Question about Gateway 835GM (835GH) PC Desktop
RAM Recognition 835GM PC Desktop
I installed 2 new 1024 mb DDR2 memory modules in my computer in Slot O.
I tried to reinstall the 2 old 512 mb DDR2 memory modules in Slot 1. The computer then would not recognize the 2- 512 mb. memory modules.
If I switch the 2 - 512 mb in Slot 0 and the 2- 1024 mb in Slot 1, it will not recognize the 1024 mb memory.
Do all 4 memory modules have to be the same size in order for the computer to recognize them?
  • Gateway Master
  • 4,806 Answers
The memory is dual channel, so you have to use matched memory for it to work 1gig in each slot if possible, check the 1 gigs and 512's to see if they run at the same bus speed, if they are not matched there is your problem try a gig and a 512 in slot 0 to see if it picks the memory up, also there is sometimes an option in the bios to dissable dual mode
Posted on Nov 15, 2008
I have a HP a1514n media system with 2 - 512 sticks of ram. I replaced one of the 512's with a 1GB stick and my system only shows 1024 ram available. I checked the settings in startup and it shows...
First of all, make sure you have the right memory - 240 pin, DDR2 SDRAM, PC2-4200 MB/sec.
Your machine should support the memory as it has two banks of 1. Sometimes it is simply a sequence problem. In older machines with mixed memory, I always put the largest and fastest in the first slot. You might try just reversing the memory.
Jul 19, 2011 | HP Pavilion a1514n (EX269AAR) PC Desktop
Are all memory chips alike? What type do I need to add to this model? I now have 512, want to at least double.
No, not all RAM modules (memory chips) are alike, there are roughly eight different types. Obviously, as this is a laptop, this has laptop RAM, reducing it to three options now. To figure out exactly which type of memory you have, use this tool: After installation of this bit of software, open it (it should have created a desktop icon) and look under the "Memory" tab on the top (arrow 1) and look at what it says next to "Type" (arrow 2)
Now that you have this type, you can ask an employee at your local best buy for this type of laptop memory (DDR, DDR2, DDR3), or look on for this type of laptop memory. Make sure that you do not get desktop memory, as this will not fit into your laptop's RAM slots. And you're going to want to look for a 1 gig module for doubling a 512. (the bigger the better, just keep in mind that 1 Gigabyte (GB) = 1024 Megabytes (MB))
I hope this helps!
May 07, 2011 | Toshiba Satellite A105-S4244 Notebook
Hi, I would like to upgrade the original 512 MB memory. We have just found the second slot (just under the keyboard!!!) and now I have the following question: can I keep the old 512 MB RAM module and...
What type of RAM is your Pc using? SDR, DDR1 or DDR2? 1 GB single module of RAM maight be heavier for your notepad and the Laptop maight even fail to boot. Just use the 2 Modules of Ram (2 chips each 512MB) and check in BIOS if the RAM capacity has acually changed.
Nov 04, 2010 | Fujitsu Siemens AMILO Pro V2010 Notebook
Computer beeps six times after installing new game. Precision workstation 670. Ram sticks are a 1GB each. My old ram works fine with the computer.
You need the EXACT speed rated RAM.
Your support page states it needs.....
NOTE: Your computer supports only registered memory
Memory capacities
256-MB, 512-MB, 1-GB, 2-GB, and 4-GB ECC
256-MB, 512-MB, 1-GB, 2-GB, and 4-GB ECC modules to a max of 16GB
more info here
Jul 26, 2010 | Dell Precision Workstation 670 PC Desktop
Just bought 2 1GB PNY dual Chanel memory modules for my Computer Make: HP Pavilion 061 Computer Model: RJ181AA-ABA a1600n Currently has Memory: 4 slots: 512 MB, 512 MB, empty, empty QUESTION: which slots...
Start off by putting the first memory module in DIMM slot 0 this is the slot nearest the processor. DIMM slot 1 is the slost after DIMM 0.
Jun 28, 2010 | HP Computers & Internet
How to install memory for T3642 eMachine
eMachines T3642 Computer takes the PC2-5300 DDR2 SDRAM DIMMs. Supports Dual Channel DDR2. Memory Type, and comes installed with 1.0 GB = 512 MB (removable) + 512 MB (removable) of Memory. You can upgrade your eMachines eMachines T3642 Computer to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory, already with 1.0 GB = 512 MB (removable) + 512 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
1. Place the computer power switch in the "off " position and disconnect the AC power cord.
2. Remove the computer top cover following the instructions in the model-specific owner manual.
3. Before touching any electronic components, make sure you first touch an unpainted, grounded metal object to discharge any static electricity stored on your clothing or body.
4. Locate the memory expansion sockets on the computer motherboard. If all the sockets are full, remove smaller capacity modules to allow room for higher capacity modules.
