My ASROCK P4V88 motherboard continues to reboot with Windows XP Home - SP-2. I get all type of system error at boot up. I have purchased a new processor (Intel 3.0 GHz). I have purchased the recommended memroy (4-512mb @DDR400 (PC400). Now in addition to the rebooting, the system will not run all four sticks (just 2). Any ideas. Certainly appreciate it. Gene
- try updating the Bios of your systemboard
Posted on Sep 18, 2008
Asrock p4v88 9 beeps
http://pcsupport.about.com/od/fixtheproblem/tp/ami-beep-codes.htm
THE MOTHERBOARD HAVE GIVEN YOU THE CODE OF
CHECKSUM ERROR.TRY CLEAR CMOS IF THAT NOT HELP
THE MOTHER IS IMPOSSIBLE TO FIX.
Feb 15, 2014 | Asrock P4V88 (P4V88 RAID) Motherboard
Boot usb P4V88
Hello download the manual here:
http://www.asrock.com/mb/VIA/P4V88/?cat=Download
http://www.asrock.com/mb/VIA/P4V88/?cat=Manual
You have to enter the bios boot settings, and select to boot from the usb drive, as first boot device .
The file on the usb, must be a iso file so the pc can boot from it.
When you have installed your operating system, you can change the selection again (harddrive as first boot device) to prevent damage to the new install.
The iso file on the drive, can also be burned to a disk.
Here is a great program for the job:
http://cdburnerxp.se/en/download
Its free.
But do select the lowest possible burn settings to prevent damage to the operating system.
Best of luck
If you do this you have to select the cd/dvd drive as first boot device, in the bios settings.
May 08, 2013 | Asrock P4V88 (P4V88 RAID) Motherboard
My pc doesnt start,is unable to start.it said is unable to start windows 7
Hello here is the homepage:
Your mainboard is too old to run windows 7.
Continue using windows xp, or buy a new mainboard that supports windows 7.
Good luck
Feb 22, 2013 | Asrock P4V88 (P4V88 RAID) Motherboard
Asrock P4V88 SATA RAID 1.5 Windows 7
No drivers for windows 7, here at the homepage:
But try the VIA drivers from here:
http://www.viaarena.com/drivers.aspx
This mainboard will probably only only run the 32 bit system.
Good luck
Feb 12, 2011 | Asrock P4V88 (P4V88 RAID) Motherboard
Drivers for windows 7
Hello try the via homepage here:
The mainboards homepage, only supports windows xp:
Best of luck
Oct 11, 2010 | Asrock P4V88 (P4V88 RAID) Motherboard
Dual channel Mode willnot work over 2 gb's of
Hi, please read page 12, section 2.3 in your manual. Dual channel memory must be connected per manual specs.
(Correct colored DIMM slots)
Link to Asrock manual; ftp://174.142.97.10/manual/P4V88.pdf
Main web site provided by Asrock; http://www.asrock.com/mb/overview.asp?Model=p4v88
Once the memory is installed into the correct colored DIMM slots your system should see up to just under 4GB if 4GB is installed while using windows XP. (Refer to Asrock's web site).
Hope you find this helpful and working.
Mike
Aug 01, 2010 | Asrock P4V88 (P4V88 RAID) Motherboard
Windows XP hangs up and never continue opening...
Go to Windows Explorer Right click C:\ go to properties / Tools / click Error check new box pops up tick small box to fix errors and reboot. On reboot windows will scan disk and fix any errors in system files then restart.
If windows restarts OK problem solved If not
Boot from windows CD and after all drivers loaded windows will ask what you want t do 0Install Repair etc" press the R key for repair and follow instructions from there
Warning until window finishes installing do NOT press any keys when it reboots
Nov 21, 2008 | Asrock M266A Motherboard
Constant Rebooting and System Error Messages
I suspect you could have a heat sink fan not working remove side of case and when you turn computer on check fans heat sink and video card are working
With computer OFF
remove heat sink fan and check that the heat sink is not clogged up with fluff and dirt.
I regularly clean both fan and heat sink every 2 months also check the fan in power unit and blow it out
Aug 16, 2008 | Asrock P4V88 (P4V88 RAID) Motherboard
Computers & Internet Logo
80 people viewed this question
David Payne
David Payne
