Question about Mitsubishi WS-55511 55" Rear Projection Television
Convergence issue with WS 555111
Picture is blurry, and the convergence adjustment doesn't help. How can I fix this?
  • 927 Answers
Good Day;
Sounds like the Convergence IC has failed. Replace > STK393-110 > part # 267P155010 > TV uses one IC. Good Luck, big IRISH.
Posted on Oct 01, 2008
  • MICHAEL MULLINS Oct 01, 2008
    Good Day;
Blurry picture
By focus is the set looking 3d etc--called a convergence issue---if so go into the menu with the Mitsubishi remote and see if it will adjust---if off and will not adjust in some area of the screen the set needs the convergence chips replaced.
If convergence is good and not the issue describe the problem a bit more----these sets have 3 picture tubes with lens---from rear of set (safest way) the lens can be cleaned with a lens cloth---dust on them will make the picture look darker and dull looking and usually is done one time a year--do not try to adjust anything until you try this first.
Nov 05, 2012 | Mitsubishi WS-48311 48" Rear Projection...
Mitsubishi ws-55515 intermitent blurry picture
A bad connection somewhere--when it happens if picture is 3d look in menu for convergence and call up the grid of lines--if they are not perfect you have convergence issue which usually requires parts to be replaced.
In this set sometimes the chips will become flaky and convergence will jump in and out.
May 05, 2012 | Televison & Video
I finally got my tv hooked up. but the color and the picture is blurry, mostly on the top. i have tried different things but no matter what it doesn't change the blurriness,and some lines come across...
Tv have a R,G,B colors lines misalignment,have picture shadows or 3D picture look alike?Yes,than tv have a problems known as a convergence problems,it is dead.The tv convergence board must be repair,by replacing like 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop will cost u like $300-350 for parts and labors.
Jun 13, 2011 | Toshiba 57H81 57" Rear Projection...
The picture on my Mitsubishi WS-65511 TV suddenly went blurry (looks like a 3D movie without the glasses). Is there a menu option that I can use to fix it myself?
No,tv have a problems known as a convergence problems,it is dead.This problems it is the tv board that call the convergence board it is dead.This convergence board must require to be replace 2 STK convergence ICS and some or all of it resistors too on the convergence board too.To fixed the tv convergence board to solved the tv convergence picture.The shop,will cost u like $300-350 for parts and labors.
Apr 19, 2011 | Mitsubishi WS-65611 65" Rear Projection...
My rear projection tv is blurry and after i adjust the convergence, it goes back blurry again and i start over.
You have defective convergence. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the problem, how to fix it and where to get the parts. Let me know if you need more help.
Thanks for using FixYa and for the generous rating.
hardrocko
May 12, 2010 | Mitsubishi WS-65809 65" Rear Projection...
Blurry,double exposure picture
Ur convergence is dead.Must replaced convergence ICS and all it resistors.U know how to solders?Buy a convergence kit at Websites Tv repair World.com,Tvrepairkit.com replaced what in the convergence kit.
Jan 11, 2010 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-65611 Repair kit from TV-Repairkits.com no fix.....
I have a few ideas but they all will require some more information from you. I know these sets very well-if you fixed the convergence problem my hat is off to you--it can be a do it yourself job but not the most easy set to do it on.
Let me assume you adjusted the convergence in the customer mode--it does on any of the HD models have to be adjusted in the regular and then the HD modes.
The only other thing here that may be the problem is FOCUS. A simple way to determine this is to remove the back cover--turn the set on and call up the advanced convergence grid---then cover the lens for each tube one at a time--with red and blue lens covered are the lines in sharp focus or look blurry?
Repeat this with only red or blue not covered and see what you think--if one of the tubes is out of focus you will see it there--
There is also a TECH menu for adjusting the convergence-like the customer menu but it saves the adjustments into the set's memory--you will need to hit menu and a four digit code based on the actual model number of the set.
Check to see if focus is or is not your problem-easy to tell--green, red, blue lines will either be sharp or out of focus--if out ask and I will tell you the simple way to adjust that.
If this information has helped you rate this solution as I do this here for free.
SD TECH
Dec 22, 2009 | Mitsubishi WS-65611 65" Rear Projection...
Hitachi 57F500 blurry picture
How can I fix it? The magic foucs goes to two or three lines and goes back to the picture. The sides are blurry, like red and green.
Mar 18, 2009 | Hitachi 57F500 57" Rear Projection...
Convergence problem and cropped picture
your tv is under convergence problem usually we need to replace 2 big integrated circuits in the convergence section, at this point you may need a good tech to come over to your home
Nov 13, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Red convergence wont move
if the red line is blurry and you have adjusted the screen focus control and does not work then you prob have a bad red CRT or bad red CRT fluid.........
convergence STK have nothing to do with the red being blurry
Dec 09, 2007 | Mitsubishi WS-55809 55" Rear Projection...
Mitsubishi WS-55511 55" Rear Projection Television Logo
264 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
