When I Turn On My Zenith HDTV Monitor, It Displays Overlapping Colors Of Red, Blue and Green. The Screen Seems To Be Slanted To An Angl. I Wish To Kow If This Can Be Fixed, Or If I Can Have This Monitor Repaired And How Much Would It Cost To Get It Done? I've Heared Some It Can Be Fixed, And 've Also Heard It Can't Be Fixed and That I'd Just Have To Throw It Out And Buy A Brand New One. Ofcourse The Problem Is I Can't AfFord To Just Go And Buy A Brand New One Of This Size... I've Also Heard Estimates On How mUch It Would Cost Me To Repair This HDTV Monitor. I'd Like More Information On It If Possible. So That I'll Have Better Idea Of What Im Dealing With Here And What I May Have To Loof Forward T... Thank You! ~Sincerly, Wallace Smith III
    Master:
  • 505 Answers
Ok try turning the tv of for 40 minutes by the power point and back on. that way it will reset picture - and should go back to normal please let me now how this goes ((By a rating
Make sure you un plugged it by the power point for the 40 minutes
also make sure there is no speakers or anything magnetic within 60cm's of the tv this can also cause the picture to have strange colors in the screen - if that happens simple Repeat the above......
Regard; Aaron
Thanks for using Fixya.com
Posted on Sep 18, 2008
What is convergence IC problem
Convergence has to do with how different colors are displayed on a screen or monitor - typically the rear projection and some other types. When colors are overlapping to create unexpected combinations, or leave gaps between areas where overlapping is expected that results in a shifted red, green or blue image strip or edge - that is an indication of a convergence issue. They can look like this in severe cases:
Colors will drift, so manufacturers often include a utility to help you nudge the colors back in the right place. Most times this utility is buried in the Set Up Menu and when activated, produces a screen like this:
You will need to adjust the red, green and blue colors for each cross so that only a white cross is displayed. Keep red, green and blue fringing to a minimum. When you're done, the screen should look black and white, symmetrical and straight - like this:
Problems arise when you are no longer able to coax the utility to give you these crisp, B&W results with no red, blue or green ghosting. This is often due to a failing convergence integrated circuit ("Convergence IC"). Many times, replacing it will solve the problem, but other times it can be the result of failing components either ahead or after this IC. If you're attempting to replace this IC, please make sure the TV or monitor has been *unplugged* for 24 hours or more to allow the dangerously high voltages to dissipate.
Sep 08, 2014 | Hitachi 50VS810 50" Rear Projection HDTV
Zenith Projection Television R45W47
Ur tv the convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts are defective still have some life left,it will causes colors lines like RED,GREEN,BLUE misaligns,colors shadows,3D picture.When the 2 STK covergence ICS are totally dead it make this cricket noises and burning smell.The shop cost u $300-350 for parts and labors.
Jun 15, 2010 | Zenith R45W47 45" Rear Projection HDTV
My Dell E176FP 17" LCD monitor keeps cycling colors -red green blue black then colors again... (More) My Dell E176FP 17" LCD monitor keeps cycling colors -red green blue black then colors again during...
well that could be because the screen is going bad. you might want to get another one or take it in to get it fixed, no more than 100 to fix your screen.
Feb 13, 2010 | Dell E176FP 17" LCD Monitor
Monitor only displays blue color, no red or green
hi there, it may be that the RGB balance has been changed. Try getting a person that knows about monitors to calibrate the colors correctly. Or, connect the computer to a different monitor. If it still displays blue, it's a problem for a expert.
Jan 18, 2010 | ViewSonic E790 Monitor
The color on the screen is green when I watch movies. How do I fix this problem?
Good day sir, your inquiry about the green lcd screen can be caused by several things. 1. The monitor/tv produces 3 colors, red green and blue, the tv mixes these three colors to produce the picture. a loss of red and blue produces this green screen. so check the cable, specially the red and blue jack of the component inputs, and the red and blue cable. 2. there may be loose contact on the signal cable. try using the video input instead of the component input. 3. the dvd player may have the problem, check the player component out jack. a loose jack port can cause these problem. hope this may help. thanks
Jul 20, 2009 | Toshiba 32AV502U 31.5 in. LCD HDTV
The colors are distorted and it seems like the only colors that really show are blue, green, and red. When you turn the TV on you can see blue, green, and red lines across the screen. The picture also...
Hi there, this is what we call in the industry convergence board failure. this board regulate the rgb and keeps everything in order so the picture looks nice and clean. when this board starts to malfunction, what you are witnessing is usually the result. I suggest repairing this convergence board. this will fix the 3-d effect.
Mar 08, 2009 | RCA HDLP50W151 50" Rear Projection HDTV
Yellow haze
The blue filter is burnt out. A very common problem in Zenith DLPs. There are 3 color filters, 1 blue (a pinkish color), 1 green (a grayish brown) and 1 red (it is red) they give you your colors for you picture. This is a simple fix.
Mar 23, 2008 | Zenith E44W46LCD 44" Rear Projection...
Yellow Haze Center Screen
Mar 19, 2008 | Zenith E44W46LCD 44" Rear Projection...
Three seperate colors on Screen
Screen may have a hair line crack in it causing projection to be distorted. Inspect screen very closly with magnifying glass if necessary to insure no cracks. If crack is found replace screen.
May 18, 2007 | Zenith R40W46 40" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
