Question about DISH Network Televison & Video
Combining output from dish home distribution with ota antenna
I have a Dish TV dual tuner receiver. I have combined the satellite signal from the home distribution output and an OTA antenna signal with a diplexer. At the remote TV, I connect that cable to the TV antenna in. I can get the local stations in HD just fine. However, the satellite signal suffers too much. Even if I use a diplexer to split the signals at the remote TV, and plug in only the satellite signal, it doesn't look good. The remote TV is set to receive the satellite signal at channel 21.
  • 1 more comment
  • wuthrich Sep 24, 2008
    I have included a diagram of my current setup. Thanks so much for your help. Before I try this, I have some questions/comments:
    1. A Dish TV technician installed the system before I bought the HD OTA antenna. The black box in the diagram is a splitter. Is that different from a separator?
    2. Is the port that the aqua colored line is going into the Home Distribution port?
    3. If so, that aqua line is carrying a satellite signal and it is being combined with an antenna signal at the red box. How come that can be a splitter (instead of a diplexer) if it is combining 2 different signals?
    4. Lastly, I forgot to mention that there are actually 2 remote TVs. The other one isn't HD, so I didn't care about it getting the HD OTA antenna signal. Can I still have 2 remote TVs? If so, how will it change the diagram?
  • wuthrich Sep 25, 2008
    Bingo! First of all, you were right about the device that connects to Tuner 1 and Tuner 2. It is a separator, not a splitter. When I connect my system like the diagram above (using splitters instead of diplexers to combine the OTA antenna signal and output from Home Distribution port), I can get a great satellite picture on the remote TVs and also get the local channels in HD on TV2. You were also right about splitting, combining, and splitting the antenna signal. The reception from one of the distant transmitters breaks up now and then. I will check into getting an amplifier. Thanks so much for your help.
  • aaron
    aaron May 20, 2014
    its set up fine its just on the receiver menu the optus d1 option has gone how do i get that back
  • 374 Answers
You should have your system setup in the following manner below:
You also will only be able to receive the HD locals with a HD OTA antenna. It is possible that you will need to turn the satellite off in this room to view the OTA's effectively.
Also you should use a splitter as depicted in the picture by the red boxes to combine signals of this frequency. The blue box is the diplexer on the incoming satellite feed and the black box is the seperator that most dual tuners use. If yours does not utilize this device you will have another cable coming from the outside of the house to the back of the receiver. The location of the ports on the back of the receiver in my diagram may differ in position on your receiver so obviously connect them to the proper port. I hope this ressolves the issue and there is no need to seperaate the signal at the remote tv as it will only be a duplicate of the same signal you have connected already as OTA and the TV2 backfeed are of the same frequency range.
Posted on Sep 23, 2008
  • Jim Franks Sep 24, 2008
    Okay, working with your diagram the fuchsia line is the satellite signal that is 950-2150 mhz it runs into the sat port on the diplexer and combines the signal with that of the OTA line which is orange and enters on the UHF/VHF port. The combined signal then represented by the green line then exits the in/out port and enters the same port on another diplexer behind the TV1 the SAT port carries the high frequency signal into a DPP seperator. This device allows the seperation of of the 950-2150 mhz signal into two seperate bandwiths 950-1450mhz for tuner 1 and 1650-2150mhz for tuner2. It employs bandstacking technology allowing the Dual Tuner to believe it has two incoming satellite feeds. the seperator will have two lines leaving it that go to the Tuner 1 and 2 ports on the receiver. Splitters do not allow for the seperation of signals and diplexers do not allow for band translation so neither will work in this application correctly to replace the seperator. The VHF/UHF port of the diplexer behind the tv will need to be connected to the OTA antenna port.
    The home distribution port has had it's signal stepped down and now does not require a diplexer to combine its signal with the OTA signal. If you run the home distribution and the ota into a splitter and combine the two signals you can now split that combined signal and go to both of your remote tvs.
    This is based on the use of a DPP LNB. If you were to use a dish pro you would have to have two sat lines to the back of the receiver eliminating the seperator.
