more that 120 dolars for both wireless and router from the same brand D-link. it shoould be you plug and play. and now WTF iam haveing problems never again guys never again
Posted on Dec 05, 2008
Low wireless signal strength compared to other computers - the netbook consistently reports about half the wireless signal strength that a Dell laptop sitting next to it does. in low signal strength areas...
For HP Mini 1000, the wireless device can be problematic.
I will recommend the HP Mini 210-1084. This has the fastest wireless in the HP Mini range of Netbooks.
Good luck.
Jul 17, 2010 | HP Mini 1000 Netbook
Consider me your personal technecian for a Dell Laptop
before posting any question do log on to
its a comprihensive website where you can find each and every information regarding any dell computer
and along with your question do provide system's service tag
your system's service tag located at the bottom pannel of your system, turn it upside down you will find a bar coded sticker which has a 7 digit alphanumeric number
on Jun 07, 2008 | Dell Inspiron 8500 Notebook
The last 3 or 4 cakes i've baked have sunken in the center and a little underdone.
clean the door glass so you can see easy and get a good meat thermomiter put it on a small cookie sheet or pie pan upside down. set 350 and preheat 15 min then watch temp go up and down write down the high and low is it consistantly the same.the temp half way between high and low is the average is it lower than 350. if it's all over the place the control is most likley bad. consistantly off or high and low more than 60 deg apart sensor is bad.if it's gas oven and it takes a long time for the burner to light after the glow bar comes on replace ignitor, average will be low and spread will be wide
Dec 25, 2009 | Electrolux Ovens
My dell laptop/windows xp now has a half-size, upside down screen
Hold down CTRL and ALT keys and press UP arrow to turn it back to normal. For the screen size, right click on an empty space on Desktop and select Properties then go to Settings tab. On screen resolution move the bar to adjust the screen size to your desired one.
Jul 12, 2009 | CMS 250GB HARDDRIVE 2.5 DELL INSPIRON 500...
Poor reception on my onboard wireless card in my Dell 5100 Inspir
pls see the WLAN card properties and see if power save mode is tick kindly uncheck it for best performance
by default the performace is set to low or medium performance also check the power settings and wireless settings click best performance there
pls tell me if u dont get my solution
Mar 18, 2009 | Dell Inspiron 6000 Notebook
Dell Inspiron screen upside down and no response to mouse
sounds like you have a virus bad one try downloading AVG need to unistall perious anti virus and install AVG also windows denfenders is good also .........lala linda
Jan 06, 2009 | Dell Inspiron 1501 Notebook
Asus M-51 series Laptop
You need to check the signal strength in the other room and compare it with where you were getting a good signal.
Check the other Access Points/routers in your area, are they broadcasting on the same channel, if they are then change your access point/router to a different channel.
To improve radio reception you may need to move the access point/router to another location away from solid walls etc.
Your wireless card may be as good as your roomates, if possible borrow one of theirs and set it up (configure it) for your laptop and see it it works better.
Try the other options before you buy another wireless card.
Nov 16, 2008 | ASUS M51Sn-c1 (90N-SFEA143288ECQL0Y) PC...
Task bar on bottom of screen and ribbon on top of screen disappear -- can no longer access them
why is it that it is not made clear that you have to pay to get assistance till you've taken all the time to access the site, figure out how to post, then actually post.  then here comes the money police.
I google quick, free dell monitor assistance or support and you're what I got.  I beleived you were free.
Jul 09, 2008 | Dell E773C 17" CRT Monitor
you don't have to pay for any cd
if its a dell computer you can call dell technical support 1-800-624-9896(United States)
you have to provide them your system's service tag
service tag located at the bottom pannel of your system, turn it upside down you will find a bar coded sticker which has a 7 digit alphanumeric number. you have to verify account details and it could be name of the person who ordered the system or else ph number given when the system was purchased or else address it was shiped to
DELL will send you all the cds free of cost.
Jun 05, 2008 | Dell Latitude D600 Notebook
Microphone not working
try reinstalling audio drivers
log on to
click on drivers and downloads
enter your system's service tag
download latest audio drivers
save it on your desktop
go to device manager and uninstall audio drivers
restart your system
now install the latest audio drivers from your desktop
restart your system after installing the drivers
then check if the mic is working
Jun 04, 2008 | Dell Inspiron 6400 Notebook
D-Link RangeBooster G WDA-2320 (1010075372) Wireless Adapter Logo
158 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
