Samsung plasma Samsung PS50A456P there is a grainy/noise effect to the screen if you look close. Is almost unnoticable on busy images but very on flat colour areas. Is this just a Plasma thing as also have lcd and the screen as much less movement
5 Suggested Answers
  • 5 Answers
SOURCE: PLASMA DISPLAY STARTING UP. PLEASE WAIT
Un plug the power to the Plasma Screen and also to the Media Receiver for ten minutes. Disconnect the off the air antennas both A and B. After ten minutes plug in the plasma screen then the media receiver and turn on wi the remote control. You should now be back in operation. I was.
Also It may not be a bad digital tuner. The TV Guide feature is active even when the zip code is set to all 0s so if you have an over the air antenna attached the TV will look for the TV Guide info and if it can not find it because of a weak signal or the chanel it is tuned to does not carry that information the TV thinks that tuner does not work which triggers the 12 flashes. Also on power up the gray box with the waring message "Plasma Display Starting Up, Please Wait" appears and the screen is blank.
Posted on Feb 20, 2008
  • 109 Answers
SOURCE: Samsung Model: HP-R4262 42" Plasma Problem, pink pixelation/ghosting
Wow, I've been an installer and salesman in the consumer electronics industry since before the first plasma TV came out (Phillips 42" and Fujitsu 42" in 1996) and this is the first time I've ever seen that kind of an answer. "Take this to a repairman and he can add more plasma" what is the repairman a doctor. If it were that easy no one would ever have to upgrade or replace their screens. You can't add more plasma to a screen, if you don't believe me call Samsung and ask them for yourself like I did. I was actually so dumbfounded by your answer that I called a tech friend of mine at Samsung and asked him, his answer; "does this guy work for you?" I told him no and he said, "I was going to tell you to fire him because that's the dumbest thing I've ever heard anyone tell a customer".
What you need to do is take you plasma TV to an AUTHORIZED Samsung dealer/repair shop and inquire about the hazing/ghosting problem with them. Follow this link to find an authorized repair center near you: http://www.samsung.com/us/support/repairlocation/serviceLocator.do?group=&type=&subtype=&model_nm=HP-R4262&dType=D&mType=UM&vType=R&prd_ia_cd=&acc_ia_fl=&disp_nm=HP-R4262
Posted on Jun 19, 2008
SOURCE: LG PLASMA TV WITH COLOURED LINES OVER SCREEN
I have the exact same problem with my 42" LG plasma which is about 3 yrs old. Turned it on one morning and had verticle lines all over it with only the sound playing.
Posted on Jul 07, 2008
SOURCE: Philips 42" Flat Screen Plasma - blinking red light 7 times - HELP please!
I had the same issue with 2 of these sets. It ended up being 2 capacitors were bad on the power supply. They are located towards the bottom of the board, you can visually see they were buldging and leaking slightly. I replaced them with 2 I salvaged out of an old computer (of same values) and the tv works as it did before.
Posted on Jan 08, 2009
SOURCE: LG flat panel plasma with red line
I had the same problem and fixed it by replacing the control board. It's a little nerve wracking, but required only simple hand tools. If you'd like to see detailed pictures of the repair check out my blog.
http://greenrenovation.wordpress.com/du-42px12xc-repair/
Posted on Feb 04, 2009
Samsung plasma tv has vertical lines
The most cost effective thing to do is just replace the TV. The cost to repair will be close to the cost of a new LED flat screen, they are very cheap now.
Aug 21, 2016 | Samsung PN51F8500 51" Full HD 3D Smart...
My SAMSUNG PPM42M6H screen has horizontal grainy lines at the top of screen measuring about 7 inches and from right to left. Lower half seems OK. What should be done or replaced?
Check the ribbon cables in side the TV that connect to the panel. They are the left side looking at the back. Make sure they are all seated propporly. If that does not fix, then your Upper Y Buffer board needs to be replaced.
Apr 10, 2012 | Samsung PPM42M6H 42 in. Plasma TV
I think it's screen burn image retention very grainy mainly red is it worth replacing the screen
No it would not be feasible to replace the display panel. It will cost as much as a new set.
Sep 02, 2010 | Samsung HP-R4252 42 in. Plasma HDTV
I have a 50 inch samsung plasma tv that i think
You would need to purchase a complete new screen as it is not practical or economic to have this done. I would suspect your fault could be a poor connection from the buffer board to that section of the screen or most likely, as you state, the screen is at fault. It is now just as reasonable to buy a new TV than to have the screen replaced
Jan 10, 2010 | Samsung PS50A466 50 in. Plasma HDTV-Ready
Tring to find a samsung pn58a550 plasma screen replacement,my screen is broken. I was tring to find where to buy one.
I've never seen a source for replacment LCD or plasma screens for TVs. Effectively the screen is like the chassis of a car; you can buy everything except that as a repair part.
Even if it were available, the cost of the part would be very close to the cost of an entire TV set. Your best bet is to buy the same model with a blown power supply and take that part from yours to make a whole TV.
Nov 02, 2009 | Samsung PN58A550S Plasma TV
Samsung plasma R4272, sound, but no image on
Sounds like an X or Y drive board. They are the heart beat for driving the plasma display. Without them both you won't see anything.
Oct 13, 2009 | Samsung SP-R4232 42 in. Plasma HDTV
PN50A450 Samsung green screen problem
This is a problem in one or more boards in the TV.
If your TV is still under warranty please call Samsung to get if fix at not charge.
parts for your tv are not cheap and labor is not eider.
Jun 15, 2009 | Samsung PN50A450 50 in. Plasma HDTV
42 inch samsung plasma screen is half blacked out
the problem lies in the y or x board just replace the on thats acting up and you should be ok
Dec 31, 2008 | Samsung SPN4235 42 in. Plasma HDTV
Green noise on all black images on my SAMSUNG LN LCD TV screen
I had a similar problem with my LG plasma. I used the Image Sticking Minimization
(Pixel Orbitor, White Wash, and Inversion) feature which is designed to prevent image burn in and ghosting. This ISM feature may be available on the Samsung or any other brand under a different name. I activated the "white wash" option for about 30 mins, the screen turns white and somehow the pixels get reset. The green noise disappeared after that.
I hope this helps. Phezbuster
Dec 20, 2008 | Televison & Video
Televison & Video Logo
79 people viewed this question
Top Televison & Video Experts
Electro Med Services...