    As to the number of remote tvs you can have there is no limit but with each splitter or break in the cable you will have db loss degrading the signal. This can be overcome with the implementation of an amplifier. The biggest negative are that all remotes tv will be mirror images of the TV2 and will not be able to view different programming independent of each other. A modulator can change thiis but is expensive or you could add additional receivers and accomplish the same goal.
    I hoe this clarifies things for you a bit. Need anything ellse feel free to ask.
I have aquired a dish dvr, i do not have the dish servicem however. I want to know if i can still record a program and watch it later. Thank you
It is highly unlikely. The unit unlikely has any inputs other than the coax cable coming from the satellite dish. This will is the same 75 ohm cable connection you see on your tv used with antennas or cable service, but the tuner in the satellite box only decodes satellite signals.
Sorry about your luck. I recall some manufactures such as LG making DVD recorders with hard drives inside them. Those units can capture any analog signal. Another idea is to get a TV tuner card for your computer.
Jan 05, 2015 | Televison & Video
What is a converter box for tv
A digital television adapter (DTA), or digital-to-analog converter [set-top box], or commonly known as a converter box, it is a television tuner that receives a digital television (DTV) transmission, and converts the digital signal into an analog signal that can be received and displayed on an analog television set. It may refer to over-the-air broadcast television signals received by an television antenna, or to cable TV systems which switched to digital cable. It normally does not refer to satellite TV, which has always required a set-top box either to operate the big satellite dish, or to be the integrated receiver/decoder (IRD) in the case of direct-broadcast satellites (DBS).
In North America, these ATSC tuner boxes convert from ATSC to NTSC, while in most of Europe and other places such as Australia, they convert from Digital Video Broadcasting (DVB) to PAL. Because the DTV transition did nothing to reduce the number of broadcast television system standards (and in fact further balkanized it), and due to varying frequency allocations and bandplans, there are many other combinations specific to other countries.
Feb 21, 2013 | Polaroid FLM-3232 Television
Dish satellite diplexer issue
Partial solution: I have had rabbit ears sitting on my roof, somewhat tied in with my dish, for close to two years. It's just a matter of running a coax out.
Sep 01, 2012 | DISH Network ViP722 DTV Receiver /...
Have new E370VL hooked up to Dish Network via coax. The picture jumps/blips? Connections are tight. Help.
This can happen when there is radio interference near the coaxial cables. Sometimes the interference is behind walls. The solution is to try a different combination of modulation and channel than what the DISH receiver is current set.
The DISH menu screen for this setting is Menu-6-1-5. With dual-tuner receivers, typically "TV 1 Out" is the TV that is connected in the same room as the receiver is located. "TV 2 Out" is the tuner that is fed to the remote TV via backfed coaxial signal.
All that needs to be done is to change the channel and mode going to the effected TV to something different. If your channel/mode is currently set to Air/60, try changing it to Cable/73. When you change the mode/channel in the DISH receiver, you need to set the remote TV to the same mode and channel.
Keep in mind that with some TV companies like VIZIO, they call their "Air" mode "Antenna". With VIZIO's the TV must be set on TV input and then go into the Menu to the Settings, Tuner Settings. Change mode type to match what you are trying on the DISH receiver, exit the VIZIO menu and manually enter the channel number.
Eventually with trial and error, you will find a mode/channel combination that isn't effected by your particular environmental interference.
Jan 03, 2011 | Televison & Video
I have a 625 dual tuner from Dish. When I do a check switch it shows that I have signals on both satellites on tuner 1 but tuner 2 has none. When I disconnect the cables from the receiver and reconnect...
Hi, Mary with Dish Network Customer Service, I will be happy to assist with this. This receiver needs to have a Separator (splitter) that has one coax cable coming from the Satellite into the single side and then two cables out, which connect to the receiver box. The Separator is marked with a SAT1 & SAT2. They will connect up to SAT1 & SAT2 on the receiver box itself. If you are using a different typr splitter, it is probably not rated for the splitting of the Satellite feed. I hope this helps you, if not feel free to contact me.
