You must have HDMI port on both TV and laptop. you need a HDMI cable to connect to the laptop. but first see that HDMI version of TV is compatible with laptop's HDMI.
There could be a few different issues that could cause the behavior you're describing. Here are a few possibilities:
HDMI connection issue: Make sure the HDMI cable is properly connected to both the TV and the laptop. If you're using a HDMI splitter or HDMI switch, make sure those are also properly connected.
HDMI port issue: If you've tried multiple HDMI cables and still have the issue, there could be an issue with the HDMI port on the TV or laptop. You could try a different HDMI port on the TV or laptop, or use a different device to see if the issue persists.
Display settings: Make sure the display settings on the laptop are set to display on the external monitor (the TV in this case). If the laptop is set to display on the built-in monitor, it may cause the display to flash on and off.
Hardware issue: If none of the above solutions help, there could be a hardware issue with the TV or laptop. It's possible that the display controller or other hardware component is faulty and causing the display to flash on and off. In this case, it may be necessary to have the device repaired or replaced.
I hope this helps! If you have any further questions, please don't hesitate to ask.
If your laptop does not have a HDMI port then you need a VGA to HDMI converter. Connect this converter to your laptop and then connect it to the TV using a HDMI cable. You also need to connect the audio out port on the laptop to the audio in on the TV. You can get a combined audio input with some HDMI converters. Check out this WEB site. http://www.proaudiovisual.com.au/vga-to-hdmi-converter-adapter-and-upscaler-video-audio-full-hd-1080p/
Buy a HDMI cable.Hook up one side of the HDMI cable to ur tv HDMI Hub.The other side of the HDMI cable to ur laptop USB Hub.That it u got a connnection,now go in ur tv input pick which HDMI inputs,u put it in,example 1 to 4 HDMI Hubs.Pick the one HDMI Hub that ur laptop it hook up in.That it now u got ur LCD tv used as a monitor.
Connect the Sony Receiver's HDMI output to HDMI in Philips TV.
You can connect a DVD player or STB to either HDMI In of Receiver or HDMI in of Philips TV.
