Question about Canon PIXMA iP90 Mobile Printer
I have a canon Pixma i90v
The power wont come on it work yesterday i do travel could it have got bumped? would that make it not power up, any idears
  • 76 Answers
Have had it that the dcdc board goes inside the machine. You will need to contact a service engineer to repair.
I have a few contacts in the uk that will repair this for you!
Posted on Oct 20, 2008
My printer power wont turn on when i press button
Try removing your printer cartridges and then the print head from the printer. If the printer powers up with the print head removed, then the print head is either shorted or clogged. If it's shorted out then you will need a new print head (usually cheaper to just buy a new printer). If you can clean the print head without damaging it, sometimes it will work again. Usaully a good 24 hour soak in alcohol or a cleaning solution will work.
May 09, 2010 | Canon PIXMA iP3000 InkJet Photo Printer
Printer says there's no paper in it which there are
http://canon-resetter-repair.blogspot.com/
Resetter above
http://support-nz.canon.co.nz/P/search?model=PIXMA%20MP500&filter=0&menu=QA
Support site. http://support-nz.canon.co.nz/P/search?model=PIXMA+MP500&filter=0&menu=manual
manual above.
This happens when the OOP detector is either stuck, or faulty. Giver it a clean, and a bit of shake, and tap about the area of the sensor, Tale the tray out and insert it again, quite hard, try to "Jar" it gently. Often, theses sensors go faulty. You may need it repaired.
Apr 16, 2010 | Canon Pixma MP500 All-In-One InkJet...
Just wont switch on - I checked the fuse in the
Try to use different cable. you may want to check below link for any other Canon MP830 issue
http://pc-and-peripheral.blogspot.com/
Oct 19, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon Pixma MP780 printer wont turn on
Dear sir,
This problem printer power supply or power adoptar is out of order or fuse is burning
please chack it and solve this problem
Aug 27, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon PIXMA ip4500 will not turn on
Sounds like the power outage was a power surge and destroyed your printer, especially if your printer was not plugged into a power surge protector strip. Check with others in your apartment to see if they experienced the same. If so, your landlord may be responsible and can put in a claim. If your printer is still under warranty, contact Canon. Also, check to see if this item is covered by tenant insurance, if you have coverage. Hope this helps.
Jul 16, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Canon Pixma MP 830 will not power on after just using yesterday. I checked the cord and changes power oulets nothing?
If you can reach in and get the printhead to move to the center, you need to remove the printhead and see if it powers on. Many times a defective printhead will keep it from powering up.
Jul 14, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My canon pixma mp 160 not working.apear 5100 error
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
ppobmi17
Jun 22, 2009 | Canon PIXMA MP160 All-In-One InkJet...
My Canon Pixma i90v has been working great for a year and now all of a sudden the color cartridge isn't working. I've done a print head cleaning and a deep clean. The test print shows that the black works...
If the printer is not worn out, one of the first things to try is to remove the printer in the computer settings. Reboot the computer and reinstall the printer software. This ensures that you have not gotten bad or corrupted drivers.
Apr 28, 2017 | Canon Office Equipment & Supplies
Printer not working
Hi
You must download resetter software to your printer name iP tool for canon pixma.
Step 1: Reset hardware
  1. Press Resume button hold for 1 - 2 minutes
  2. Open the cover
  3. Release the catridge and then put catridge again
  4. Close The Cover
  5. Turn Off
  6. then Turn On again
Step 2: Reset Software using general tools
  • Download software resetter or general tools for canon pixma iP4500 : Download service tool for Canon iP4500
  • Driver should have been install correcly.
  • Connect USB cable.
  • Before connect power, press and hold power button then connect the power.
  • At the same time Hold power button, and press reject button for 2 times then release power button.
  • Run software resetter for canon iP4500.
  • Don’t forget to open lock release in the software. ( note : to view lock release menu, min resolution 1024 x 728)
  • Then select Set Destination to iP4500
  • Check CLEANING and EEPROM CLEAR
  • Click MAIN and PLATEN
  • Finally test print by click TEST PATTERN1.
Gud luck..
Jan 29, 2009 | Canon Pixma iP4500 InkJet Printer
My printer wont power on
For Canon PIXMA iP1800 series No Power issue. Normally is either QK1-3130-000 AC POWER ADAPTER or QY5-0194-000 LOGIC BOARD.
You may find the parts at www.comcentre.com.my
Nov 18, 2008 | Canon PIXMA iP90 Mobile Printer
Canon PIXMA iP90 Mobile Printer Logo
old marine
old marine
