Question about Mitsubishi HS-U540 VHS VCR
Manual info needed
For Mitsubishi U540
I need an owners manual.
Here is a link to the manual you've requested:
Mitsubishi HS U430 User Manual
best of luck!
Apr 13, 2016 | Mitsubishi HS-U540 VHS VCR
Manual hs-u530 VHS VCR
This is a pretty old unit---try to Google the model number with "manual"
May 19, 2012 | Mitsubishi HS-U540 VHS VCR
Mitsubishi HS-U540 VHS VCR How do you connect the red, white, and yellow cables?
The RED is Right Speaker the WHITE is Left Speaker and the YELLOW is for
Video. They connect with RCA Cables to the same color coded inputs on yout TV.
You may find it easlier to just use a CoAxial Cable; Use a CoAxial for the CABLE IN to the Cable Box then 1 CoAxial from the Cable Box OUT to the VCR IN then use 1 OUT from VCR to TV IN. That is much easlier then using RCA Cables.
Aug 14, 2010 | Mitsubishi HS-U540 VHS VCR
Where do I find the input select? i am trying to connect a video game to my vcr which is a mitsubishi hs-u540.
Usually there's an input select button on a VCR's remote. You just press that, and it should work. It usually does.
Feb 15, 2009 | Mitsubishi HS-U540 VHS VCR
Onscreen display is in spanish
Do you have a menu or setup button on the VCR's remote? If you press that, you'll have to look in the menu until you find the language selection. Oh, wait. If it's in Spanish, you might need a Spanish to English dictionary, too.
Well, good luck, and just ask if you need more help. I hope I gave you enough info, but the menus vary with every VCR, so I can't be too much more specific.
Jan 14, 2009 | Mitsubishi HS-U540 VHS VCR
Need a manual - screen is all in spanish
Hit menu on the remote or on the tv and then view the choices. there will be one for language, change it to your preference. ole'
Mitsubishi U54 VCR Recording Speed
If you have a remote, there should be a button labeled "SP/EP" or "RECORDING SPEED." Otherwise, I might try looking in the VCR's main menu.
Aug 09, 2008 | Mitsubishi HS-U540 VHS VCR
How to remove app
go to the apps options and there should be delete as one of the options.
Feb 22, 2008 | Samsung SCH-u540 Cellular Phone
Input selection
Many of the late VCRs have very limited funtion from the VCR buttons. Power, eject, play, perhaps channel selection, that is about it for most. I assume you don't have the manual? Looked on Mitsubishi website, didn't list a manual for your specific model, perhaps another model would be close enough. http://www.mitsubishi-tv.com/j/i/18344/OwnersGuides.html?tid=5&f1=2005&s=3 Replacement remotes here: http://www.vcrremotecontrols.com/Mfrs/Mitsubishi/MitsubishiVcr.htm
Aug 22, 2007 | Mitsubishi HS-U540 VHS VCR
Open Questions:
Mitsubishi WS-65511 Rear Projection Big Box TV resets with a green flashing light every 5 minutes, Then works fine for 5 more minutes (perfect picture). Acts up worse when cold. Warm it up Works hours It's NOT the DM board caps. I've already replaced the DM caps twice. Not the problem. No repairman will look at the set. Too Old. So am I. I could repair it with help. The power supply must have a safety circuit that will shut down & reset if too much draw. I DON'T have a diagram. I'm not sure how to trace it . Which board? If I unplug boards one at a time, Will it damage other boards ? I know it is NOT the 7 DM board caps everyone keeps telling me. I see no burn't parts, No bulging caps. Tapping on components doesn't reset. What kind of component would act up when cold , But not overdraw when warm? This set has the best beautiful picture when it runs. If you can get past the resetting every 5 minutes for the first hour, You can watch it sometimes for 20 hours. I've left it on at night & it is still on the next morning. Change the channel Or raise the volume, And off it goes. Once or 10 times, Keeps resetting. Then on for 4 or more hours, Maybe. I can't afford a new one. It works GREAT ! when it works. I've notice that even when the set is turned off, The green light starts flashing (resetting itself while it's off) , Then stops. Once in a hundred times it will kick off the breaker & you need to push reset with a pin on the front panel next to the green light. It's probably a 10 cent resistor OR a $ 1.00 cap. If I only had someone with more knowledge than me to help. I know how to use a meter & read a schematic. I built a Heathkit 25"TV in the 70's & all my novice ham gear. I'm 64 & not familiar with digital circuits. Can someone help PLEASE ?
Dec 16, 2017 | Mitsubishi Televison & Video
Mitsubishi HS-U540 VHS VCR Logo
49 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
