Question about Danby Refrigerators
Danby beverage center doesn't get cold enough....the lowest it goes is 43 degrees which is what the manuel even states too...but thats not low enough...is there anything I can buy to make it like 5 to 8 degrees colder?
SOURCE: Whirlpool Beverage Center (WBC127BLS) - Won't cool enough
i got it fixed. you have to know a little about wiring to make this happen, but not impossible. took cold control off old refrigerator, and wired it into compressor behind refrigerator. the cold control is no more than a thermostat that acts as an on/off switch, so the hot wire needs to be removed off the compressor and the hot lead on the cold control needs to be wired to constant voltage and the other wire on the cold control plugged into compressor where original hot wire was disconnected. you will have to drill a little hole through refrigerator somewhere to run thermostat wire off cold control into refrigerator. you now control the internal temp by the external cold control switch. if you hook it up this way you will only be bypassing the original cold control on the whirlpool, but will still have your digital readout of internal temp. mine now reads 32 deg. and if the beer is in the back of refrigerator it will have ice in it, just the way i like it.
Posted on Mar 02, 2009
  • 27 Answers
SOURCE: danby freezes all beverages
check position of thermistat bulb it should be on the plate
Posted on Jul 29, 2009
honeymokey
  • 3113 Answers
SOURCE: Fridgadaire beverage center too warm
It should get cooler than that at least down to 33-34 degrees. Be sure you have air flow behind the unit, not pushed against wall. Feel for cold air coming from freezer to lower part just behind light bulb. If it is not turning off and defrosting they will do this as ice builds up and results in no air movement. you may want to remove the cover in the back of freezer and see if it is froze up. Or just turn it off and defrost and start back over the next day. The defroster timer may also be bad and it is under cover beside the light bulb.
Posted on Jun 15, 2010
ZJLimited
  • 17970 Answers
SOURCE: I have the Danby Model
Are you tray to "reset" the unit; disconnected power few minutes (five before to reconnected again).
If the problem come on again, try to set the temp manually accordign the User Guide.
Keep us updated.
Posted on Apr 28, 2011
imufo2
  • 3773 Answers
SOURCE: Can i get my danby model no DAR604BLS to be colder
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If
you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Posted on Sep 09, 2011
Purchased in 2010. Temperature doesn't fall below 55F. Fan works. Sounds like compressor is working. Haven't physically inspected compressor. Used to cool to 39F.
May be both. Is the evaporator blocked or have ice built up on it? If so there could be two reasons for that. Low on freon or not enough airflow inside the cabinet.
Aug 08, 2015 | Danby Silhouette Series DBC514BLS 5.3 cu...
My danby wine cooler does not get cold enough
Cool enough? You know most wine and beer only like it about 50 degrees and not any cooler. If it up at 55 and you have set it lower then the room is probably warmer then it can handle to cool them. I have some in the garage but in July and August the struggle to stay any cooler then 55 but then they are not expensive units either. Danby is cheap brand too. Nothing they make is that great.
Oct 07, 2014 | Danby Refrigerators
DANBY dbc657bls This is a beverage fridge by Danby Designer. I have 2 of these fridges and one is just starting to get ice build-up at the back. I have defrosted it a couple of time and the problem of...
you have a door seal leak, the ice is from outside air getting into the cooler, you might also check for an air leak it the service door in the bottom back of the cooler.
Jan 21, 2011 | Danby DWC610BL Wine Cooler
Not cold enough
Just some general info on Danby Kegerators. The temp fluctuation is 32-42 degress thru out the day and for 1 hour a day you will get a temp of 46-48 degress during defrost. Unfortunatly there is no way to bring these coolers colder than 32 degrees.These Keg coolers need to be in a temp controled enviroment and if it is enclosed in a cabinet you need to have 3" opening on all sides for air to circulate. Some of the main fault codes are EE = open sensor and LE = which is a communication error between the display board and the main board. The LE error may be in the touch pad which gets moisture in the membrane and causes the pad to quit responded sometimes the error can be solved by simply disconnecting the molex plugs from the boards, straighting out the pins and reinstalling
Sep 17, 2010 | Danby DKC645BLS Compact Beverage Cooler
Frigidaire refrigerator with a broken freezer
He is correct. The temp in the refrig controls how often and for how long the refrig runs. Lets say the temp in your garage is 34 degrees, and you have your refrig set to 36 degrees: The refrig will never run, the fresh foods section will cool to 34, and the freezer will warm to 34. Even if the temp is 45 in the garage and you set the fresh foods to be 33, the refrig will not need to run long enough and often enough to keep the freezer temp cold enough. You will most likely need to have the ambient room temp at least 55 degrees to get satisfactory refrigerator performance. Insulating the refrig will not help. (by the way, outdoor beverage vending machines use an internal heater in cold weather to prevent liquid beverages inside from freezing,..... so using that info, you could put a low wattage heater in your refrig to make your refrig run enough to make the freezer section work. The %&#* with that, just move it into the house!)
Feb 06, 2010 | Frigidaire FRT17B3A Top Freezer...
Danby freezes all beverages
Jul 26, 2009 | Danby DAR259BL 2.6CF Silhouette Compact...
Avanti N252BG beverage cooler does not get cold enough
Brand new installed avanti beverage cooler. In a basement undercounter so room temp. around 65 degrees. Only gets to around 45 degrees inside even though temp is set to 34 degrees. Most of the time it sits for days without being opened but still not cold. Any suggestions on how to fix this problem?
Mar 26, 2009 | Avanti N252BG Beverage Cooler
Dec 26, 2008 | Frigidaire FRTB7B4EMB Top Freezer Beverage...
If you're handy with a soldering iron, it's possible to 'trick' the fridge into cooling down a few more degrees.
Long version:
If you open the door to the fridge, on the right wall near the bottom is a small plastic grate. You should be able to pull this straight out from the side wall. There is a temperature sensor attached to the back of the grate. Unplug the sensor. (The fridge will then give you a very annoying error beep and display "EE" on the readout. Pushing the °F-°C button stopped the beeping.) This sensor will change resistance with temperature. (The lower the temperature, the higher the resistance) I was reading a resistance of about 3700 ohms at 43°F and 2460 ohms at 68°F. Throw in a rough assumption that the response is linear and it works out to almost 50ohms/degree. In order to 'trick' the fridge into cooling down more, you need to drop the resistance. I was aiming for about 6 degrees cooler. Assuming the resistance response was linear, 6 degrees cooler would give me about 4000 ohms from the sensor. By jumpering a 50000 ohm resistor (yes, 50K ohm) in parallel with the sensor, I should get about 6 degrees cooler. I did the soldering, plugged the sensor back in, and ended up about 8 degrees cooler. Two days so far, everything appears good and the beer is cold.
Short version:
Put a 50K ohm resistor in parallel with the temperature sensor behind the grate on the inside right hand wall.
The temperature read out will be inaccurate forever after though. But then, I just want cold beer, my wife wants cold water, and the kids want to play with the cool blue light. I don't care what the number on the readout is.
Oct 03, 2008 | Refrigerators
Refrigerators Logo
37 people viewed this question
Top Danby Refrigerators Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
jason
Are you a Danby Refrigerator Expert? Answer questions, earn points and help others