5. The ejector tabs shown in the illustration are used to remove a module. By pushing outward on the ejector tabs, the module will pop-up from the socket and it can then be removed.
6. Handle your new module carefully; do not flex or bend the module. Always grasp the module by its edges.
7. For most installations, DDR modules can be installed in any available expansion slot. Other installations may require the memory to be installed in a particular sequence based on the modules capacity. Check your owner manual to determine the correct installation sequence for your configuration.
  • Insert the module into an available expansion socket. Note how the module is keyed to the socket. This ensures the module can be plugged into the socket one way only. Firmly press the module into position, making certain the module is completely seated in the socket. The ejector tabs at each end of the socket will automatically snap into the locked position. Repeat this procedure for any additional modules you are installing. install_ddr.gif 8. Once the module or modules have been installed, the computer top cover can be reinstalled.
    9. Plug in the AC power cord and reinstall any cables disconnected during the installation process.
    10. Turn on the computer and follow the instructions in your computer owner manual that describe the steps necessary to allow your computer to recognize the newly installed memory.
  • Oct 23, 2009 | E-Machines eMachines T3830 PC Desktop
    RAM increment
    yes just pur chase 1 128 MB or 512 MB or 256 MB ram but check first *********** bord ram module
    check your old 64 Mb ram if it has 1 notch it is ddr1 or ddr2 if it has 2 notch it iks sdram
    then pur chase from shop.
    then fix it on secodn slot
    Apr 24, 2009 | Compaq Presario 5000 PC Desktop
    Dual Channel on an Emachines T5082
    Look closely at the BOLD print
    Memory Upgrade for eMachines eMachines T5082 Computer, the eMachines eMachines T5082 Computer takes the PC2-4200 DDR2 SDRAM DIMMs. Supports Dual Channel DDR2. Memory Type, and comes installed with 512 MB (removable) of Memory. You can upgrade your eMachines eMachines T5082 Computer to up to a maximum of 2.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB (removable) standard Memory installed. For best Computer performance use the maximum amount of allowed Memory per slot for your Computer.
    Choose the following Memory Upgrade for eMachines eMachines T5082 Computer.
    Apr 17, 2009 | E-Machines T5082 PC Desktop
    Install more memory, install new dvd/cd drives
    As far as the memory in your system goes, each memory slot can hold DDR2 PC2-8500, DDR2 PC2-5300, or DDR2 PC2-6400 with a maximum of 1GB per slot. You can add two 1GB modules to your present configuration if you choose.
    For complete info go to: Crucial for Gateway 835GM
    You can also go to and run their scan feature. It's safe and works well.
    Note that you should install memory in matched pairs, so if you should buy 2 more 512MB modules, make sure they are the same kind/type. Also realize that should you upgrade to 4GB of RAM, unless you have a 64-bit OS, it may not recognize all 4GB.
    As for the drives, any "big box" electronics store will have the drives you need/want. Even Wal-Mart has a decent selection of internal drives. The drives should work with no problem. Gateway and other companies put fancy bezels on the front, but they have buttons and hinged doors that will allow most drives to be used. One thing you need to make sure of is what type of drive you need. That is, what type of controller is used, either IDE or the newer SATA. If you are not sure, comment back and i will try to research it further.
    Jan 06, 2009 | Gateway 835GM (835GH) PC Desktop
    I had the same issue on this board where it came with a Samsung 512 MB 533 MHz PC2-4200 DDR2 DIMM. I put in a 1 GB Kingston with the same specs (533 MHz PC2-4200 DDR2) and it would not recongize the Samsung anymore with the system reading as 1 GB of RAM instead of 1.5 GB. Tried every configuration and would only see the Kingston. It would only see the Samsung if I pulled out the Kingston regarless of the slots I use. So, I just bought the exact same make/model of Kingston and it recognized that fine and the system now has 2 GB of memory (max this board allows). And, I had already installed the latest BIOS for this board from Intel before doing all this so wasn't an old BIOS. I'm figuring the board didn't like something about the Samsung memory (speed, module configuration, etc.) that made it not play nice with the Kingston. If interested I bought the DM8400A/1G Kingston modules. And, this board appears not to support dual channel memory. Only has channel A, slots 0 and 1, and I read need two channels to support dual channel (seems obvious). Boards that supports dual channel memory normally have 4 memory slots, two for channel A and two for channel B, then put in matching modules in slot 0 for channel A and B and have dual channel memory access. And if want more ram, then matching modules in slot 1 for channel A and B.
    Jun 25, 2008 | Intel D102GGC2 Motherboard
    Gateway 835GM (835GH) PC Desktop Logo
    168 people viewed this question
    Top Gateway Computers & Internet Experts
    Prashant M
    Prashant M
    Alun Cox
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
