Question about Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835)
My computer keeps dropping the signal i have already talked with a tech i need help the signal keeps on fading and i cant get on the internet with my laptop computer.
    Scholar:
  • 94 Answers
You should try checking the wireless security & channel.
make sure if your network requires a security you should check that your typing the right one cause this is case sensitive.
make sure also to check the wireless signal of your router or Access point be sure to set that on channel 11.
Posted on Sep 18, 2008
I time Warner internet and phone line all my 5 computers working but my smart tv works some times and then it loses connection
Is your wireless connection dropping? - We Rock Your Web
www.werockyourweb.com > Tech > Troubleshooting
Jun 22, 2014 - Does your wireless connection connect, then disconnect, then connect again, only to disconnect .... I did try 1,6,11 not working it's drop away.
Samsung smart Tv and internet connection ' AVForums
www.avforums.com > Forums > Home Audio Video Forums > Televisions
Feb 23, 2013 - Chaps I have connected my Samsung Tv to the home network but it can be ... Sometime it works great, and then it drops to unusable speeds.
WiFi drops over and over - Comcast Help and Support Forums
Dec 09, 2015 | Televison & Video
I already asked the question and then had to get off the computer. The question was how do I stay on the WiFi internet through netgear router. When the WiFi symbol shows I am conneted if I go too Chro
Need to know your signal strength and if you're connected with proper credentials. If the wifi signal is weak, the computer may disconnect to look for a stronger signal. Sometimes ipv6 is the culprit on older computers too. Disable that and use ipv4 only. There are multiple reasons for dropped internet so the more info about your system and the conditions under which the internet is dropped will help in diagnosing the problem without sending you on a wild goose chase.
Dec 15, 2014 | Samsung Galaxy Tab 3 7-inch, white
There is free internet service with an unsecure wifi at my apartment building. How do I boost the signal so I can get optimal results with so many freeloaders hogging the internet?
Bummer deal! Try to reinstall the wifi. And try and move it to a different location - to see if that helps. Try higher in the air for more direct signal reach. Hope this helps.
Dec 07, 2014 | Computers & Internet
Keeps dropping signal to iPhone & computer
Hello!
I am not able to locate a model 67, so I presume that is short name for it.
Can you look at the label on the bottom and get the full model name? Examples of Netgear model names are WRN2000.
As for the signal dropping, it is possible that the router needs a firmware update. I would suggest searching for a firmware download for the modal have.
Jul 01, 2014 | NetGear Computers & Internet
We havea TRENDnet Wireless AP TEW-430APB - keeps dropping wireless
It can drop signal if there are other devices working in 2.4GHz band interfering with it. Try to switch over to 5GHz band.
Aug 29, 2017 | Trendnet TEW-430APB Wireless Access Point...
Dell inspiron e1405 cant acquire a network address?
Call Dell customer support phone number 1-800-204-4427 to get online help for technical problems related to Dell computer, laptop, printer, scanner and tablet Dell Laptop Support Phone Number 1 800 204 4427 Tech Help
May 17, 2017 | Dell Inspiron E1405 Notebook
I have had my Veralink router Westell (Model 327W) sice I hooked up with Verizon DSL in 2005. In the past several weeks it keeps dropping my signal to my other computers that i use a wireless adapter to...
hi, try to connect that particular computers directly to the router using the ethernet cable,monior the internet connection,if l the internet connection is consistent, theres a possiblity that you need to update the driver for your wireless adapter,try to uninstall and reinstall it,but if the internet connection is still dropping off,contact verizon and tel them that you are having an intermittent connection to the internet,have them check the dsl line and if possible,ask for a higher tech support to do a test assist for the connection...
thanks and God Bless
Jun 03, 2010 | Westell Wirespeed VersaLink...
Cannot get on the internet
Hi
The problem was in the wep key. I entered the old wep key, not recalling that we had to trade our router in for a new one last summer. When I entered the new wep key we were able to get online.
thanks again
Apr 09, 2009 | Linksys Rangeplus Wireless Pc Adapter
D-link dwA-142 keeps dropping internet
these dlink products in this line are **** I threw out 3 new ones buy a different brand or buy a signal booster for this product
Dec 19, 2008 | Linksys Wireless-G WUSB54G 802.11g/b
My computer keep losing signal from internet. windstream techs say the problem is not with them. my computer is just two months old and i am very unhappy please help. i usually just listen to the gospel...
Either you have dysfunctional wires on the house either is problem with your internet provider. Try contact them.
I had a similar issue. Random disconnections and sometimes tend to happened very often. Tried many things like you did and nothing worked.I figured out that the cables on the outlet where messed up due to a water leak from the upstairs neighbor.
I changed it to a new outlet of the house which was in different cables and the connection got a little more stable but not much better.
After contacting my internet provider, they sent a technician and he told me that it most likely problem from the provider. Currently im in the processes of changing internet provider.
Oct 11, 2017 | Computers & Internet
Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
96 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