Jan 01, 2011 | DISH Network DVR-625 DTV Receiver /...
You're closed captioning is all jumbled up on Seattle's KIRO TV from my DISH network. The cc works fine on all other channels. Dish says it's a network problem. Any response?
The CC is provided to DISH (and all cable/satellite companies) by the network that creates the programming. Usually, live TV (like news, sports, etc) is the most jumbled because of the time it takes someone to transpose what is being spoken as it is being spoken. If this is a network that is available OTA (via antenna), verify that the issue is not happening when you are receiving the signal from somewhere other than DISH (if you cannot receive an OTA signal, try at a buddy's house that uses another cable provider). If the problem occurs via OTA or other providers, contact KIRO to have them improve their CC service. If it only happens when viewed with DISH, contact DISH, who will then resolve the issue with KIRO (usually a lag time in signal transmission from the provider).
Feb 11, 2010 | Televison & Video
Get dish network to work with hp SR5505F COMPAQ PRESARIO COMPUTER
You can not change channels on Satellite with your TV tuner card. The satellite box decodes the sat signal (it is sent encrypted) you can run S-Video/RCA/HDMI depending on the video card input, but you will be required to change the channel on the Dish box. The TV card can only change channels on broadcast (over the air) channels, you can attach an antenna and it will use the NTSC tuner to change analog channels (if they are still available) and the ATSC tuner to change digital/HD broadcast channels. This card (from your description can ONLY deal with broadcast TV, You will need a TV card with a QAM tuner for unscrambled digital cable. There is no solution for directly interfacing with Satellite on a PC or Mac (DirectTV or Dish) the signal from the satellite is encrypted and requires (at least for DirectTV, a fairly complicated decryption setup to function, this is handled by the tuner box/card combination. Sorry your setup will not support changing the channel on the PC, you may be able to find some kind of software that can utilize an IR transmitter to change the channels on your satellite box, similar to the way a Tivo or other DVR can talk to cable boxes, but that is the best you will be able to do as far as channel changing.
Jan 09, 2010 | HP Computers & Internet
No signal on one tuner for dual tuner box.. neither tv works.
Hi benray there is something else youcan do on that to make sure your getting the strongest signal possible. Youwill need to press the MENU-6-1-1 buttons on the remote. Select Check Switchand Test, after the test is complete select done and then check the signal andif there is still a weak signal we will need to re-point the Dish.
Oct 24, 2009 | DISH Network 322 DTV Receiver
Dish Network - Dish 500 Satellite 110 is not being recognized
You will need a DP or Legacy twin or quad, or DPP twin without using an external switch. If you use Legacy Duals, or DP Duals you will need a switch. USUALLY a SW21 is used to combine the signals but you may have a different one in use if at all.
The primary thing to remember when using a switch is that you must use the same type of LNB as switch e.g. Legacy switches with Legacy LNB's and Dish Pro switches with Dish Pro LNB's.
Check your LNB type. Legacy LNB's have only a Dish Network Logo on them, Dish Pro has DP on them and DPP have DP PLUS on them.
One of three things could be the cause:
1. Line of site. Must be clear of all obstructions to ensure adequate signal.
2. You have a faulty switch, or conflicting LNB and switch, or no switch at all.
3 you may have a bad port on the LNB.
As a fail safe check that your mount is level and plumb. You also may have the dish pointed directly at 119. Check the Skew and elevation settings as well. If LOS IS THE ISSUE YOU MAY NEED TO RELOCATE THE DISH OR REMOVE THE OBSTRUCTION.
In some extreme cases microwave towers and High Voltage lines also pose a problem but doubt this is the case for you.
Sep 04, 2008 | DISH Network 301 DTV Receiver
Televison & Video Logo
5,197 people viewed this question
Top DISH Network Televison & Video Experts
S. Gontko
john milligan
Jaime Hernandez
Are you a DISH Network Televison and Video Expert? Answer questions, earn points and help others
