Cameras Logo
pravin Posted on Sep 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lens get stuck in the zoom mode - Cameras
Level 3:
  • Cameras Master 17,130 Answers
  • Posted on Sep 26, 2011
Cameras Master
Level 3:
Answers
17130
Questions
0
Helped
3631826
Points
52372
The non-functioning of the camera can be a fault in the shutter, zoom or auto focus sections and may be due to the failure of the Main control system or the drive. A simple was is to reset and we can try by removing the battery and card for some time. Now replace only the battery and while switching power ON, tap the lens hood on the palm of your hands so as to disengage any dirt or mechanism being struck. You can spray a degreasing spray on the lens hood sides and also assist the lens as it tries to come out, attempt to pull it out slowly while powering ON the camera. Also in some cases you can slid a thin film/paper on the lens hood sides to wipe out any dirt .
Tips to open and check for common faults:
http://www.youtube.com/watch?v=v2Mj3Qp3xYU&feature=related
Use some air to blow between the lens to dislodge any sand particles struck inside. Unless you are familiar with handling of small devices must the camera be opened. If so check the voltage on the motor drive, check the auto focus and Zoom drives, it must be free with manual movement. If jammed the motor can be removed and released. If none of these works then you can think of taking consensus with the service centre.
Get estimate before you decide.
Thank You for using Fixya
Zoom Stuck in telephoto mode: I have a Canon HV20 HD DV camcorder. It is stuck in the telephoto zoom mode. It will not zoom in our out. I try to zoom both with the lever on the camera top and with the...
The most likely cause for this is a zoom lens out of place or impaired in some way. This will require disassembling the camera to remove the lens assembly and then disassembling the lens block to repair. This can be done fairly inexpensively but it's not really a user serviceable problem and should be repaired by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com.
Lens is stuck in zoom mode
you have to send the camera in for service either to the company who made it or to some other repair company.
for example
http://www.advancecamera.com/repair/
Jun 28, 2008 • Cameras
1helpful
My Casio Exilim 7.2 Megapixel camera is stuck on zoom.
ur zoom lens trrip is broken 1side dont use zoom inout strip cost 50$
1helpful
2answers
Canon powershot s2 15 shutter won't open
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help:
http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Konica Minolta Z6 camera lens won't retract or zoom out
I have the same problem. The lenses does not retract when turned off or function with the zoom control when turned on. Has anyone found a fix?
Zoom lens is "locked"
Is there a little lock switch on the lens?? My Nikon lens all have a tiny little lock and if it accidentally gets pushed into lock position it will not zoom. Barry Brown www.coralreefphotos.com
2answers
Zoom ring on 18-55 mm lens is locked/stuck
Are you sure it's the zoom ring that's stuck, and not the focus ring? The focus ring doesn't move when the camera is in autofocus.
If it's indeed the zoom ring that's stuck, you can spend more money than the lens is worth in repairs, or buy a replacement (circa 35 dollars on ebay) for dreadfully cheap. Good luck.
Zoom and shutter not functioning
that is a symptom of being dropped and stuck in a mode.
it requires total dissemble of the camera to fix or replace the lens. your lucky it takes pictures at all. most cameras refuse if the lens is stuck.
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
