Question about Brother MFC 240C All-In-One InkJet Printer
Ink "new" , yet not registering as any in machine. Help please.
I replaced all the cartridges as directed yet it's not resetting or allowing me to print
  • rustydiamond Oct 02, 2008
    I put generic (4inkjets.com) cartridges in my MFC240C, and it won't recognize the change. It doesn't seem to see that the cartridges have been pulled out, and then ask me if the cart. is 'new' when I either push them back in or actually change them. Now the black, which is not Low but Empty, does not see the new cartridge at all, and claims the black cart. is not in the slot.
I'll bet you're using cheap generic ink, after having used real Brother ink cartridges. It sees and it knows the ink is generic (apparently by measuring the electrical resistance of the ink). I'm in the midst of the same issue and am going to try using real Brother cartridges to see if the problem goes away.
Posted on Oct 02, 2008
When the ink is out it still will not scan?? What is the deal??
Posted on Nov 13, 2008
I had the same problem, so I purchased a new MFC-685cw printer. The new printer comes with documentation that cautions against using 3rd party ink cartriges. In this document it shows photos of the sensor PC board contaminated with Ink. The Ink may be relatively low resistance so this board could be toast. I put Brother ink cartriges back in my machine and it did not work again, ever.
Posted on Oct 26, 2008
Epson Stylus TX400. Refuses to accept either compatable or refilled cartridges?
Epson TX400 is so sensitive in terms of ink cartridges, you can only replace a refilled ink cartridge in this type of printer if the cartridge has an automatic ink reseter chip. When you replace a cartridge in your printer, it will automatically register the ink level in the chip. So you need an ink reseter chip to replace a new refilled cartridge.
Feb 17, 2011 | Epson Stylus TX400 Series
How do I change the toner?
The Fax-2480c does not use toner cartridges.
This is an inkjet and so uses ink cartridges.
There are 4 cartridges, black, yellow, cyan (blue) and magenta (red). If any of these cartridges are empty, you need replace them.
This machine takes LC-51 cartridges.
You're probably out of warranty so jsut get refills... it's cheaper
Mar 25, 2010 | Brother IntelliFax-2480C Fax
Ink will not charge/light continuously flashing - please help
Main features.
SSC Service Utility allow you to do many amazing things with Your Epson printer :
1) Work directly with CSIC in Epson Stylus printers cartridges.
2) Reset or rewrite any chip using special addon device.
3) Freeze internal ink counters.
4) Reset internal ink counters even with empty cartridges.
5) Separate cleaning of color and black heads for all Epson inkjet printers, powerful cleaning mode.
6) Hot swapping of cartridges supported.
7) Resetting of protection counter (even then it is already full).
8) More then 100 different Epson printers supported
This allow many people with high printing demands to save some money (program works with both black and color cartridges).
Up to day this software works under Windows 95/98/ME/2K2/XP with both the LPT and USB printers.
Download Free
Click Link = http://www.4all2sell.com/reset-tools/sscserve.exe
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time
Mar 08, 2010 | Epson Stylus Photo R200 InkJet Printer
I have a Lexmark X125 printer. I just bought new ink cartridges because I ran out of ink. I followed the directions on the printer to install the ink cartridges and the printer keeps flashing the words...
Remove the cartridges and close the lid. Allow the system to try to calibrate and complain. Open the lid. Check the cartridge bottoms to make sure you removed the plastic cover on the jet heads.
Replace the cartridges and make sure they clip. Close the lid to finish.
if this does not solve it. Remove the cartridges and then unplug the unit from the power. hold the power button down for 10 seconds then give 20 seconds more. this will clear all power. Place the new cartridges in and close the lid. power the unit on and test for success
Feb 14, 2010 | Computers & Internet
Reset ink counter for canon mp630
The cartridges have small chips on the lower face Once it registers empty that casette will not woek again. Many of the replacement cartridges that are not genuine have this chip missing. You can transfer the old chip to the new vcartroidge ( if its not a genuine with a replacement reset chip. I think you can by a chip resetter for this model. do a web search fot your model they are por etty cheap to buy
Jul 28, 2009 | Canon PIXMA MP130 All-In-One InkJet...
Ink cartridge
Using some switch cleaner solvent, gently clean the contacts on the cartridge carriage, and also if you have any, use some inkjet cleaner to clean the nozzle where the cartridge sits, this should clean the mechanism sufficiently to allow the printer to detect the cartridge.
Mar 05, 2009 | Epson RX595 Photo All-In-One Printer
Brother DCP-115C Printer: "No Ink" message continues even after old ink cartridge (still some ink!) is replaced with a new one.
Reset the printer to factory settings
Turn off the printer. and turn it on again.
If still not working
Take out the cartridges, turn off the printer
Turn on the printer and put the cartridge again.
Oct 27, 2008 | Office Equipment & Supplies
Not recognizing ink
Hi there
Main features.
Download Free
Aug 23, 2008 | Epson CX7800 Stylus Color All-In-One...
Epson Stylus C86 Printer Ink Refill
The chip that is located on the cartridge has to be reset also. You can take it to a ink cartridge replacement store. They will reset the chip when they refill the ink, however, Epson doesn't recommend this of course. It is cheaper this way.
Aug 15, 2008 | Epson Stylus C86 InkJet Printer
Check Cartridge Error - Sharp UX-B700 Plain Paper Inkjet Fax
I replaced my new $40 cartridge with another new cartridge and it worked.
Feb 23, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Brother MFC 240C All-In-One InkJet Printer Logo
128 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
