It's a Mitsubishi Projection Television Receiver WD-52628 with no picture but I get sound
  • bradbyrnes Sep 18, 2008
    How do I test it if my lamp is out and can I replace it myself. The TV is on a 2 foot stand and I can't get behind it.
    Genius:
  • 1,665 Answers
Link below has helpfull information for your receiver lamp replacement. have a look..
http://electronics.pricegrabber.com/tv-accessories-and-mounts/m/63750967/
Posted on Sep 18, 2008
  • 3,037 Answers
First thing you can do is pull the speaker grills off the front and gain access to the bottom of the crts. Look to see if you can see a faint glow from the bottom of them.Thats going to be the filaments of the crts and will let me know if the high voltage transformer is running or not. The transformer runs the filaments.
Power it on and put on an active channel. Look down into the crts and see if you can see a picture.
If you can't see a picture, then the flyback transformer is running but the set does not have high voltage to run the crts.There is a large red wire coming out of the flyback. It will go to the high voltage splitter that has a red wire going to each crt. The splitter could be bad. Check it out physically to see if there are any cracks in it.
If there are cracks, replace otherwise it's most likely the high voltage divider has gone bad.It is a common failure in big screens. Unless you have past experience with extremely high voltage, it would not be safe for you to work on this.
Your best bet is to replace the divider and have a professional do it.
Let me know if you have any questions
    Scholar:
  • 163 Answers
Your lamp may need to be replaced.
What is error code 42 on wd62627
Double check as no 42 is indicated on their site.
Nov 29, 2012 | Mitsubishi WD-52627, WD-52628, WD-62627,...
Wd-52628 flashing blinking light
Using your original remote, power on the tv, enter "menu 1,2,3, enter" to "Initialize" the "factory reset" once the window comes up choose to reset to default. That should fix the blinking green timer light.
Jan 16, 2012 | Mitsubishi WD-52628 52" Projection HDTV
I have a Mitsubishi WD 52628. I replaced the tv
try turning it on hold the menu button for eight seconds menu pops up try reseting the settings again as before you had the problem
Jan 23, 2010 | Mitsubishi WD-52628 52" Projection HDTV
No video but have sound everything works except picture lamp has been replaced
Ballast Board or you have a defective Fan, if Fan stops running set will shut off.
Dec 12, 2009 | Mitsubishi WD-52628 52" Projection HDTV
How do you get to the bulb on a Mitsubishi 1080p model wd-52628?
look to the right side of tv front remove the 2 screws watch how the filter comes off to replace back look for 3 screws on the lamp remove them and pull the lamp out replace is opposite of removal
Apr 01, 2009 | Mitsubishi WD-52628 52" Projection HDTV
Steady Yellow Lamp Light on Mitsubishi WD-52628
no its just indicating that the lamp is reaching the end of its lifespan,
Mar 15, 2009 | Mitsubishi WD-52628 52" Projection HDTV
Colors are off (NO YELLOW. BLUE) has a Green Hue to picture
there may be the possiblity of loose dvi cable between chasis and optical enngine. this is a cable much like a montor cable. it has two screws that tighten it down. reseting this sometime help
Dec 19, 2008 | Mitsubishi WD-52528 52" Television
Mitsubishi wd-52628 flashing green timer light
If the power/timer led is the one blinking constantly
the most likely problem is two 3300 mfd caps and 1 to 8 1000mfd caps on the power board.
could be the DM board or caps on it as well.
Jun 17, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Mitsubishi WD-52628 52" Inputs look like old cable scrambled channels
Change the 1000uf @16v capacitors on the FMT board that should solve your problem. You will most likely found that they have swelled. Let me know if you need further info.
Apr 04, 2008 | Mitsubishi WD-52628 52" Projection HDTV
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
Electro Med Services...
