Do you get a beep at startup? A single beep means it passed initial diagnostics.
You got a problem there. Check if the fans are running. If not, either your Power supply or the switch or the main line power is the problem. If the fans are turning, try taking out the memory and expect long beeps. If it is beeping, you got a bad memory. Test with a known good one. If not, check the power from the power supply to the motherboard if it is plugged in tight and the 4 pin extra CPU power is on. If not, have your warranty card ready.
no thers is no beep
