Question about Xerox Phaser 6350/YDT Laser Printer
The menu screen is blank
There fore I get no info as to what the printer is doing or which cartridge is low. Printer works, just can't read any info!
  • Anonymous Mar 26, 2009
    **** printer
    Director Badge:
    Uploaded 100 video answers.
  • 160 Answers
If your 6350 has a blank display the most common reason is a bad control panel. It takes about a minute to replace and is very easy. Hope this video helps! Enjoy ">
Posted on Feb 03, 2011
If the printer is network capable you can have xerox trouble shoot the printer on line at the xerox
support centre, if it's not network then you are going to need a replacement display.
Posted on Nov 30, 2008
Does not print with new ink
The HPs are notorious for not recognizing the cartridge after a few replacements in my experience. On the information screen is it saying the cartridge is not in or ink is low? You can have the machine, through the menu, do a cleaning of the heads. If this does not work then I have a low tech solution to fix the seating of the cartridge. I put a wadded up paper towel in the door to hold the cartridges firmly in place and the printer reads it fine then. I do have a different model than what you are showing but there has to be a way.
Sep 28, 2012 | HP DeskJet 970cxi InkJet Printer
Reading no paper paper tray is full
Instructions
  1. Check the display for an error message. If the display reads "Clearing paper from printer," the engine has detected a jam and is attempting to eject the jammed pages automatically. These pages will often be blank.
  2. Check the display for "Performing PRINT/STOP TEST" or "Performing SERVICE TEST." Either of these messages indicates that the printer is going through a test procedure that may eject blank pages.
  3. Reduce the amount of paper in the input tray if the printer is feeding multiple blank sheets at a time. The printer will pull extra pages through if the input tray is overfilled.
  4. Replace the paper in the input tray with the correct size if needed. If the 4600 printer detects the paper as an incorrect size for the print job, it may eject the paper without printing anything on it.
  5. Replace the ink cartridges if certain colors are blank on the page. Replace the black cartridge if printing a black text document that is coming out blank. The printer may attempt to print even if the ink level is low or empty, but will unable to print anything on the page, causing it to come out blank.
  6. Remove the sealing tape from newly installed cartridges. The tape covers the print heads and should be removed before installing the cartridges. If the tape is left on, it will prevent ink from getting on the pages as they print.
  7. Press the "Check mark" button on the control panel to enter the printer menu. Run a diagnostic so the printer can attempt to determine the cause of the blank pages printing. Press the up or down arrow to select "Diagnostics." Press the "Check mark" button. Press the "Down" arrow to highlight "PQ Troubleshooting." Press the "Check mark" button. The printer runs a diagnostic and returns to a ready state when done.
Jan 08, 2011 | HP LaserJet 4600 Printer
I have a canon pixma mx320. I purchased on line refillable ink cartridges. The problem is the printer will not let me copy, print or even fax. The screen keeps reading black ink volume level not readable....
Go into the Canon Printer Utilities. Click on Solution Menu folder. Click on Solution Menu icon.
A new window will open up. Click on "Change settings or find solutions to problems.
A new window will open up. This screen will give you 3 selections to choose from.
They are: Printer Settings, Printer Status and Troubleshooting. You will be able to reset your ink cartridge levels from these windows and try to print again.
Dec 22, 2010 | Canon Office Equipment & Supplies
My printer now only prints blank pages.
try wiping the contacts (gold colored spots) with a tissue, and after wipe the ink despensing end.
Dec 03, 2008 | Lexmark Z600 InkJet Printer
Overiding Empty Cartridge error for Dell A10 962
maybe it have the ink level chip which can be resetted by removing the cartridge and oning and offing the printer for 5 times within 10 minutes coz it saves data of a cartridge upto 5 use before only.. and 6th time insert it.
Nov 15, 2008 | Dell 962 Photo All-In-One InkJet Printer
Clearing message after "replace photoconductor kit" message came on
To reset the photoconductor page count:
  1. Turn off the printer.
  2. While the printer is off, press and hold the Select (pattlnk_1262005_1956-enus20772_selectbuttonicon_t64x_en_us.gif) and Return (pattlnk_1262005_1950-enus21096_returnbuttonicon_e340e342_en_us.gif) buttons on the operator panel.
  3. While keeping both buttons held down, turn the printer back on. Keep holding down both buttons until the printer screen displays Performing Self Test or CONFIG MENU.
  4. Release the buttons when you see either of these messages.
  5. If Reset PC Cnt does not then appear on the screen, press the left or right menu button until it does.
  6. Press the Select button once. The message Resetting PC Cnt Value should briefly appear on the screen, indicating that the photoconductor page count has been reset.
  7. When the display shows CONFIG MENU again, power off the printer.
  8. Wait five or more seconds and then power the printer back on. NOTE: Do not hold any buttons down when powering on the printer during this step.
    The photoconductor page count should now be reset. At this point, it is recommended that you print a menu settings page to confirm this. Do the following:
    1. With the printer at the Ready status, press the left or right Menu button until UTILITIES MENU appears on the screen.
    2. With UTILITIES MENU on the screen, press the Select button once. A new menu should appear.
    3. If Print Menus is not displayed on the second line of the screen, press the left or right menu button until Print Menus appears.
    4. Press the Select button once. The message Printing Menu Settings should appear on the screen and the printer will print out one to three pages of printer settings.
    5. Look for a heading labeled Cartridge Information on one of the menu settings pages.
    6. Under Cartridge Information, look for the word Photoconductor. Confirm that the level of the photoconductor says OK or is close to 100%.
    7. If the photoconductor is still reading low, try printing 10 - 20 more pages.
    8. Print the menu settings page(s) once more. Confirm that the photoconductor level is now at OK or close to 100%.
    9. If the photoconductor continues to give a low reading, repeat this entire procedure again from the beginning to reset the counter once more.
    10. If the photoconductor reading is still low after two attempts to reset the counter, the printer may require service.
Jul 28, 2008 | Lexmark E342n Laser Printer
I would take out both cartridges and put them in again. Realign the printer and the error codes should remove themselves. Try turning the printer off and on before puting the cartridges in again. That may make a difference. You can let your computer know not to tell you when the ink is low too. Let me know how this work for you.
Cynthia Charczenko
Dec 26, 2007 | Dell A940 All-In-One InkJet Printer
Brother DPC- 115C
What error does the machine show up?
Plz give some more info in detail!!!!!
Oct 24, 2007 | Brother DCP-110C All-In-One InkJet Printer
Xerox Phaser 6350/YDT Laser Printer Logo
452 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
