Question about Whirlpool Washing Machines
Whirlpool water softener WHE530 has electronics failure. Model purchased March 2007. Where to get 'digital parts' under '3-yr. electronics warrantee'??
    Genius:
  • 1,028 Answers
Call whirlpool direct
Posted on Sep 19, 2008
Tip
Determining the Age of Your Whirlpool Appliance
This advice applies to all appliances manufactured by Whirlpool. Determining the manufactured date of most appliances is accomplished by looking at the SERIAL NUMBER. On Whirlpool appliances this is determined by the following method:
The 1st two numbers identify the WEEK produced, the 2nd digit identifies the YEAR.
Example: EK1201983 (March 2000)
0 - 1980/2010/2040
1 - 1981/2011/2041
2 - 1982/2012/2042
3 - 1983/2013/2043
4 - 1984/2014/2044
5 - 1985/2015/2045
6 - 1986/2016/2046
7 - 1987/2017/2047
8 - 1988/2018/2048
9 - 1989/2019/2049
X - 1990/2020/2050
A - 1991/2021/2051
B - 1992/2022/2052
C - 1993/2023/2053
D - 1994/2024/2054
E - 1995/2025/2055
F - 1996/2026/2056
G - 1997/2027/2057
H - 1998/2028/2058
J - 1999/2029/2059
K - 2000/2030/2060
L - 2001/2031/2061
M - 2002/2032/2062
P - 2003/2033/2063
R - 2004/2034/2064
S - 2005/2035/2065
T - 2006/2036/2066
U - 2007/2037/2067
W - 2008/2038/2068
Y - 2009/2039/2069
NOTE: WHIRLPOOL (Includes Kenmore, Estate, Roper, Frigidaire, and later model Maytags). If in doubt, look at the MODEL number. Whirlpool model numbers are often prefixed with the following numbers:
106, 110, 198, 562, 664, 665, 850
on Dec 05, 2009 | Washing Machines
Tip
0 – 1980/2010/2040
1 – 1981/2011/2041
2 – 1982/2012/2042
3 – 1983/2013/2043
4 – 1984/2014/2044
5 – 1985/2015/2045
6 – 1986/2016/2046
7 – 1987/2017/2047
8 – 1988/2018/2048
9 – 1989/2019/2049
X – 1990/2020/2050
A – 1991/2021/2051
B – 1992/2022/2052
C – 1993/2023/2053
D – 1994/2024/2054
E – 1995/2025/2055
F – 1996/2026/2056
G – 1997/2027/2057
H – 1998/2028/2058
J – 1999/2029/2059
K – 2000/2030/2060
L – 2001/2031/2061
M – 2002/2032/2062
P – 2003/2033/2063
R – 2004/2034/2064
S – 2005/2035/2065
T – 2006/2036/2066
U – 2007/2037/2067
W – 2008/2038/2068
Y – 2009/2039/2069
NOTE: WHIRLPOOL (Includes Kenmore, Estate, Roper, Frigidaire, and later model Maytags). If in doubt, look at the MODEL number. Whirpool model numbers are prefixed with the following numbers:
on Sep 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Fabric softener premature release
In my case it was simply a matter of cleaning the nozzles that spray the water into the MAIN DETERGENT compartment. Turns our that when the washer was filling up, some nozzles were partially clogged and were directing water to the side where the softener compartment was, causing the fluid level to rise and therefore releasing the softener early. The washer was NOT spraying water in the softener side, what happens is that the dispenser tray is configured in a way that when the fluid reaches a certain max level in the softener/bleach trays, it completely drains. A way to test for this problem would be to completely dry the softener tray and start the wash cycle like you normally would (including detergent), only without adding any softener to the tray and see if after filling there is any water in the softener tray, this would prove that the water is coming from the other side.
Apr 13, 2012 | Whirlpool GHW9400 Front Load Washer
MY GE WATER SOFTENER QUIT WORKING PROPERLY AFTER 6 MONTHS ,I HAVE HAD SERVICE CALLS AT $150 EACH TO NO AVAIL IT DRAWS SALT BRINE MY WATER HARDNESS IS 17 I HAVE SOFTENER SET TO 22 .I HAVE PRE WATER...
What is it doing? No soft water? What is the water analysis? Try manually regenerating 2x in same day. Make sure a bypass valve is NOT open. I need more info to help.
H2O Services
Jan 17, 2011 | GE 30000 Grain Water Softener GXSF30H
I have a cabrio purchased in dec of 2007.. model
Hi
Thanks for using FixYa. Yes you are right you can call 1-800-253-1301 whirlpool will send a tech. to fix it and pay for the part. Error F1 means primary control failure and to resolve this you’ll have to replace the machine control assembly. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 05, 2010 | Whirlpool WTW6400SW Cabrio Washer
Top agetator is not working what do i look for
well if the model number thats attached to this call is even close theres still 20 sub-models from ther. anyways your agitator sits upon a plastic drive bell, you can remove the agitator by pulling up sharply upon the agitator (sometimes a belt looped under the agitator provides a better grasping surface), then you can see and touch the drive bell, which is held in place by a 7/16th bolt.. that drive bell is indexed to the transmission drive shaft by splines that sometimes/often wear out allowing the agitator to spin sorta freely..
give that a shot and let me know..
have fun, and good luck,
ttfn
Jan 31, 2010 | Hotpoint VBXR1090D Top Load Washer
My water softener seems to be working, but my water feels nasty, like it's not working
If you have a three valve bypass the center "bypass" may be open and letting hard water past softener.
RJ
Dec 23, 2009 | NRS Fleck 5600 - 64,000 Grain Timer Water...
Not getting soft water. The system charges but it does not seem to be getting brine from the tank to wash the softener pellets. Is there some way for me to check the valve. Maybe change a simple part. ...
You need to remove the venturi valve and clean it. This part is usually found under a round plastic cap that unscrews remember to put softner on bypass or turn off water first
Nov 15, 2009 | NRS Fleck 5600 - 64,000 Grain Timer Water...
High speed spin problem
contact maytag at 1-800-688-9900 and ask whats going on and you need your machine fixed while it is under warranty, it is only covered for a year.
they may refer you to a whirlpool number but whirlpool now ownes matag so this is ok
Jan 21, 2008 | Maytag EPIC MFW9700S Front Load Washer
Washing Machines Logo
722 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
