Question about Dryers
Roper Model # REX4635EWO it won't start, i have changed to start switch and it didn't help, if i take a screw driver and connect the wires to it and ground it to the top of the washer it will run, can you help me figure out what it is that needs to be fixed: is it a lose wire that has come off the ground or what????? Thank you Melissa Crabtree miskatlyn@hotmail.com
  • miskatlyn Sep 19, 2008
    no not the door switch, when we connect the screwdriver to the prongs on the starter switch and ground it to the metal and have the door closed it runs, when we open the door it stops, it has something to do with the start switch, we replaced the start switch today and the same thing happened, could it be a bad wire, and someone told me to replace the start switch with a toggle switch and that would work, how accurate is that
    no it's not the door switch, when we replaced the start switch and it still didn't work, we connected the prongs to the start switch with a screwdriver and grounded it to the metal of the dryer closed the door and it ran, when we opened the door it stoped, so we know it's not the door. but don't understand y when you connect the prongs to metal iwth a screwdriver and ground it it will work
    Genius:
  • 1,028 Answers
Ck door switch
Posted on Sep 19, 2008
99 f150 6cyl- the problem started with the pickup cutting out when I would try to give it gas and speed up. I changed the fuel filter but that didn't help, I changed the spark plugs and that...
Rather then guessing as to what the problem is learn to test ! Check the electrical circuit , hook up a fuel pressure gauge , use a spark tester to see if it has spark . Do you like buying parts you don't need ? Other wise your better off having a qualified repair shop check it out .
Testing Electric Fuel Pump Problems with Voltage Drop Test
Fuel Pump Electrical Circuits Description and Operation
Test the fuel pump relay ,do you know what a relay is and how it works ? Ford fuel pump electrical analysis begins at 8 mins into the video .
Do you know what a wiring diagram is ? Free wiring diagrams here http://www.bbbind.com/free_tsb.html Enter vehicle info. year , make , model and engine size. Under system click on engine ,then under subsystem click on fuel controls . Click the search button ,then the blue link . scroll down to diagram # 7 ,this fuel pump electrical circuit .
Test don't guess
Aug 14, 2017 | Cars & Trucks
My roper dryer won't turn on. i rewired the back to put a new cord on and now it wont start
Here is a tip that will help you with changing your dryer plug.Dryer Cord and Wiring Dryer 3 Wire or 4 Wire
heatman101
Aug 23, 2011 | Roper RES7648E Dryer
Rex4635ewo dry not working
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 08, 2010 | Roper Dryers
Dryer will not turn off when I open the door. As the light will not come on, I believe the problem is the switch on the door. The door switch assembly can be ordered from Roper, but I cannot find a...
Good day,
Sounds like the door switch. Easy repair. Remove the lint filter.
Remove the 2 screws under the lint filter opening. With a screw driver, insert it between the lid and front panel on one side at a time. Pop that end up and then do the other side.
Lift the lid up and away from you.
You will see the switch. Replacing it is a pure nuts and bolts operation. Just make sure you mark the wires before removing the old switch.
The kit (It's a Whirlpool product) should be available at any decent sized appliance parts house.
Sep 03, 2010 | Roper RES7646KQ Electric Dryer
Roper washer lid switch is burnt. how to get to it? already have taken the two small screws out. The switch is accessable now. But how to change it ?
If it is soldered in, just unplug washer, cut wires at switch, solder on or use **** connectors to attach new switch. Be sure to use heat shrink tubing over new connections, do NOT just use elec tape...put shrink tubing on over the wires before connecting then slide over connection afterward, use a lighter or hair dryer/heat gun to shrink completely so as to form fit over new splice, this will prevent shorting against chassis. You can get both the tubing and connectors from Radio Shack.
Sep 22, 2009 | Washing Machines
Removing motor
Watch the video:
Jul 06, 2009 | Roper Dryers
I bought a new property which has a Roper Dryer Model REX4635EWO and a Roper washer model RAB5232EW. NO MANUALS!
Roper is made by Whirlpool. The Roper website is down and under construction. Contact Whirlpool either by email or telephone. They may be able to give you the info you are looking for.
http://www.whirlpool.com/custserv/index.jsp
Apr 18, 2009 | Dryers
Roper EL5030V Electric Dryer
yes there are two, one is on the blower housing a small white on with two blue wires connected to it, the other is on the element housing at the left top it has 2 red wires connected to it
both of these if good will read contunity.
Apr 19, 2008 | Roper REK2950W Electric Dryer
Dryers Logo
225 people viewed this question
Top Dryers Experts
