Question about Lexmark Office Equipment & Supplies
Need to set up printer on line - Lexmark Office Equipment & Supplies
  • 399 Answers
Click the start icon on the left side corner on your pc---then click printer and faxes----then right click the printer icon which you are using -----then in that the ON line / OFF line option will come .do it on line by clicking the on line option.
Posted on Sep 18, 2008
Need to install Printronix p5210 via LPT cable
in same way as well as generic printer installed on pc
Jan 02, 2013 | Printronix Line Matrix P5210 Printer
Dpu 414 stacks lines
Set SWDIP switch 1, switch number 4 to ON. That switch controls whether when you get a CR (Carriage Return), you get just that carriage return or a CR-LF (carriage return + line feed). You need the latter. Setting the switch to ON will accomplish that. Have a good day.
Jul 02, 2012 | Seiko DPU 414 Matrix Printer
TOSHIBA e-STUDIO232 fax settings for VoIP line
No settings, a fax machine will not work reliably on a Digital Phone Line.
Apr 12, 2010 | Toshiba e-Studio 232 Black and White...
6122 deskjet prints test page fine but only prints one line on the paper for all other print jobs.. what is wrong?
Is it almost a solid line? This may be an application problem. Are you printing text?
I have seen this in two flavors:
1) If there are switch settings for this printer you want to make sure that the printer is set for CR/LF ( Carrier Return/Line Feed). This tells the printer to Return the printhead to the start of the line and the LF command tells the printer to step up the page.
2) If you are connected serially, the parity bit may be set incorrectly. Depending on the parity,the bit could printer if set for even parity but the sending PC is set to EVEN parity can cause a LF command to get ignored and the symptom is the lines print on top of the first line.
Feb 05, 2010 | HP DeskJet 6122 InkJet Printer
Jobs go to the print que, but nothing prints,
There are a few possible problems:
1. The printer is set to off-line. Go to start, select printers and faxes, then double clip on the printer icon, check the options under the printer tab. See if it is set to off-line, uncheck the option.
2. The printer is not connected? Too obvious, but check it.
3. The printer is set to off-line. Check the printer buttons.
4. There is no paper in the printer or the paper tray is not properly set.
5. There is some other problem which generally causes the printer to go off line.
Jan 28, 2010 | HP LaserJet 1020 Printer
Why is my Zebra printer printing every other label?
The labels you are printing have an extra line feed (a blank line) after the last printed line. Remove them.
Remove any "FormFeed" from the label run, if you are doing a "merge".
Line 1 Name
Line 2 Address
Line 3 Address2
Line 4 City St Zip
Line 5 <Blank>
Line 6 <Blank>
Sep 21, 2009 | Zebra LP 2844 Thermal Printer
How to set page length in computer for dot matrix printer model wep 800DX
to set up page length in inches
?? chr(27)+chr(67)+chr(0)+chr(12) - for 12" page length
to set up page length by lines
?? chr(27)+chr(67)+chr(50) - for 50 lines / page
Jul 20, 2008 | Epson LQ-2180 Matrix Printer
Cannot send out faxes
Directly from the wall, phone line should be connected to to Line port at the back of the printer and answering machine should be connected to EXT. port from the back of the printer. Make sure on the fax setting on the printer that you have all the info already ( ur number and stuffs), communication setting on the printer, drd set to all, ecm to off, v.34 to off, rings to answer 6 and dial tone detection to off. and answering machine distinctive ring pattern should be set to 4rings.
And since you are using DSL make sure that line from wall should have a filter then connect it to LINE port at the back of printer...
Apr 03, 2008 | Epson Stylus CX9400 Photo Printer
It sounds like there is 12 inch form length (or may be A4) selected on the computer system. The data from the system will take precidence over the 11 form length set on the printer.
If using Windows, ensure the Printing Preferences in the pritner driver are set to 11 form, Also check Printer Properties for a paper size ensure this is set to 11 inch
On the 'System' check the paper size selected within the application (if available) Check this is set to 11 inch form length
Check document margins to ensure these are not reducing the 'printable area' on the page. If availabe to a Print Preview on system to see what the document looks like.
If your application outputs raw data to the printer, check the number of lines per page assming printing at 6 lines per inch you can fit 66 lines on an 11 form. Check no more than 66 lines are per page, it sounds like 72 might be being sent befor a Form Feed in the data. (there may be a 1 line top margin set on the printer)
Finaly check the top margin setting on the printer to ensure it is set to 0 so you have the full 66 lines available on a page on the printer I think you would be looking to set the FORM ADJUST to 0 to adjust the top margin
Feb 22, 2008 | Tally T2250 Matrix Printer
Printer goes offline
Set IP of printer manually and make sure AutoIP is off. Printout user settings to ensure.
Dec 11, 2007 | Brother MFC-7820N Printer
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
