Comfort zone 1500 infared heater
On temp display area, it says [doFL], and so it won't let me put tempurature numbers is so i can use the heater. how can i get the display to clear, or can you tell me how to clear it so i can enter temp number to start heater. thanks.
  • 1 more comment
  • Anonymous Dec 14, 2008
    mine is doing that too.
  • Anonymous Jan 10, 2009
    mine too
  • Anonymous Mar 18, 2014
    Tried holding down buttons to clear and set the temp. It will take the temp but then continues to flash the AO5 and you also hear a clicking sound. Fan never comes on and display does not clear out.
I have the exact same problem. How did you get it fixed ?
Posted on Oct 26, 2008
  • guest98761 Nov 19, 2010
    According to the call line, hold down the up, down and enter at the same time to clear it. I traded mine in before trying this so I am not sure if it works or not.
With Comfort Zone infared heater - how to change from C to F
Chances are this is not possible. Just figure out the temp you want in C and set it to that....
Jan 10, 2017 | Comfort Zone Heating & Cooling
I have a comfort zone infared heater the buttons will not work can power it on and off can control speed but nothing else
The thermostat may be fried inside. Try having it replaced at a Electronics store like Radio Shack or a YouTube tutorial video may provide you with the process of replacing the thermostat. The part should be fairly cheap.
Apr 27, 2016 | Comfort Zone Heating & Cooling
Infared heaters fan runs to long why
Defective temp sensor for the fans or the unit is just running to hot due to placement
Jan 16, 2012 | Comfort Zone Heating & Cooling
I have a Comfort Zone CZ1500W showing an AO5 error code. I have 9 ohms across each element. The fan thermostat reads open. When I bypass it the fan runs, but no heat. The element thermostat reads
Everytime I turn on the CZ heater, the display reads A05 and then it goes away when i set the temp. As far as I can see and feel, I'm not experiencing any issues with the heating, fan, or thermostat or the extension cord running hot. I'm concerned that something could be wrong or unsafe, with Comfort Zone filing for Chapter 7, anyone know who is offering support or a number I can contact?
Dec 02, 2011 | Comfort Zone CZ1500WC Infra-Red...
My comfort zone infrared hearter has a display message of A05 and will not run, what does that mean? How can I fix it?
Hi. I have the Comfort zone 1500 (cz 1500) and just ran into this AO5 problem. Turns out the thermostat was set lower than the actual room temperature. I just turned up the heater temp and it kicked right on. Hope this helps!
Nov 16, 2010 | Comfort Zone Heating & Cooling
My Comfort Zone Infrared heater by Earthwise is showing two different faults on the display, ao5 and doFL, what do they mean?
this means if it does not reset by pushing up,down,enter and clears and no heat then the main control board is shot i have 2 in my shop and the capacitors have popped
Oct 30, 2010 | Heating & Cooling
How do you change from celcius to farieheit on comfort zone heater
To change your heater display from Celsius to Fahrenheit: press and hold the "down" button and the "enter" buttons simultaneously for 5 seconds and release.
- VS
Nov 28, 2009 | RTO Comfort Zone Electric Portable Space...
Comfortzone display ''dofl''
According to the call line you have to hit the up, down and enter buttons at one time. Did not try this as I returned mine before I got an answer. No problem with the new one!
Jan 10, 2009 | Heating & Cooling
Heating & Cooling Logo
937 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
