Question about Canon ImageClass D880 Copier
Adf were can I buy a new adf for my cannon D880
    Problem Solver:
  • 10 Answers
This is a dealer only item, if it's not pulling paper and you can see the feed roller turning,you may just need new feed rollers,but you would still need to order those from you local canon dealer
Posted on Sep 19, 2008
Beeping noise when copying
CLEAN THE FEED RUBBER OF YOUR ADF, OR THE SENSOR. OR REPROGRAM ADF
Mar 26, 2014 | Canon imageCLASS D880 All-In-One Laser...
What to do window says check document open ADF?
That means: open adf cover ( auto original feeder ) and remove jamed paper.
Probably adf needs some maintenance, clean rollers.
Jul 05, 2010 | Canon imageCLASS D880 All-In-One Laser...
We have two canon image class D880 printers in our office. The ADF feeder will not pick up the paper and feed it through the scanner section. We have about 6,000 and 9,000 copies on these. I have cleaned...
Never clean feed rollers with alcohol. Lift the automatic doc. feed cover up. You will see 2 grey rollers. Clean them with 409,fantastic or water. The rollers are available. A pain to put in. Steven
Feb 04, 2010 | Canon imageCLASS D880 All-In-One Laser...
Canon Imageclass D880 automatic document feeder problems
Clean the ADF rollers and pad with alcohol.
Check to see if your ADF has done over 90 000 copies and if it has, change the ADF pick up assembly only.
Good Luck
Oct 19, 2009 | Canon imageCLASS D880 All-In-One Laser...
Check document open ADF Canon D880
If u slide the feeder to the right, in the top left hand corner there is a small p.c.b "printed circuit board" with a sensor on it, replace that board and ur all set.
Jun 05, 2009 | Canon imageCLASS D880 All-In-One Laser...
Feeding sticks on top tray
It sounds like you need an adf roller assembly
Jan 14, 2009 | Canon imageCLASS D880 All-In-One Laser...
Printer D880 Cannon System error E000. What will fdix it?
From a fellow FixYa expert, "Press "Additional Functions", press "#", then press the "Right Arrow" button till it says, "Printer", then press "Set" then press the "Right Arrow" button again until it says "Printer Reset" then press "Set" again, the display will ask you "Yes" or "No". Press the "Left" arrow for "Yes", then press "Set". Now, unplug the power cord and wait 5 seconds and plug back in. If this don't work, get a new fuser."
Jan 06, 2009 | Canon imageCLASS D680 Laser Printer
Cannon image class d880 printer driver
Hi go to thise site www.canon-europa.com and down load the driver if its not there thats mean the driver not supported yet tray to contact the deler on your area
thanks
May 17, 2008 | Office Equipment & Supplies
Black lines
Here you go.
1. Put a paper on the glass don't use the ADF see if you printed copy has a black line on it.
If you do not have a black line on it, do the following.
Lift up the ADF tray go in to additional functions #6 Adjust/Clean and then #2 clean the ADF feeder.
The roller is in the top of the ADF feeder at the right and is white in color. When you press the (set) button you will see it spin.
Also clean the glass you have some whiteout on it. (Look at the glass real good when cleaning it).
Nov 19, 2007 | Canon imageCLASS D880 All-In-One Laser...
Canon ImageClass D880 Copier Logo
126 people viewed this question
old marine
old marine
